CARD Math Part 2
Posted by DanBoris, 17 November 2009 · 66 views
Action
In my last post I showed how the Action! compiler produces some pretty optimized code for CARD math under certain circumstances. This time I will show the more general case which should be pretty familiar to anyone who has done 6502 programming.
Here is the Action! program and it’s dis-assembly:
CARD I
PROC MAIN()
I=2
I=I+2
RETURN
0E6C: .BYTE 00,00
0E6E: 4C 71 0E    JMP  $0E71
;I=2
0E71: A0 00       LDY  #$00
0E73: 8C 6D 0E    STY  $0E6D
0E76: A9 02       LDA  #$02
0E78: 8D 6C 0E    STA  $0E6C
;I=I+2
0E7B: 18          CLC
0E7C: AD 6C 0E    LDA  $0E6C
0E7F: 69 02       ADC  #$02
0E81: 8D 6C 0E    STA  $0E6C
0E84: AD 6D 0E    LDA  $0E6D
0E87: 69 00       ADC  #$00
0E89: 8D 6D 0E    STA  $0E6D
0E8C: 60          RTS
Most of what is here we have discussed before so I won’t go into great detail. As you can see since I is initialized to the value 2 the INY optimization can’t be used so two loads and stores are performed. It’s interesting to note that a different register is used for each byte. I am not sure why the compiler chooses to do this, although in the end it doesn’t affect program size or performance.
The add part of the program is standard 6502 16-bit math, adding the lower byte, then adding the upper byte which also handles and carry from the lower byte.
February 2012
S M T W T F S
   1234
56789 10 11
12131415161718
19202122232425
26272829
Recent Entries
Recent Comments
Tags
