Hi there!
Just made a first attempt at recording data for a C64 longplay video:
Fort Apocalypse
This is a small (100K) package. To use it, unzip it somewhere, then do the following:
- File / Attach Cartridge Image / CRT Image
=> Choose the Fort Apocalypse CRT from the ZIP
- Snapshot / Load Snapshot Image
=> Choose fort_start.vsf
- Snapshot / Start-Stop Playback History
Then you should be able to watch it. It's recorded with VICE 1.20 and AFAIK the files should work on any VICE version equal or higher than 1.15
Let me know if this works for you and in case if you like the recording or if you have any suggestions for improving it
Greetings,
Manuel
Fort Apocalypse
Greetings,
Manuel
Create a custom theme
Will try to dig up 1.20
EDIT: Got 1.21 and it worked, though I had to rename fort_end.vsf to end.vsf
Fun to watch.
Suggestion for improvement:
-is there a more interesting way to dodge missiles than running away until they run out of gas?
