"Footprint" of DOS.SYS?
Larry
MEMLO (dec. 743, 744) contains the lowest free RAM address pointer.
So, once DOS loads, either use a monitor to view those locations - or you can just ?PEEK from BASIC.
The end point of the load won't necessarily be the start of free RAM since DOS needs extra memory for workspace, buffers etc.
Thanks, Rybags!
That is most helpful.
Is this Atari DOS 2.5? :?
Any DOS.
BASIC, or whatever language/app is used will use MEMLO as it's starting point to store programs/data.
Here are some MEMLO values for several Dos versions I have looked at thus far:
Dos 2.0s $1CFC
Dos 2.5 $1E1C
MyDos 4.50 $1EE9
MyDos 3.07 $1BE9
OSS Dos from Basic XL toolkit $1B00 (this Dos can't load a DUP.SYS)
Sparta Dos 3.2G $17A2
Sparta Dos X 4.22 $10FF (!!!)
-Larry
DOS 1.0 always loaded DUP as well (from memory - I don't think I ever had the "pleasure")
FRE(0) is just APPMHI - MEMLO
APPMHI (14,15 dec) tells the OS the highest location that the application is using (ie BASIC or whatever language should set it as the program/variable storage grows)
A neat trick on OSA and OSB (400/800) was to set APPMHI to something like $9D00 - the OS then would not be able to open a screen after System Reset, so it in a way was a means to protect software from funny business.
The bug was fixed in the XL OS.
