Z3.C - debugged
Posted by EricBall, 02 June 2009 · 24 views
Attached File  z3c.zip (41.63K)
It works! I found the bug in the parsing routine (dumb error on my part). I'm going to call this chapter complete.
The next chapter is to create z3.spin based on this code. I/O will probably be based on a serial terminal interface. And it will run catseye.z3, which is small enough to fit in HUB RAM (hopefully), so no SD I/O. The objective is to do as little as possible other than porting the code from C to SPIN.
Whoops, I jinxed myself there. catseye.z3 isn't working correctly. That's weird 'cause HitchHiker's and MiniZork worked fine.
  • Report
February 2012
S M T W T F S
   1234
56789 10 11
12131415161718
19202122232425
26272829
Recent Entries
Recent Comments
Search My Blog
