8bitdomain Posted February 25, 2007 Share Posted February 25, 2007 Here is an project I built as a RGB test monitor for arcade games but has been attached to a Jaguar for gameplay. It is based on a Sharp 5" LQ5A136 display. The monitor has the needed 15Khz Hsync and has built in backlighting. The controller board I built contains the backlight inverter, power supply which takes a 12vdc input and provides the +5, +8 & -5 for the LCD. Dip switches to select PAL or NTSC, InputA (DB9) or InputB (8pin header), Pos or Neg sync selection and an unusual horizontal flip or vertical flip mode. The LCD's alone are normally $300 but I was able to find about 10 surplus units for a reasonable price. See attached pictures for detail on the controller board and running Doom. If there is any interest I could build up a few, however the price would be a little steep, around $138 complete. Mike Quote Link to comment Share on other sites More sharing options...
Pocket Posted February 25, 2007 Share Posted February 25, 2007 Nice homework Quote Link to comment Share on other sites More sharing options...
Gorf Posted February 25, 2007 Share Posted February 25, 2007 Now if you can fit that all in a small handheld....... Quote Link to comment Share on other sites More sharing options...
Atariman Posted February 25, 2007 Share Posted February 25, 2007 And if you DO try to make a handheld version, make sure to add in the JaguarCD... you know... so that it won't be too easy... (j/k) Quote Link to comment Share on other sites More sharing options...
+LS650 Posted February 25, 2007 Share Posted February 25, 2007 Pardon my ignorance - but wouldn't it have been a lot easier to go buy one of those small LCD monitors that take an AV input? You know, like you see parents putting in the mini-van for the kids to watch DVDs on? Quote Link to comment Share on other sites More sharing options...
8bitdomain Posted February 25, 2007 Author Share Posted February 25, 2007 Pardon my ignorance - but wouldn't it have been a lot easier to go buy one of those small LCD monitors that take an AV input? You know, like you see parents putting in the mini-van for the kids to watch DVDs on? Yes it would, but the origional goal was to be able to test arcade boards (Williams, Midway, etc.) So having RGB inputs was a must. Having it work for the Jag too is just icing on the cake. Mike Quote Link to comment Share on other sites More sharing options...
ManShowBoy Posted February 25, 2007 Share Posted February 25, 2007 Would be cool to turn that into a flip-top screen and have it close where the jag cd connects when not in use. Quote Link to comment Share on other sites More sharing options...
Gorf Posted February 26, 2007 Share Posted February 26, 2007 And if you DO try to make a handheld version, make sure to add in the JaguarCD... you know... so that it won't be too easy... (j/k) Nowadays I bet you can find a nice compact CD drive that could work. Quote Link to comment Share on other sites More sharing options...
Gorf Posted February 26, 2007 Share Posted February 26, 2007 Pardon my ignorance - but wouldn't it have been a lot easier to go buy one of those small LCD monitors that take an AV input? You know, like you see parents putting in the mini-van for the kids to watch DVDs on? And Jag can do RGB from the SV port which blows all others away in quality as that is the abolute direct signal most display devices break down to anyway. R,G,B, Hsync, Vsync. This is the REAL deal. Quote Link to comment Share on other sites More sharing options...
+remowilliams Posted February 26, 2007 Share Posted February 26, 2007 This is the REAL deal. Got that right, this is really cool. RGB FTW! This would be a great hobby/testing display unit. Quote Link to comment Share on other sites More sharing options...
Gorf Posted February 26, 2007 Share Posted February 26, 2007 Pardon my ignorance - but wouldn't it have been a lot easier to go buy one of those small LCD monitors that take an AV input? You know, like you see parents putting in the mini-van for the kids to watch DVDs on? I use one of these for my Jag development. It good to do vertical monitor games on too. Quote Link to comment Share on other sites More sharing options...
jaguar_fan Posted March 6, 2007 Share Posted March 6, 2007 Here is an project I built as a RGB test monitor for arcade games but has been attached to a Jaguar for gameplay. It is based on a Sharp 5" LQ5A136 display. The monitor has the needed 15Khz Hsync and has built in backlighting. The controller board I built contains the backlight inverter, power supply which takes a 12vdc input and provides the +5, +8 & -5 for the LCD. Dip switches to select PAL or NTSC, InputA (DB9) or InputB (8pin header), Pos or Neg sync selection and an unusual horizontal flip or vertical flip mode. The LCD's alone are normally $300 but I was able to find about 10 surplus units for a reasonable price. See attached pictures for detail on the controller board and running Doom. If there is any interest I could build up a few, however the price would be a little steep, around $138 complete. Mike Nice solution! Quote Link to comment Share on other sites More sharing options...
ovalbugmann Posted March 13, 2007 Share Posted March 13, 2007 Nice work! a RGB connection for the Jaguar is very nice. Do you know of any devices that can make my computer monitor use the needed 15Khz Hsync so I can use the RGB output on my ICD catbox? Quote Link to comment Share on other sites More sharing options...
Gorf Posted March 13, 2007 Share Posted March 13, 2007 So what's the latest scoop on this thing....any new progress? Quote Link to comment Share on other sites More sharing options...
JagMod Posted April 9, 2007 Share Posted April 9, 2007 Just got mine today!! Picture is clean and crisp. Thanks Mike! Quote Link to comment Share on other sites More sharing options...
+remowilliams Posted April 10, 2007 Share Posted April 10, 2007 Picture is clean and crisp. Thanks Mike! I'll say! BSG Mini anyone? Quote Link to comment Share on other sites More sharing options...
Lastblade Posted April 11, 2007 Share Posted April 11, 2007 Picture is clean and crisp. Thanks Mike! I'll say! BSG Mini anyone? Nice!!!! Quote Link to comment Share on other sites More sharing options...
jaguar_fan Posted April 11, 2007 Share Posted April 11, 2007 Awesome!! Quote Link to comment Share on other sites More sharing options...
ovalbugmann Posted April 17, 2007 Share Posted April 17, 2007 Nice detailed picture on that display, cool little monitor, and that ship interior kinda looks like a face. Quote Link to comment Share on other sites More sharing options...
Pocket Posted April 17, 2007 Share Posted April 17, 2007 lol that's just awesome Quote Link to comment Share on other sites More sharing options...
+remowilliams Posted April 17, 2007 Share Posted April 17, 2007 Nice detailed picture on that display, cool little monitor, and that ship interior kinda looks like a face. It does! I didn't notice that before. Quote Link to comment Share on other sites More sharing options...
