neotokeo2001 Posted February 5, 2008 Share Posted February 5, 2008 Does anyone know how the pipes are displayed in Mario Brothers? I want to change them to stairs but I can't seem to find them anywhere. Quote Link to comment Share on other sites More sharing options...
Nukey Shay Posted February 5, 2008 Share Posted February 5, 2008 The pipe gfx is "hard-coded" right in the display kernal... ;2nd bank... Lfae4: lda #$74 ; 2 sta COLUP0 ; 3 sta COLUP1 ; 3 lda #$c4 ; 2 color of top pipes $FAEB ;1st bank... ;drawing top pipe area: Lb045: dex ; 2 bpl Lb045 ; 2³ sta RESP1 ; 3 sta WSYNC ; 3 sta HMOVE ; 3 ldx #$e0 ; 2 top lines gfx $B04F sta WSYNC ; 3 stx PF0 ; 3 ldx #$0c ; 2 jsr Lb3dc ; 6 sta HMCLR ; 3 lda ($b0),y ; 5 and ($b4),y ; 5 ldx #$60 ; 2 middle lines gfx $B060 sta WSYNC ; 3 sta GRP0 ; 3 stx PF0 ; 3 lda ($c5),y ; 5 and ($cd),y ; 5 sta GRP1 ; 3 lda ($a1),y ; 5 sta ENAM0 ; 3 lda ($a3),y ; 5 sta ENAM1 ; 3 iny ; 2 ldx #$06 ; 2 jsr Lb3f3 ; 6 lda ($b0),y ; 5 and ($b4),y ; 5 ldx #$70 ; 2 bottom lines gfx $B080 ;drawing bottom pipe area: Lb330: sta HMCLR ; 3 lda $f9 ; 3 sta COLUPF ; 3 lda ($b2),y ; 5 and ($b6),y ; 5 ldx #$c0 ; 2 sta WSYNC ; 3 sta GRP0 ; 3 stx PF2 ; 3 lda ($cb),y ; 5 and ($d3),y ; 5 sta GRP1 ; 3 lda ($ba),y ; 5 sta COLUP0 ; 3 iny ; 2 ldx #$06 ; 2 jsr Lb469 ; 6 lda ($b2),y ; 5 and ($b6),y ; 5 ldx #$00 ; 2 sta WSYNC ; 3 sta GRP0 ; 3 stx PF2 ; 3 lda ($cb),y ; 5 and ($d3),y ; 5 sta GRP1 ; 3 lda ($a1),y ; 5 sta ENAM0 ; 3 lda ($a3),y ; 5 sta ENAM1 ; 3 iny ; 2 lda #$c4 ; 2 Color bottom pipes $B36E sta COLUPF ; 3 ldx #$0e ; 2 jsr Lb480 ; 6 lda ($b2),y ; 5 and ($b6),y ; 5 ldx #$70 ; 2 bottom pipes gfx $B37B I can't remember who made this disassembly...but it looks like it was being converted to 16k. The addresses shown above should coincide with the 8k game. mariobros.zip Quote Link to comment Share on other sites More sharing options...
neotokeo2001 Posted February 6, 2008 Author Share Posted February 6, 2008 I have no idea what I am looking at. Is there any way to make the top pipes look like stairs without too much trouble? Maybe just flip them. Quote Link to comment Share on other sites More sharing options...
Nukey Shay Posted February 6, 2008 Share Posted February 6, 2008 Have at it. I'm retired. *at least as far as looking at this one goes The addresses listed are correct. HOM = 004f ; enter the value you want to use for the top lines of the upper pipes. Original value = #$E0 GFX = 11100000 What you see onscreen for PF0 = "-xxx" HOM = 0060 ; "" middle lines of the upper pipes. Original value = #$60 GFX = 011000000 What you see onscreen for PF0 = "-xx-" HOM = 0080 ; "" bottom lines of the upper pipes. Original value = #$70 GFX = 11100000 What you see onscreen for PF0 = "xxx-" HOM = 037b ; value used for the lower pipes. Original value = #$70 GFX = 11100000 What you see onscreen for PF0 = "xxx-" HOM = 1aeb ; value used for the upper pipes color. Original value = #$C4 Color = Green HOM = 036e ; value used for the lower pipes color. Original value = #$C4 Color = Green I dunno how to explain it any clearer if you don't want to at least look at the disassembly. Quote Link to comment Share on other sites More sharing options...
neotokeo2001 Posted February 6, 2008 Author Share Posted February 6, 2008 Have at it. I'm retired.*at least as far as looking at this one goes The addresses listed are correct. I wasn't sure what I was looking at but your second post made it plain. What you see onscreen for PF0 = "-xxx" I have tried to work with the disassembly for various games and I can make the changes but then I can't get it converted back to a BIN. I think I am allergic to DOS. Quote Link to comment Share on other sites More sharing options...
Impaler_26 Posted February 6, 2008 Share Posted February 6, 2008 Hm... with the stairs it looks really ankward when the enemys drop in, i guess you'll also have to fix the enemy's position to align with the stairs... Quote Link to comment Share on other sites More sharing options...
neotokeo2001 Posted February 6, 2008 Author Share Posted February 6, 2008 Now that I have my brain-dead moment past me. The enemies don't quite line up with the stairs but you can only really tell in screen shots. Thanks Nukey and Impaler. Quote Link to comment Share on other sites More sharing options...
neotokeo2001 Posted February 7, 2008 Author Share Posted February 7, 2008 I also want to change the lives for Player 1 and 2 to zero with no extra lives awarded. Am I looking in the right area? Lfdb8: lda $9d ; 3 beq Lfddd ; 2³ lda #<Space ; 2 blank space gfx...low byte sta $97 ; 3 reset all 6 pointers to be blank sta $95 ; 3 sta $93 ; 3 sta $91 ; 3 sta $8f ; 3 sta $8d ; 3 ldy $87,x ; 4 get # of lives left for this player...bit 0 doesn't apply ldx #$0c ; 2 set pointer counter to 6 (characters) x2 (bytes each) lda #<Reserve ; 2 Mario head gfx...low byte bne Lfdd5 ; 2³ always branch (to the starting position) Lfdd2: sta $8d,x ; 4 reset pointer to the head gfx dey ; 2 reduce temp value (# of lives remaining) Lfdd5:;Start here ;NOTE: bit 0 isn't used to store the value of # of lives left... ; so each pass through the loop checks for a minimum value of 2 (instead of 1) cpy #$02 ; 2 Is Y a value of 2? bcc Lfddd ; 2³ branch if less (i.e. ran out of lives to display) dex ; 2 ...otherwise, reduce to the next position & branch back up dex ; 2 bpl Lfdd2 ; 2³ Lfddd: rts ; 6 Quote Link to comment Share on other sites More sharing options...
Nukey Shay Posted February 8, 2008 Share Posted February 8, 2008 No, that area is only printing what the life counter already holds...you want to edit where the life counter itself is set/adjusted. The starting number of lives is set here: ldx #$03 ; 2 lda $80 ; 3 and #$04 ; 2 bne Lf22e ; 2³ ldx #$05 ; 2 Lf22e: stx $87 ; 3 $80 holds the game variations (numbered 0 to 7). The 1st 4 use 5 lives, the next 4 use only 3. X is given a value of 3 (lives) at the top, and a bit test is done to the game variations to check if it should use 5 instead. So in both cases, you'd want to load X with a value of 1. These 2 spots are at $1225 and $122D in HOM. Edit them to hold only the rightmost bit instead of 2 bits. You also want to skip bumping up the number of lives... inc $87,x ; 6 lda #$0f ; 2 bne Lfe28 ; 2³ Lfe23: Change $1E1D and $1E1E to value $EA (replacing INC $87,x with 2 NOP's)...by using bitpattern XXX-X-X- in HOM. Quote Link to comment Share on other sites More sharing options...
Nukey Shay Posted February 8, 2008 Share Posted February 8, 2008 BTW the reason that the printing routine checks for a minimum value of 2 is because the current life is not shown in reserve. When playing the last life, no reserves are shown...when the life counter is zero, the game is over. Quote Link to comment Share on other sites More sharing options...
Shawn Posted February 9, 2008 Share Posted February 9, 2008 (edited) The pipe gfx is "hard-coded" right in the display kernal... I can't remember who made this disassembly...but it looks like it was being converted to 16k. The addresses shown above should coincide with the 8k game. I paid supercat to convert it to F6 last year so I had enough space to add my end screen on Smurfs Arcade Action. When I wanted to change the pipes, I just removed them all together. Hope this helps. Edited February 9, 2008 by Shawn Sr. Quote Link to comment Share on other sites More sharing options...
