    235
    1,089
    434,504
#8 Mindreader and Nim
For those of you who don't know. Nim is a game where you start with a quantity of piles of items. You and your opponent take turns removing any number of items from any pile, including the whole pile. The idea is to be the one to take the last item left. In this port of the ancient game, the piles are represented by numbers in blue squares. The controller works well for this one, too. Move the joystick in a direction to choose the pile, twist the stick to add or subtract from the pile, push the plunger down to confirm, pull it to cancel. Very intuitive actually. You can have three, six or nine piles.
I played this one for almost four hours over the course of two days. Truth. I loved playing Nim. I hadn't ever had the opportunity to play NIM since I was about six years old. It was interesting to play through a few rounds and start to see the patterns and the number combinations one had to reach to ensure a win. The instructions for this game explain exactly what you need to do to win a game. You convert the total number for each pile into it's binary equivalent, add the piles together and figure out what you need to do so that the sum of them all equal zero. Or something like that. The manual gives a better explanation. I was able to beat the game consistently after a while, but only if I used pencil and paper, which I'm afraid I consider a type of cheating without cheatcodes.
Mindreader is also fun. It's like the game Mastermind and its closest home videogame relative is Fun with Numbers(RCA Studio II, 1977). In this version, you try to guess a two, three, four or five digit number. You input your guess and the computer gives you a hint by telling you if you guessed a correct digit in the sequence and if you guessed it in the correct order.
Say your number is 783 and your guess was 748, the game would respond with "HT" meaning one of your digits is a "hit" and is the right number in the right place and one of your digits is a "T" for transpose, meaning right number but not in the right place. Obviously, guessing a two or three digit number is a lot easier than guessing a four or five digit number. Every time you make a guess, the computer gets a point. Every time you solve a number, you get the remaining points. In other words, you have to solve the number in an average of 10 questions or less to beat the computer controlled console to the winning 100 score.I played this game a lot, too.
Okay, while far from the most amazing feat in graphics, this pair of games is still an incredible step up in the area of puzzle games. Yes, you could play these games with a friend and not need a videogame system, but you couldn't play them by yourself without one.
Next entry, Videocart #9
3 Comments
I also played these games for quite a while. I didn't know Nim before playing this game, and curiously, I've since found it in physical form at a store. Maybe I had seen it before but had no idea what it was. I beat the AI a couple of times (without using paper, you cheater!) but I lost most of the replays. I understood the technique to beat the computer but I thought that making all those calculations on paper were kind of silly. You are SURE to win if you do them, so what's the point? On the other hand, without doing it, you're practically sure to lose against the AI. So, although I enjoy the game, it also annoys me in a way.
With Mindreader, well, it was the same thing as always. I usually beat it but I used way too many turns. I don't remember how much I scored, but I'm sure it wasn't good.
hahah, yes! I was cheating. I just remember reading the solution and being fascinated by it. "Here's the tangled mess and here's the one thread you can pull to untie it all." I don't think I understood -why- that solution works and I think that's what I had hoped to understand by doing it on paper.
I'm not sure if I understood the solution either, even though I should have, given my programming background. I just didn't want to get too obsessed with this one game.
