Building a batari dumper?
Posted by Zach, 18 July 2006 · 42 views
If the design is really as simple as shown below, and if it could actually work, this could be a good electronics project for a beginner like myself. It seems to be just a matter of attaching wires.
If the dumper is safe, I can think of a certain undumped Charlie Brown prototype that resides here in Northern California. It was batari who first suggested the idea of using a switch to make his dumping program work safely, although what he described is a little different.
I already have the AA board and batari's dumper program on an EPROM. I believe a cartridge slot can be purchased without much difficulty. Although an Atari board is easy to find, removing the chip will be some work. I don't know if such a thing as a 48-24 multiplexor with a switch exists, or if multiplexor is technically the correct term, but I think you can figure out what I mean. So what do you think? Would it work? Would it be safe?
EDIT: Added a new diagram based on suggestions from batari.
  • Attached Image
  • Attached Image
All you need is a DPDT switch connected to the chip enable pin (A12) and a couple of resistors. This will allow you to float the bus on one or the other cart, so you can have them both plugged in at the same time.
  • Report
Thanks for the quick reply. I'm not sure I understand what you are describing. Would it need two cartridge slots? If not, how could both the cartridge and the dumper board connect to the VCS?
  • Report
You could do it one of two ways. One, you could build a board with two slots on it, one for the batari dumper cart and one for the cart to dump. Two, you could hack a slot onto an AA board.
On second thought, you just need a SPDT switch. You have 3 connections on a switch like this. The center connects to A12 coming from the 2600. Each side of the switch connects to A12 on a slot or board, and also to a resistor running to GND.
If the switch is in one position, only one cart is enabled at a time. It doesn't matter that everything else is connected - only one chip will have access to the bus at any time.
  • Report
Thanks Fred. I added a new diagram based on your description. Does that look more like what you are talking about?
I only drew the first 12 lines for simplicity's sake. Also, I didn't draw the connections to the Atari board. It'll be easier to trace which holes connect to which pins once I remove the chip. Also, I set aside resistors and GND for a later time. For now, the next step will be to buy a soldering iron and learn how to use it. If that works out, I'll come back here to ask for help selecting resistors.
  • Report
If anyone is wondering, I am still working on this. I bought a soldering iron recently and managed to fuse together a Y-shaped wire. I was a bit surprised when smoke came out of the solder, but I guess there is more in it than metal.
So far I have a soldering iron, 25 ft of wire, and an SPDT switch. What I still need to get is a cartidge slot and a 4K ROM board. I will order the former when I get my next paycheck. If I get a desoldering pump, it shouldn't be too hard to make the latter from a Pac-Man cart.
  • Report
February 2012
S M T W T F S
   1234
56789 10 11
12131415161718
19202122232425
26272829
Recent Comments
