    4,962
    2,719
    1,810,622
Nice Mice
atari2600land
My ChuChu Rocket-inspired game has a new name: Nice Mice. In it, your goal is to guide the mouse to the cheese. The mice always turn right when faced with an ability to turn. If you'd like to try the first level out, check out the link in my signature. If you don't have a Virtual Boy emulator handy, here's a screenshot. I've made the mice into little wind-up mice, that's what the thing sticking out of the mouse is. And I've made the number of blocks you have left to place over there at the top left corner. And, now the mouse doesn't move when you place the blocks. When you're done placing the blocks, you press Start to move the mouse. Select resets the level so you can try again, and, when setting blocks, B undoes your last block placement. Next up what I need to do is (try to) get rid of the goto statements in the code (which I don't know why goto statements in C are so bad. Why not use them if the designer of C put them in there?) and some level designing. I want to have this done by the end of the year, and I think I can easily do that. GoSub for VB took about 8 months to complete.
It comes down to maintainability. When you use goto, it's not obvious when you are looking at a destination label, where all of the goto references to that label are. Also, goto breaks the nested structure of C, since it makes it possible to jump into the middle of a nested block.
For an similar example, when I originally programmed Skeleton+ I reused a label as the address of the end of the "YOU WIN" bitmap. Unfortunately, at some point I ended up moving the bitmap to a different address. So instead of drawing 262 lines, the code ended up drawing far more. So if you actually won the game, the screen would roll! All because I was lazy and re-used a label.
I just had to make a mock up of what Chu Chu Rocket would look like on the Virtual boy. The tiles are 24x24 and it fit with Virtual Boy's 384x224 resolution quite well.
Here are the tiles and the sprite.
Chuchu:
Cat:
