Tyrop Posted July 4, 2007 Share Posted July 4, 2007 I just got an XEP80. If I try to binary load MAC/65, it does not work. Does anyone know how to get it to work with MAC/65? The following web page seems to suggest that MAC/65 is the only OSS product that will work with the XEP80: http://www.atarimagazines.com/v7n6/xep80slideshow.html Quote Link to comment Share on other sites More sharing options...
+Guitarman Posted July 4, 2007 Share Posted July 4, 2007 I just got an XEP80. If I try to binary load MAC/65, it does not work. Does anyone know how to get it to work with MAC/65? The following web page seems to suggest that MAC/65 is the only OSS product that will work with the XEP80: http://www.atarimagazines.com/v7n6/xep80slideshow.html Are you using disk or cart based Mac/65?? Quote Link to comment Share on other sites More sharing options...
Tyrop Posted July 4, 2007 Author Share Posted July 4, 2007 I'm using disk based. Quote Link to comment Share on other sites More sharing options...
+Guitarman Posted July 4, 2007 Share Posted July 4, 2007 I'm using disk based. It may be that you have to use the cart version since the XEP80 driver would have to be loaded from the disk. I can try it for you to see if that will work, if you don't have the cart. Quote Link to comment Share on other sites More sharing options...
Tyrop Posted July 4, 2007 Author Share Posted July 4, 2007 I'll bet you're right. Probably need the cartridge. I don't have the cartridge. I have the FTE version. That's too bad, I bought this so I can use it with MAC/65 so that I could get a little better readability. At least is was not that much money. I would be curious to find out if it works for you. Quote Link to comment Share on other sites More sharing options...
+Guitarman Posted July 4, 2007 Share Posted July 4, 2007 I'll bet you're right. Probably need the cartridge. I don't have the cartridge. I have the FTE version. That's too bad, I bought this so I can use it with MAC/65 so that I could get a little better readability. At least is was not that much money. I would be curious to find out if it works for you. I try to test it tomorrow (4th) and let you know. If it does, I may have an extra M65 cart, if you're interested. I'll check. Quote Link to comment Share on other sites More sharing options...
guus.assmann Posted July 4, 2007 Share Posted July 4, 2007 I'll bet you're right. Probably need the cartridge. I don't have the cartridge. I have the FTE version. That's too bad, I bought this so I can use it with MAC/65 so that I could get a little better readability. At least is was not that much money. I would be curious to find out if it works for you. I try to test it tomorrow (4th) and let you know. If it does, I may have an extra M65 cart, if you're interested. I'll check. If it does work, I can also supply a M65Cart. I've made a combo that also has ten Basix-XL + XE and Action. Quote Link to comment Share on other sites More sharing options...
Tyrop Posted July 5, 2007 Author Share Posted July 5, 2007 Thanks for checking. I would be interested in the cartridge if you have you would like to sell. Quote Link to comment Share on other sites More sharing options...
Defender II Posted July 5, 2007 Share Posted July 5, 2007 (edited) What is the most available monitor for the XEP80? I have one laying here and need a monitor. Can you use the same monitor for the Bit3 80 collumn card? Edited July 6, 2007 by Defender II Quote Link to comment Share on other sites More sharing options...
+Guitarman Posted July 5, 2007 Share Posted July 5, 2007 What is the most available monitor for the XEP80? I have one laying here and need a monitor. Can you use the same monitor for the Bit2 80 collumn card? The output for the XEP80 is a standard composite output. You can use any monitor with composite in, including a TV. Quote Link to comment Share on other sites More sharing options...
Defender II Posted July 6, 2007 Share Posted July 6, 2007 What is the most available monitor for the XEP80? I have one laying here and need a monitor. Can you use the same monitor for the Bit2 80 collumn card? The output for the XEP80 is a standard composite output. You can use any monitor with composite in, including a TV. Thanks. Any idea about the Bit3 80 column board for the 800? It looks like the same connector. Quote Link to comment Share on other sites More sharing options...
