What do you think the following C should do?
In both of these cases, the code looks sane. The compiler doesn't flag them as errors. But the results aren't what you'd expect.
unsigned byte zmem[128*1024];
int read_word( int a, x )
a = zmem[a++]<<8 + zmem[a];
There are three (!) errors in the above code:- precedence error : addition is done before shift
- order of operations : is a incremented before the second array reference?
- compiler bug : a contains a++ after the operation
int PC;
void run( void )
op2code( op & 31, zmem[PC++], zmem[PC++] );
Looks reasonable, provide the next two bytes in the instruction stream as operands. Again, there are several potential bugs lurking:- is PC incremented before or after the function call (tested - it's before, at least with my compiler)
- order of operations : which operand gets which byte?
- is actually PC incremented before the second array reference?
Create a custom theme
