Ball Horizontal Proposal
Posted by DanBoris, 08 April 2007 · 79 views
In the discussion of the ball horizontal control circuit, supercat proposed a simplified circuit that would perform the same function. This is the circuit I believe he is describing:
It actually comes pretty close to working, and it does use less chips, but instead of generating 3 speeds it generates 4.
The VSYNC input will make sure the circuit is only enabled for the first four lines on the screen. For each count on the hit counter the MOVE signal will be enabled for either 1,2,3 or 4 lines as follows:
Count Move high on line(s)
0-3 2
4-7 1,2
8-11 2,3,4
12-15 1,2,3,4
I may still be possible to modify this further to get it to work exactly like the original Pong worked.
  • Attached Image
I offered two circuit proposals, but seem to have flubbed my descriptions. The first one was for two speedups (at 4 and 12 volleys, meaning three velocities total), the second was for three speedups (four velocities total).
  • Report
Ah, ok, I assumed you meant that the first circuit had two speeds, instead of two speed ups. I'll have to draw that one up.
Dan
  • Report
May 2012
S M T W T F S
  12345
6789101112
13141516171819
202122 23 242526
2728293031
Recent Entries
Recent Comments
Tags
