Atari Charles Posted February 27, 2008 Share Posted February 27, 2008 (edited) I figured I would try using Hackomatic 2 than assembly to make music on the Atari 2600. As Paul Slocum has a program called Music Kit 2.0 here: http://qotile.net/files/music_kit_2.zip and as the user is supposed to take Paul's "songmain" to modify and make a new song, I figured why not try this using Hackomatic 2(my favorite tool) to do the same thing. As the song bin files are essentially a song(audio), why not hack it up. In Hackomatic 2, I compaired "songmain" with another cool from "b00daw" of nephariousatarious, I found where there was changed and where patterns emerged for the audio of the bins. With this a person can make changes in the code, save it as a bin, try it on an emulator and if you like the changes continue, if not redo. I opened three Hackomatics "songmain", "nephariousatarious" and "mysong("songmain" that will be changed)". I compaired the code and figured out where "nephariousatarious" was changed to make a new song. Of course, he didn't do it via hackomatic, so his results are more exact. Even without compairing both songs, a person can see where things repeat and where there is a pattern in Paul's "songmain". Change the line but coloring or uncoloring squares either adding, subtracting or redoing a line of code and see what happens. Don't change the first 0000 to 0017 or your song may be screwed up or be shortened. Also I figured I would play around with placing images in areas reserved for sound. I got some interesting results with blocky Pac-Man and his ghosts(no I didn't try E.T. yet) and the sounds were still cool and somewhat musical. And oddly had some atari Pac-Man sounds in there. People have showed what sound looks like, but now we can hear what Atari graphics sound like. The Pac-Man and Ghost song is not done, but here is a w.i.p.. Here are the original songs and the songs I have done. Check them out it Hackomatic or Bithacker to see what changes I have made. For those of you like myself, who are still learning on the Atari 2600 programming front, Hackomatic is a good way to try your hand at music. songmain.bin botb_1653_b00daw___nephariousatarious.bin Nepharious_Atarious_Keponic_Remix_Charles_F._Gray_.bin Paul_SlocumSongmainGlitchRemix_Charles_F._Gray_.bin Pac_man_and_Ghost_Song__Charles_F._Gray_.bin PaulSlocumSongmain_if_extended_by_this_intro_Charles_F._Gray_.bin Pac_man_and_Ghost_Song_B_Side_and_B_Sure_to_open_it_with_Hackomastic_too__Charles_F._Gray_.bin Edited February 28, 2008 by Atari Charles Quote Link to comment Share on other sites More sharing options...
B00daW Posted February 28, 2008 Share Posted February 28, 2008 As the song bin files are essentially a song(audio), why not hack it up. In Hackomatic 2, I compaired "songmain" with another cool song "botb_1653 b00daw" by nephariousatarious, I found where there was changed and where pattrens emerged for the audio of the bins. With this a person can make changes in the code, save it as a bin, try it on an emulator and if you like the changes continue, if not redo. Silly Charlie... The song is called 'Nepharious Atarious.' Quote Link to comment Share on other sites More sharing options...
Atari Charles Posted February 28, 2008 Author Share Posted February 28, 2008 Fixed. Quote Link to comment Share on other sites More sharing options...
B00daW Posted February 28, 2008 Share Posted February 28, 2008 Fixed. Is it??? Oi... ;P HAHAHA.... Good luck! Quote Link to comment Share on other sites More sharing options...
gambler172 Posted February 28, 2008 Share Posted February 28, 2008 Hi Charles Nice.... greetings Walter Quote Link to comment Share on other sites More sharing options...
+Charlie Cat Posted March 1, 2008 Share Posted March 1, 2008 Hi Chuck: Nice Work. Thanks for posting. Anthony.... Quote Link to comment Share on other sites More sharing options...
