cosmosiss Posted April 28, 2008 Share Posted April 28, 2008 Yay, time to spam the hack forums again. So we know the colors on this great game are horrible, like most early games, and in B&W mode, the background is grey. Well, I think this set of colors looks better, and the ships have been somewhat vectorized. So what to do with the B&W mode colors? Change them to the horrible colors in the Combat airplane levels. That should balance things out. space_combat.bin Quote Link to comment Share on other sites More sharing options...
Nukey Shay Posted April 28, 2008 Share Posted April 28, 2008 Given that virtually nobody uses B&W televisions anymore, most people use the switch to control some other function (like switching to the PAL color set, or pausing a game). To be compatable with all hardware, the program would need to keep track of the switch's old state on the previous frame (costing 1 bit of ram), as well as a bit set -only- on powerup that determines if the 7800 console is being used (another bit of ram). These adjustments can be easily added to Space War, because the original game did not use ram addresses $E0 to $FB for anything ($FC to $FF are used by the stack to keep track of JSR return addresses...the rest are not used - or even cleared on powerup). Also, the program is only 2k, so an additional 2k of romspace is added by pushing the values that exist at $F7FC-$F7FF to be at $FFFC-$FFFF instead. To do this, just add ORG $FFFC above the last 4 bytes. A reverse-engineered disassembly of the game was made by Manuel Polik and posted at [stella] for your hacking convenience. Quote Link to comment Share on other sites More sharing options...
ComputerSpaceFan Posted April 28, 2008 Share Posted April 28, 2008 I switch to B&W when playing Surround because that default color scheme makes me want to hurl. Quote Link to comment Share on other sites More sharing options...
cosmosiss Posted April 29, 2008 Author Share Posted April 29, 2008 (edited) I believe Thomas changed them to make it ressemble a Tron cycles game. -- 4K A good coder could add neat variations like guided missiles and obstacles/mazes. Now that would trully be a Space Combat game. Don't know much about the Stella list, but I believe the Stella Gets A New Brain CD has the archives. -- Yep, here it is. This bad boy is going to a cart! Tron__Surround_Hack___2006___Thomas_Jentzsch_.bin Edited April 29, 2008 by cosmosiss 1 Quote Link to comment Share on other sites More sharing options...
Impaler_26 Posted April 29, 2008 Share Posted April 29, 2008 You can find the Space War disassembly here (plus alot more). I also found this Space War 4K disassembly on my hard disk... spacewar_4k.zip 1 Quote Link to comment Share on other sites More sharing options...
cosmosiss Posted April 30, 2008 Author Share Posted April 30, 2008 Thank you! Site has been raided. Quote Link to comment Share on other sites More sharing options...
Rob Mitchell Posted August 20, 2008 Share Posted August 20, 2008 Thomas and I did a hack of Spacewar in 2005 .. called PDP Spacewar. Search for it here. Rob Mitchell Quote Link to comment Share on other sites More sharing options...
