xt5 Posted July 22, 2008 Share Posted July 22, 2008 hi, this is my first post here, Im really new to the atari world, just got my first ever atari just 2 weeks ago I've playing a little with cc65, the assembler and linker seems really good, but I've lot of problems with the compiler generated code. first, I don't like to use page zero at all for temporal values and pointers, that is why I've done my own linker scripts and generate a nice exe without use the atari libs of the cc65 package for example a simple code like this: unsigned char data[211] = { 0x4A, 0x55, 0x45, 0x47, 0x4F, 0x31, 0x20, 0x44, 0x46, 0x53, 0x46, 0x00, 0x4A, 0x55, 0x45, 0x47, .................................. ...................... .............. 0x31, 0x37, 0x00 }; // global unsigned char i; // global ...... .. for(i=0; i<sizeof(data); i++) data[i]-=0x20; generate a very big and slow code that uses a page zero pointer, the code generated is lda #$00 L0147: sta _i cmp #$D3 bcs L0122 lda #<(_data) ldx #>(_data) clc adc _i bcc L012C inx L012C: sta ptr1 stx ptr1+1 ldy #$00 lda (ptr1),y sec sbc #$20 sta (ptr1),y lda _i clc adc #$01 jmp L0147 the same code is generated either with -O, -Oi, -Or, -Os, -Oir, -Ois, -Ors the code without optimization is even worse: L0121: ldx #$00 lda _i cmp #$D3 jsr boolult jne L0124 jmp L0122 L0124: lda #<(_data) ldx #>(_data) clc adc _i bcc L012C inx L012C: jsr pushax ldy #$00 jsr ldauidx sec sbc #$20 ldy #$00 jsr staspidx ldx #$00 lda _i pha clc adc #$01 sta _i pla jmp L0121 L0122: so Im very disappointed with this, as I've to tweak 50% of the code generated, maybe Im just missing something because the code you would expect by that simple snippet is something that just avoid page zero *abuse* like this ldy #$00 loop: cpy #$D3 bcs L0130 lda _data,y sec sbc #$20 sta _data,y iny jmp loop that seems to be a very common issue on 6502 compilers as I've tested IAR one and seems also abuse zero page, also I've tested other one (can't remeber the name) and was even worse.. please give me any direction in this fun atari coding thing regards, xt5 Quote Link to comment Share on other sites More sharing options...
Heaven/TQA Posted July 22, 2008 Share Posted July 22, 2008 i love the "i++" and "lda i, clc, adc #1" one... no kidding... I am a pure assembler fan so I have no clue regarding cc65.... but here are Wrathchild, Bryan etc who use cc65...they should be able to help a little bit... but in general compiler can not be as good as a hand optimised code... f.e. how should cc65 know that you won't use (zp),y but absolute instead? for the compiler it is the same? Quote Link to comment Share on other sites More sharing options...
PacMan Posted July 22, 2008 Share Posted July 22, 2008 Aren't there any pragma directives that can be used to control this behavior ? I seem to recall this but it has been ages since I used the cc65 compiler. Quote Link to comment Share on other sites More sharing options...
Rybags Posted July 22, 2008 Share Posted July 22, 2008 Couldn't you just have a series of TEMPn type variables. Then when you want to use them as pointers, just assign them the value needed? Another pure Asm fan here - personally I don't see a lot of point using mid-level languages on machines with such small amounts of RAM. Quote Link to comment Share on other sites More sharing options...
Irgendwer Posted July 22, 2008 Share Posted July 22, 2008 (edited) Welcome, some remarks for you: I would address this problem to the mailing list of CC65. Uz is very kind and responsive and many other CC65 experts are subscribed to the list too the 'clc,adc #$01' thing could be an improvement for the peephole optimizer - a perfect disscussion entry for the list of course you can use the inline assembler when performing such tasks or write your own assembler function, retrieving address, size and operation... the code is so bad since CC65 has to cover many use cases, sizes of datatypes etc. and it generates general code patterns for the operations Another pure Asm fan here - personally I don't see a lot of point using mid-level languages on machines with such small amounts of RAM. I think it is better than using Basic: You can better connect high-level-code to assemby-code (which you need anyhow for 'impressive'-results) and it is faster. Also the maintainability is much better. It would have been no fun and longer job to write the IO and highscore-entry management (sorting) in ECKN in assembly language. CU Irgendwer Edited July 24, 2008 by Irgendwer Quote Link to comment Share on other sites More sharing options...
MagerValp Posted July 24, 2008 Share Posted July 24, 2008 Hiya, this was discussed on the CC65 mailing list, and the solution is to use ++i in the for loop. i++ is an expression that returns a value, and then increments i, which is why the weird code is generated. With ++i the code becomes: ; ; for(i = 0; i < sizeof(data); ++i) { ; lda #$00 sta _i L0017: lda _i cmp #$D3 bcs L0018 ; ; data[i] -= 0x20; ; lda #<(_data) ldx #>(_data) clc adc _i bcc L0022 inx L0022: sta ptr1 stx ptr1+1 ldy #$00 lda (ptr1),y sec sbc #$20 sta (ptr1),y ; ; for(i = 0; i < sizeof(data); ++i) { ; inc _i jmp L0017 ; ; } ; L0018: rts You still get slightly convoluted code for the array code, as C uses ints for array indexing, which won't fit in the Y register. The compiler will never match the speed and size of handwritten 6502 assembler, so enjoy the faster development and better maintainability of the main code, and leave the speed critical parts in assembler (which is easy to call from C). Quote Link to comment Share on other sites More sharing options...
Bryan Posted July 24, 2008 Share Posted July 24, 2008 no kidding... I am a pure assembler fan so I have no clue regarding cc65.... but here are Wrathchild, Bryan etc who use cc65...they should be able to help a little bit... I've never used C on the Atari. Quote Link to comment Share on other sites More sharing options...
Heaven/TQA Posted July 24, 2008 Share Posted July 24, 2008 Ooops... Sorry Bryan... I ment the guy who did Jelly Beans, wasn't this written in C? Quote Link to comment Share on other sites More sharing options...
