jbanes Posted February 6, 2007 Share Posted February 6, 2007 (edited) Touch Wii This is basically a Touch Me/Simon game for the Opera web browser on the Nintendo Wii. Simply repeat the sequence with the Wiimote directional pad. You can optionally turn the Wiimote sideways for more comfortable control. The game is 100% Javascript, and will even work on other DOM-compliant web browsers. (Use the arrow keys if you play on a computer.) URL: http://java.dnsalias.com/touchwii/ Keep in mind that this is Beta software at the moment. If you break something, let me know so I can fix it. I have tons of info on the experience to share, but it's late. So that will have to wait until tomorrow. Edit: Internet Explorer will NOT work! See the post below for more info. May I suggest an upgrade or two? Edited February 6, 2007 by jbanes Quote Link to comment Share on other sites More sharing options...
jbanes Posted February 6, 2007 Author Share Posted February 6, 2007 I promised info on the experience of Javascript programming for the Wii, so here you go. Some of it is a tiny bit technical, but I'll try to keep it as understandable as possible. DOM Compliance I probably should have mentioned this last night, but Internet Explorer is still not DOM compliant. Due to Microsoft's inability to implement the DOM 2 Events spec (possibly the simplest friggin' spec in the world), Touch Wii will NOT operate correctly in Internet Explorer. You have been warned! Both Opera and Firefox/Mozilla are known to work, however, and Safari/KHTML should work just fine. It's only Microsoft that doesn't seem to know how to read a spec. Wiimote Buttons As previously mentioned in another thread, the Wiimote input has been decoded. As it turns out, Opera passes each button press as if it were a keyboard key. Which means that the standard "addEventListener" command can be used to trap button presses as if they were key presses. However, there are a few caveats. Opera's Use of the Buttons It would appear that button presses are extremely sluggish to respond. You need to hold the button for as much as half a second for it to register in the Javascript. Even worse, Opera ignores all attempts to stop the default events from happening. Which means that when you press the '1' key, you go to the Favorites screen even if the keypress is registered by your Javascript. Poking at the Javascript with a stick seems to reveal an interesting design behind the Wii browser. Rather than having a window that contains an HTML rendering component, the Wii seems to take a very Mozilla-like tack by running ALL browser functions through the HTML renderer. Thus the homepage is the Wii Opera interface, and what we think of as the homepage is actually a frame inside the Wii interface. This is a fairly old design, but it works because several features are disabled in the Wii browser. For example, the Wii browser does not allow new Windows to be opened. Such attempts are ignored, and the page is navigated as if it were a regular click. This doesn't normally work in other browsers as the webpage may accidently break out of its IFrame prison. To be clear, this is why the keypresses are accessible through Javascript! The Opera browser needs them in order to run its own Javascript in response to button presses. Since the Opera Javascript runs before the Touch Wii Javascript, it is not possible to disable Opera's control over the Wiimote. (Something that is normally quite possible on a mouse and keyboard system.) At least not with what I know at the moment. However, this does suggest that special Wii extensions may be available to Javascript programmers. In theory, you could take control of the scrolling interface, activate the Favorites screen, zoom in and out, etc. Of course, that assumes that the parent frame allows you the security permissions to do so. It may not be possible due to such security restrictions. Button Mappings Directional Pad - These keys are used to tab between different clickable links on a webpage. If you design your Wii game correctly, you can use these buttons without the user noticing that Opera is interpreting them. That makes these the only useful buttons on the Wiimote. A Button - While a keycode does come in for this, it's not particularly useful. By the time you get the code, the browser has already dispatched a "Mouse Click" event which will arrive as soon as you're done processing the key. As a result, it's far more useful to use this button for mouse clicks rather than trying to remap it as a keyboard key. B Button - This button enters scrolling mode. If your application is designed to take less space than a single Wii screenful, then it might be useful to you. More likely, you'll end up seeing directional arrows when you least expect it. +/- Buttons - These Zoom In and Zoom Out of the webpage. Since this can't be turned off, these buttons are not useful. See "Screen Size" below for more info relating to these keys. Home Button - This is the only button that Opera does not fire a code for. The reason is that the Wii operating system handles its press, and overlays the Wii Menu options instead. 1 Button - Pressing this takes you to the Favorites screen. This happens about the same time your code receives the keypress event, so it's not particularly useful. 2 Button - This "changes the display mode", whatever that means. It seems to disable various bits of key formatting (such as text alignment), making it even more than useless for games. Alert Popups If you use the "alert()" Javascript function, the alert will actually take over the screen until dismissed. This makes it function a bit more like the Mac OS X alerts than the Windows-style alerts. It could be useful for giving the user particular information, or even just pausing the game. I presume the "confirm()" function can be used the same way, but to ask a question instead. Flash Support Contrary to early reports, the Wiimote buttons do not appear to function inside flash programs. You must use Javascript if you want to read the presses. It is yet unclear if Javascript and Flash can communicate using a Livescript-type interface. Screen Size The actual screensize of the Wii is 640x480. However, you normally see a virtual 800x600 display scaled down to fit in 640x480 pixels. The + and - buttons are used to switch between true 640x480 mode or virtual 800x600 mode. When you're zoomed out, you're seeing the latter. When you're zoomed in, you're seeing the former. The only difference is that 640x480 mode still renders to an 800x600 screen. i.e. The browser does not reorganize the display like most web browsers do when you resize them. As a result, you must scroll around when you're zoomed in. Rotating the Controller There is no built in support for rotating the controller. The DPad directions continue to report the same keycode. If you want to support the use of a sideways controller, you need to handle the same keycodes differently depending on the "mode". The way I handled this in Touch Wii was to allow the user to click on the Wiimote image. When clicked, the Wiimote would turn in the direction of the current control scheme. What Kind of Games Can be Made? I hate to dash people's hopes, but arcade style games that use the Wiimote's buttons are probably out for the moment. Opera's mapping of every button on the Wiimote ensures that. The Opera Javascript appears capable enough, but the sluggishness and trapping of the controls makes it impractical. However, the functionality provided by the use of the DPad could still come in handy for some, slower types of games. Wargames (either Hex or Real Time Strategy) come to mind as an excellent use of the Wiimote. Virtual Board Games could be fun as well. Online Card Games via AJAX are perfectly possible, as is a game like Battleship. So there are still many possibilities, but the options are a bit more limited than one would have hoped for. Ongoing Investigations Obviously, I've only spent a limited amount of time with the Wii browser. There's still a ton more stuff to be discovered. For example, what happens if you use two or more controllers with Opera? Will they work? Will Opera identify them all the same, or use different key codes? That's a question I can't answer yet. Another thing that needs to be done is to walk the DOM top to bottom to see if any further functionality can be discovered. Similarly, the Javascript objects need to be walked with a "foreach" loop to see if there are any special functions that can be used. It's also possible that further investigation may invalidate some of my theories surrounding the operation of the Wii Opera browser. Questions? I'd be happy to answer any questions you might have, to the best of my ability. Feel free to either post them here or PM me. Happy coding! Quote Link to comment Share on other sites More sharing options...
maibock Posted February 6, 2007 Share Posted February 6, 2007 oh cool! I'll try this when I get home.. nice work Quote Link to comment Share on other sites More sharing options...
ManShowBoy Posted February 6, 2007 Share Posted February 6, 2007 Touch Wii, what a name.... Quote Link to comment Share on other sites More sharing options...
jbanes Posted February 6, 2007 Author Share Posted February 6, 2007 Touch Wii, what a name.... Thank you! I thought it was a nice play on the name of the "Touch Me" arcade game. Quote Link to comment Share on other sites More sharing options...
moycon Posted February 6, 2007 Share Posted February 6, 2007 Touch Wii, what a name.... Thank you! I thought it was a nice play on the name of the "Touch Me" arcade game. Touch Wii ??? LOL Hmmmm I might suggest Touch Mii instead... for obvious reasons. Quote Link to comment Share on other sites More sharing options...
jbanes Posted February 6, 2007 Author Share Posted February 6, 2007 Touch Wii ??? LOL Hmmmm I might suggest Touch Mii instead... for obvious reasons. Touch Mii would be a GREAT name! If I had any Miis in it. Quote Link to comment Share on other sites More sharing options...
moycon Posted February 6, 2007 Share Posted February 6, 2007 Touch Wii ??? LOL Hmmmm I might suggest Touch Mii instead... for obvious reasons. Touch Mii would be a GREAT name! If I had any Miis in it. Does the game have Wii's in it? Quote Link to comment Share on other sites More sharing options...
jbanes Posted February 6, 2007 Author Share Posted February 6, 2007 Does the game have Wii's in it? It has Wiimotes. Quote Link to comment Share on other sites More sharing options...
moycon Posted February 7, 2007 Share Posted February 7, 2007 So then by your logic since the game doesn't have Mii's in it...or Wii's in it, It should be called Touch Wiimote?? I think it's safe to say everyone here knows why you're so passionate about keeping the name "Touch Wii" Quote Link to comment Share on other sites More sharing options...
Bivotar Posted February 7, 2007 Share Posted February 7, 2007 Pretty cool! Just played a game (and made this reply via the Wii). Quote Link to comment Share on other sites More sharing options...
jbanes Posted February 7, 2007 Author Share Posted February 7, 2007 I think it's safe to say everyone here knows why you're so passionate about keeping the name "Touch Wii" Dang. You caught me. I'm too lazy to redo the title image. (Don't laugh too hard. I'm not one to joke about laziness. ) Seriously, what's the big deal? Touch Me + Wii = Touch Wii. Hilarity ensues. Is there any reason in particular you'd like it changed? Quote Link to comment Share on other sites More sharing options...
jbanes Posted February 7, 2007 Author Share Posted February 7, 2007 (edited) Pretty cool! Just played a game (and made this reply via the Wii). Thanks Bivotar! It's really just a demo app at the moment, but I do think it turned out kind of neat. Edited February 7, 2007 by jbanes Quote Link to comment Share on other sites More sharing options...
jbanes Posted February 7, 2007 Author Share Posted February 7, 2007 (edited) Game updated! - Glitch where you could continue an existing game has been removed. - Glitch that continually showed "Incorrect" in response to button presses has been corrected. - Help button added. - Help file added. - Images are now preloaded. If you noticed any sluggishness when you first started the game, this should now go away. - "Loading... XX%" message added. That should be it for this little experiment. Just remember that it's a lot more impressive looking on an actual Wii! While you can use a regular web browser (minus Internet Explorer), the full effect of being able to use the Wiimote is lost. In particular, the ability to rotate the Wiimote becomes a dud feature when viewed with a regular web browser. So try pointing your Wiis at the site, and see if you like it any better that way! URL: http://java.dnsalias.com/touchwii Edited February 7, 2007 by jbanes Quote Link to comment Share on other sites More sharing options...
moycon Posted February 7, 2007 Share Posted February 7, 2007 Is there any reason in particular you'd like it changed? None I was just messing with you, Although given a vote I'd say Touch Mii is a better title if only because it really is a play on words of the original game, plus think of the children!! Quote Link to comment Share on other sites More sharing options...
Lord Helmet Posted March 1, 2007 Share Posted March 1, 2007 Looks like you are finally getting some attention on digg with this (I posted Touch Wii weeks ago, but it got little response). http://digg.com/gaming_news/WiiCade_API_al..._of_Flash_games http://digg.com/gaming_news/Wiicade_develo...e_API_for_Flash Quote Link to comment Share on other sites More sharing options...
jbanes Posted March 2, 2007 Author Share Posted March 2, 2007 Looks like you are finally getting some attention on digg with this We've been discussing this in the "A New Way to Homebrew Thread". Hop on over and take a look. (I posted Touch Wii weeks ago, but it got little response). Yeah, I saw it. Thanks! Unfortunately, Touch Wii didn't get much of a critical response. It was probably too simple of a demo for most people to take notice. However, this API is pretty big news at the moment. I've also got a few more games on the way that are of a much higher quality. You can play a beta of the Tetris game here: http://java.dnsalias.com/tetris/ Quote Link to comment Share on other sites More sharing options...
Lord Helmet Posted March 2, 2007 Share Posted March 2, 2007 Looks like you are finally getting some attention on digg with this We've been discussing this in the "A New Way to Homebrew Thread". Hop on over and take a look. (I posted Touch Wii weeks ago, but it got little response). Yeah, I saw it. Thanks! Unfortunately, Touch Wii didn't get much of a critical response. It was probably too simple of a demo for most people to take notice. However, this API is pretty big news at the moment. I've also got a few more games on the way that are of a much higher quality. You can play a beta of the Tetris game here: http://java.dnsalias.com/tetris/ The only thing I think is missing from Touch Mii is sound Quote Link to comment Share on other sites More sharing options...
jbanes Posted March 2, 2007 Author Share Posted March 2, 2007 The only thing I think is missing from Touch Mii is sound Surprisingly, that ends up being a lot harder than you'd think. Wii Opera has no media player to speak of, and support for the WHATWG Audio object is useless due to a lack of supported formats. (It's pretty much just a stub.) The only sound generation capabilities currently available are those provided by Flash. Thankfully, the Opera guys said that they'll support audio in the future. (It's on their TODO list.) So I have the option of working with flash widgets to provide sound, or simply waiting until Opera gets it fixed. Of course, I don't like webpages that make sound; so you can guess which way I'm leaning. Quote Link to comment Share on other sites More sharing options...
