Playfield scrolling..
yuppicide
Let's say I have this as a playfield:
play1
playfield:
  ..XXXXXXXXXXXXXXXXXXXXXXXXXXXX
end
goto fr
play2
playfield:
  XXXXXXXXXXXXXXXXXXXX..XXXXXXXX
end
goto fr
How would I make it so that the playfield in play1 scrolls down the screen.. once that line gets to the bottom it'll show play2?
I would say you should use the playfield variables:
if b = 0 && k = 0 then var0 = %00111111 : var1 = %11111111 : var2 = %11111111 : var3 = %11111111
if b = 1 && k = 0 then var0 = %11111111 : var1 = %11111111 : var2 = %11111100 : var3 = %11111111
if k = Scrolls then pfhline 0 11 31 off
if k < Scrolls then pfscroll up : k = k + 1 else k = 0 : b = b + 1
I used 'Scrolls' because I'm not really sure how many times you have to scroll the playfield to roll the entire screen. Add as many lines for the b variable as you need, then add a "if b = _ then b = 0" for the highest number that b has an if/then statement for.
Edited by MausGames
Will digest what you guys wrote tomorrow when I am at work. That's where I've installed vbB and bB for now. Too late for me to work at home I need sleep.
Hey, Maus. I saw you were interested in a hard copy of the BB manual? How could you not have a printer?
Anyway, I'll print you one in black and white if you're interested. It's 52 pages I believe. PM me if you need. Would make a great book to read on the toilet.
Edited by yuppicide
Actually, I think you missed that I have spaces in there..
play1 would be
 pfhline 3 0 31 on
play 2 would require 2 pfhline commands
 pfhline 0 1 2 on
pfhline 5 1 31 on
Instead of using a whole playfield you can define lines with the "pfhline" command.
For "play 1" this would be: pfhline 2 0 31 on
and for "play 2": pfhline 0 0 21 on
pfhline 24 0 31 on
I didn't miss that, i copied and pasted your playfields and made 2 examples.
This example with your playfields does exactly the same as the other one with the pfhlines from my previous post:
 rem playfield
COLUPF=50 : COLUBK=120
play1
playfield:
end
drawscreen
if !joy0fire then goto play1
play2
playfield:
end
drawscreen
if !joy0up then goto play2
goto play1
 rem pfhline
start
pfhline 2 0 31 on
drawscreen
if !joy0fire then goto start
pfhline 2 0 31 off
test
pfhline 0 0 21 on
pfhline 24 0 31 on
drawscreen
if !joy0up then goto test
pfhline 0 0 21 off
goto start
playfield.bas.bin
pfhline.bas.bin
