One hundred million billion dollars
Posted by Mord, 08 November 2009 · 8 views
I was discussing/ranting to nobody in particular on irc about how I'd go about doing a colecovision cartridge release, to get an idea of how much money it'd cost me to pull it off, I ended the rant with:
[19:55] <Mord> then take a large gold brick and put it in as a bonus since by then the gold brick will be cheap compared to everything else that's gone into the design.
[19:56] <Mordiechu> but everyone will be going "ooo, gold brick. must buy~"
That aside, it'd still be fun to finally get around to finishing a game some day.
Currently working more on Maze Realms. Trying to fix the glitch when pushing against a wall and trying to exit the room. Currently in most cases you will get stuck unless you're leaving the left side. I'm not entirely sure why that's the case just yet but it's obviously something to do with the collision code.
*update*
Finally had a moment of inspiration and fixed it. Pretty damned simple too. An evening otherwise wasted.
Trying to fix the out-of-bounds held object glitch now. My first attempt seems to ahve worked, but there's an unusual side effect in the heart room. Should only ever be 4 in there. But when you have the key held and push it out of bounds, a 5th one shows up. X_X Trying to track the cause down but likely won't get it done this morning.
February 2012
S M T W T F S
   1234
5678 9 1011
12131415161718
19202122232425
26272829
