New 2600 game Last Mobile Space Battalion
LMSB
My first game :) This was made using Atari Basic. What a great software it is.
LMSB is kind of like a cross between space invaders and yar's revenge. I guess.
It tested successfuly on PC Stella and also on Stella for the Sega Dreamcast. For some reason, it doesn't work on Stellax.
Dos-man
author
LMSB.zip
When i tried to compile the game i got a "Branch out of range" Error. You have to set smartbranching on at the beginning of your code when you use "then" instead of "then goto".
Also the player-colors needs to be updated before every call to drawscreen, otherwise they will have the same color as the score. That can simply be fixed by placing the player-colors directly after the "gameloop"-label like this:
 rem Main loop for program
gameloop
COLUP0 = 30 : COLUP1 = 158
 z{0} = 0
 if switchreset then reboot
All in all the game is already not bad, hope you keep on working on it. :)
Edited by Impaler_26
Hi LMSB
Not bad for a first effort.A little bit like a vertical "OUTLAW"
greetings Walter
Walter, I was thinking that too. Am I correct that Outlaw is not a 1 player game? Has anyone created a version of outlaw that is one player against the computer.
Phillip
gameloop
 z{0} = 0
Thank you for the advice. I will try it. However, there shouldn't be any real need for you to compile this since the ROM is distributed with the game. I'd like to keep working on this, but I'm finding Batari Basic to be pretty sensitive. Don't get me wrong; it's a wonderful RAD tool, but some things don't work as expected and other things "break" it for no apparent reason.
Phillip
Yes, check out Gunfight.
EDIT: Or did you mean a hack of the original Outlaw?
Either really. Although I guess with the simplistic graphics of the game, a hack and a clone would be pretty much indistinguishable from each other.
Phil
gameloop
 z{0} = 0
Phillip
When i tried the game i was just wondering why the player and the spaceship have the same color as the score. So i took a look at the code and thought i'll mention it.
If you wanna continue working on your game you'll find a lot of nice people here who can help you when you have a problem with something. :)
You can also find some good code-examples and a lot of code from other games to take a look at (this helped me understand at least a little bit of what's possible with bB and what not).
gameloop
 z{0} = 0
Phillip
Cool, the advice really worked. I was able to do a lot of the things that I wasn't able to do before. I got a wider shots for the alien and scrolling satellites. Also got an end to the game (when player gets hit you hear a beep, then you see laser beams.) Also got rid of the compilation error. Thanks.
The link is the same. Just download again and try out the improved game. Let me know what you think.
Phillip
LMSB.zip
Phillip
I like the changes you made to the game, the scrolling satellites are a good idea and the game is now more fun to play. IMO it would be nice to see the final score on the game over screen...
Phillip
Cool. Did you download binary 2 or binary 3? Binary 3 was put up in another post. My not being able to upload files to my website anymore is really a disaster :) Maybe I can find a free site hoster, but I'm not holding my breath. It's only a 8kb zip file for God's sake.
Your idea to keep the score showing makes good sense. Also, I used a for loop to play a long beep and turn the player's ship red b4 blanking the screen. I'm finding the bonus levels to be really challenging. To correct some misinfo I gave earlier, the bonus levels are at 2000, 4000, and 6000 points.
Anyhow, here is the fourth binary ROM.
I guess the only question I have is how to create a title screen. I'm thinking something like that might be possible to do using 2 main loops instead of just 1.
55
loop
draw title screen
on switchreset goto 59
drawscreen
goto 55
59
loop
play the game
drawscreen
goto 59
Maybe it won't work, I'm not sure. Anyway, I don't think I can give a title screen to LMSB because of the resolution. However, it's something I will probably try when I eventually make a 2nd game.
Phillip
LMSB.zip
I tried binary #2, i'll check out the 2 newer versions later. It sucks that you can't use your website anymore but if you post your bB-games here they'll be online forever. :D
The easiest way to add a title-screen to your game is to place it at the begining of your code, that way you won't have to change anything else. Here's a quick'n'dirty example:
1 set smartbranching on
title
COLUPF = 132
playfield:
XXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXX
X..............................X
X....X.....X...X.XXXXX.XXXX....X
X....X.....XX.XX.X.....X...X...X
X....X.....XXXXX.X.....X...X...X
X....X.....X.X.X.XXXXX.XXXX....X
X....X.....X...X.....X.X...X...X
X....XXXXX.X...X.XXXXX.XXXX....X
end
drawscreen
if !joy0fire then title
2	rem blue playing field (the satellites)
3	COLUPF = 158
4	 g{6} = 0
This ugly title is just for testing, i'm sure you can make a better looking one. :D
title
COLUPF = 132
playfield:
W X..............................X
end
drawscreen
3	COLUPF = 158
4	 g{6} = 0
Well, you can really skip 3 since 4 is the same thing with some visual and audio improvements.
You'll find 4 much more playable than 2. Reduced flickering, easier on the eyes. A better looking sprite for the alien ship. The scrolling speed for the satellites was reduced, and the scrolling code was placed in the extra VScroll section of the program's code.
I wouldn't be so sure of that :) The huge pixels (each satellite is composed of just 8 pixels!) make it difficult to compose any sort of a real title screen for this particular game. I'll try it though. It'll be a must-have item for my next game.
dos-man
Is it supposed to make that constant, irritating noise that sounds like a mosquito is choking on a fire alarm or is something wrong with my emulator?
I had some luck putting in some better background audio. It has a real x-fles/ufo sound. It doesn't quite qualify as "background music", but it's close. I had to change the sound of the cannons firing to match the new background. Let me know what you think of the changes.
Phillip
LMSB.zip
Phillip
Thanks, but it's almost as irritating as the old sound. Maybe slowing the sound down and doing an adjustment or two would make it more pleasing to the ears?
Phillip
I'll work on it tonight, and early next week when I'm off work. It's a lot of trial and error.
Phillip
Yep. Same for me. I just goof around with Tone Toy 2008 until I find something I like.
Try this one out. It's actual music with varying tones, based on the other one.
This is the last section of the game I'm going to fix or improve, so make it count :)
Phillip
LMSB.zip
I tried out binaries #3-6, with the latest changes the game comes along nicely! It's pretty challenging but therefor it doesn't get boring too fast.
I'm not sure about the sounds though, IMO the sounds in #6 are not really better than in the earlier ones, they could be "spacier" for my taste. I also think the "game over"-sound takes too long.
It's better now that that the sound changes. It's less irritating. Thanks.
Thanks, I'm glad to hear it.
I consider the sound to be a huge improvement over version 1. Not having downloaded any sound-production utilities of any kind at this point, that was definitely my best shot. I do worry that it distracts a bit from the game, but I haven't really played with the new sounds yet to know for sure.
Well, Peter Norton said it best in his assembly language guide: a computer program is never done, but we must stop somewhere. I leave this game in the hands of Atari fans. I'll be interested to see if it spawns any offshoots. I reserve no rights to the source code. Anyone can recompile a new version provided that they do not distribute it under the LMSB or Last Mobile Space Battallion names. Perhaps someone can put out something with improved sound effects, or something that allows changing sound effects with the options switch.
I'll be back in a few weeks or perhaps months with a new game. I don't have any ideas or concepts yet, but I'm sure something will come. I'm also intersted in seeing if it's possible to create a Sega Genesis game using similar tools. This was quite a fun project.
Regards,
Phillip
One last bit of fun here with LMSB...
The code at line 107 moves the UFO around. Just from memory, it looks something like this.
107	  v = rand
	  if v < 127 then player1x = player1x + 7
	  if v > 127 then player1x = player1x - 7
This makes the UFO
wiggle
a lot. He moves back and forth, but doesn't go real far from his original starting point, usually.
To make the UFO do a lot less
wiggling
, try replacing the code at 107 with the following code:
107		  v = rand
	  if v < 50 then player1x = player1x - 7
	  if v > 50 && v < 100 then player1x = player1x + 7
	  if v > 100 && v < 150 then player1x = player1x - 7
	  if v > 150 && v < 200 then player1x = player1x + 7
	  if v > 200 && v < 225 then player1x = player1x - 7
	  if v > 225 && v < 250 then player1x = player1x + 7
Now he's really traversing back and forth across the screen. But it gets worse. Add the following code onto the end of the new code, and he'll start occasionally firing on you!
	  if v > 5 then goto 108
	  missile1y = player1y+4
		missile1x = player1x + 8
	gosub fireshot
That's in addition to firing whenever you fire. The line
is what makes him fire. Replace the 5 with a smaller value for less frequent firing. A number larger than 5 would cause him to fire more often.
Man, that's rough. You end up having to hide
behind
the satellites, but you still don't last too long :cool:
Phillip
