Technical information Hardware & Firmware
Posted by Lynxman, 14 March 2010 · 59 views
Technical:
List of FlashCard versions:
Hardware:
1st & 2nd run:
PCB V1.271
3rd run: (20th anniversary limited edition - little Demo added - only 20 pcs produced)
PCB V1.3a4 (changed layout with additional Pads for 8KB EEPROM for the Demo)
4th run:
PCB V1.276 (improved for faster soldering, changed some pads and position of resistors, changed LEDs)
Firmware:
The actual Firmware is V1.11 with Language set V1.21a.
This Firmware runs with all Board 1 FlashCards. (all FlashCards until now)
The only functional difference is the Demo. It will only be shown with the 3rd run FlashCards.
Firmware History:
1.01:
First released Firmware for the FlashCard. (1st and 2nd run FlashCards) - not available for download
1.10:
- add Byte Modify for 93C46
- add demo for 20th anniversary FlashCards
- activate time out routine for erasing Flash Memory
- remove one mistake in dutch language
- optimize code
Second released Firmware for the FlashCard. (3rd run and some of the 4th run) - not available for download
1.11:
- fix write and read bug with 93C46 from manufacturer CSI
- improve erase count routine for 93C46
- bug fix sometimes red status LED do not switch off after verify failt
- bug fix using green LEDs while verify
- optimize erase and time out routine for erasing Flash Memory
Third released Firmware for the FlashCard. - available for download
to do:
- add ".o" file mode
Bootloader:
Note: the Bootloader can not be updated.
1.00:
First released Bootloader for the FlashCard. (S/N 1-74)
1.01: (S/N 75-xx)
- add message "press reset" after Firmware update is complete
- optimize code
February 2012
S M T W T F S
   1234
56789 10 11
12131415161718
19202122232425
26272829
Recent Entries
Tags
    Categories
