thomas3120 Posted September 24, 2008 Share Posted September 24, 2008 (edited) Greetings, Just wondering what you guys think on those aftermarket dual use systems out there. I was thinking of getting an original NES. But I remember all the problems with some carts not working, having to blow air into the cart to make it work. So I was thinking of getting one that has the NES and SNES cart ports. Can you play games that use the NES lightgun and other special controllers (NES or SNES)? How is the quality of these systems? Any input appreciated t Edited September 24, 2008 by thomas3120 Quote Link to comment Share on other sites More sharing options...
+LS650 Posted September 24, 2008 Share Posted September 24, 2008 Google is your friend: I found this in 30 seconds by searching for "Nintendo dual systems -DS" http://en.wikipedia.org/wiki/FC_Twin_Video_Game_System Quote Link to comment Share on other sites More sharing options...
thomas3120 Posted September 24, 2008 Author Share Posted September 24, 2008 (edited) Thanks for the reply Is650, Actually I was wondering if anyone here maybe has one or used one and if they are any good. Thanks for the link, answered a few questions I had. t Edited September 24, 2008 by thomas3120 Quote Link to comment Share on other sites More sharing options...
+LS650 Posted September 24, 2008 Share Posted September 24, 2008 Yes, it would be good to hear comments from actual owners. I'm not huge into NES/SNES - but I could see getting a machine like this that let me play a few carts of favorites. Quote Link to comment Share on other sites More sharing options...
godslabrat Posted September 24, 2008 Share Posted September 24, 2008 Yes, it would be good to hear comments from actual owners. I'm not huge into NES/SNES - but I could see getting a machine like this that let me play a few carts of favorites. Short version: They're not bad, but they're not great. Some carts are incompatible, and the sound quality ranges from "Just a teensy bit off" to "godawful". If you're playing just a few games, I could see going for a dual system. If you're wanting to get serious, nothing can replace the real thing. Quote Link to comment Share on other sites More sharing options...
dark-aleph Posted September 25, 2008 Share Posted September 25, 2008 I've got the version that plays NES and Genesis (Mega Drive). It will run most of the Sega games with accurate graphics and sound, but the fail rate for the NES is far too high. Maybe 1 in 5 games won't even start, and some of those that do have tile glitches or sound distortion, or they don't play at constant speed. I'm not sure if my unit uses the same NES emulation chip as the NES / SNES unit, but if so I'd recommend avoiding it. Pay a little extra and get a NES toploader instead - 100% success, and none of the maintenance problems of the Mattel version of the console! Quote Link to comment Share on other sites More sharing options...
+remowilliams Posted September 25, 2008 Share Posted September 25, 2008 I've had my hands on just about every clone there is - the current leader is the RetroDuo. Quote Link to comment Share on other sites More sharing options...
Reaperman Posted September 25, 2008 Share Posted September 25, 2008 RetroDuo is the best by general consensus. And it is good, but it wasn't good enough. Certain NES games (especially konami titles) had sound problems, it's incompatible with a couple snes titles and s-vid only works in snes mode. As far as the retro duo taking accessories I can't tell you if it takes SNES accessories like the superscope, since my TV doesn't work with it anyhow. I will say that my SN programpad controller only works in snes mode--but I haven't seen any other controller incompatibilities. In short, it was close, but it wasn't quite good enough so I went back to my toaster NES, bent the connector pins to remove the 'ZIF' and disabled lockout. I also have a GN Twin, which is an updated version of the GenX console and it's *GODAWFUL*. The nes buttons (a&b) are reversed on the controller, it only uses the awful controllers it comes with (it does not take genesis controllers), NES games generally have color AND sound problems, along with the usual NES compatibility issues, so in short don't even think of buying one. In case anybody would be silly enough to ask, it has been tested with 32x and powerbase converter (both require some modifications to get them hooked up) and neither work. There is no slot for segaCD--I'm just beating a dead horse now, don't buy it. Quote Link to comment Share on other sites More sharing options...
KrazyKaiju Posted September 25, 2008 Share Posted September 25, 2008 The FC Twin is complete junk. RetroDuo seems to have the most positive reviews so far. Quote Link to comment Share on other sites More sharing options...
+remowilliams Posted September 25, 2008 Share Posted September 25, 2008 RetroDuo seems to have the most positive reviews so far. Definitely the best. The PowerPak working with it puts it that extra mile over the top. Still not for the hardcore crowd (none of the clones are really), but still very good for many folks. Quote Link to comment Share on other sites More sharing options...
Ace_1 Posted September 26, 2008 Share Posted September 26, 2008 I also have a GN Twin[...]. In case anybody would be silly enough to ask, it has been tested with 32x and powerbase converter (both require some modifications to get them hooked up) and neither work. Wrong and double-wrong. I own a Gen-X and Master System games will load, but there are several major issues: 1) D-pads don't respond in Master System mode 2) Two-Mega carts display graphical garbage 3) Four-Mega carts(After Burner, and the like) don't load at all The 32X also works just fine on the Gen-X, but it too has problems: 1) All sound output from the 32X is missing(play After Burner Complete and you'll see what I mean) 2) No way to mix video signals I'm currently trying to fix the 32X problems, as well as fix the incredibly distorted and scratchy audio coming out of the Genesis side. Once that's done, I'll have it documented. The NES side on that thing seems to be the exact same thing as the Generation NEX. Castlevania III gives the dark green screen and Rad Racer II causes a no-power situation(here's video proof of those 2(my own), as well as some other games working on the Gen-X: http://www.youtube.com/watch?v=31iD6lg8DSk - http://www.youtube.com/watch?v=rwYDPJIPfNo) With NES/Super NES 2-in-1s, unless you buy the non-jeweled FC Twin, the sound issues are done. Konami NES games HATE the RetroDuo, however. The FC Twin is better if you play a lot of Konami NES games, but it still has problems with Castlevania III(it will crash when you enter Stage 1). It's also semi-compatible with Rad Racer II. It works, it's playable, but the graphics are corrupt. Super NES is the same, pretty much, on both ends, EXCEPT the FC Twin has a major plus: you can add a Super NES lockout chip(from a cartridge, not from a Super NES system). This means all that crap going on with Nintendo SA-1 games will be a thing of the past. I actually already added a lockout chip into my FC Twin, just in case I one day buy a game containing the SA-1 co-processor. I say if you don't care about any of the games that have compatibility problems on the FC Twin, play lots of Konami NES and own any games containing the SA-1 co-processor(Super Mario RPG, for example), then get the FC Twin. If you don't play any Konami games, don't care about games containing the SA-1 co-processor and play any of the games the FC Twin has trouble with, then get a RetroDuo. Quote Link to comment Share on other sites More sharing options...
Reaperman Posted September 26, 2008 Share Posted September 26, 2008 (edited) I also have a GN Twin[...]. In case anybody would be silly enough to ask, it has been tested with 32x and powerbase converter (both require some modifications to get them hooked up) and neither work. Wrong and double-wrong. I own a Gen-X and Master System games will load, but there are several major issues: You confuse me. you're calling me wrong and confirming me correct? nevermind, I guess I don't really care. Edited September 26, 2008 by Reaperman Quote Link to comment Share on other sites More sharing options...
Ace_1 Posted September 26, 2008 Share Posted September 26, 2008 Reaperman, you had stated that they don't work at all. Unless you were trying to say the same thing as me? The way you worded it, it sounds like you're saying that neither the 32X or Master System games work at all on the GN Twin and Gen-X. Quote Link to comment Share on other sites More sharing options...
+remowilliams Posted September 26, 2008 Share Posted September 26, 2008 Konami NES games HATE the RetroDuo, however. I take it you mean audio wise. Yes it's definitely not right in that area. Some stuff sounds ok though, worst I've heard is Jackal which is just mangled. Quote Link to comment Share on other sites More sharing options...
Ace_1 Posted September 26, 2008 Share Posted September 26, 2008 (edited) I only tested Top Gun on the RetroDuo(Black/Red model), and all you hear is the bass and drums(noise/DPCM(if Top Gun even makes use of it) and Triangle). The melody(Square channels) is muffled to the point where it's nearly impossible to hear the Square channels. That's the reason why I own an FC Twin. I have A LOT of Konami games, and if I put a Gradius game(Gradius, Salamander/Life Force, Gradius II) in the NES slot and am greeted to garbled music, I'd get rid of a RetroDuo in a hurry. However, I have to find out where the FC Twin outputs its sound on the NES side, as I have to fix 2 sound problems: -The Square channels are a little too loud(Triangle and Noise are slightly overpowered, but DPCM is VERY hard to hear) -The Square channels have some kind of filtering going on. Here's what I mean: if you play Rad Racer on an NES, you'll notice that the engine sound is kinda garbled/staticky, but on the FC Twin(and RetroDuo), it's clean. I have to fix that Now, the FC Twin also has a tendency to distort DPCM, causing some garbled speech in Gradius II and Top Gun the Second Mission. Is this a flaw in the NOAC design? Edited September 26, 2008 by Ace_1 Quote Link to comment Share on other sites More sharing options...
+remowilliams Posted September 26, 2008 Share Posted September 26, 2008 I only tested Top Gun on the RetroDuo(Black/Red model), and all you hear is the bass and drums(noise/DPCM(if Top Gun even makes use of it) and Triangle). Did you combine the L/R RetroDuo outputs back into a single mono when testing? You need to do that, as the RD NES stereo is the split chip output, and does not sound correct. Same as a real 'stereo' NES mod. Quote Link to comment Share on other sites More sharing options...
Ace_1 Posted September 26, 2008 Share Posted September 26, 2008 I only tested Top Gun on the RetroDuo(Black/Red model), and all you hear is the bass and drums(noise/DPCM(if Top Gun even makes use of it) and Triangle). Did you combine the L/R RetroDuo outputs back into a single mono when testing? You need to do that, as the RD NES stereo is the split chip output, and does not sound correct. Same as a real 'stereo' NES mod. This RetroDuo seemed to be outputting in dual-mono already. I was getting the same sound on both speakers. It's one of the earlier models from around launch. Quote Link to comment Share on other sites More sharing options...
MN12BIRD Posted September 26, 2008 Share Posted September 26, 2008 There never as good as the real deal. But having two in one can be handy for some people I guess! I have a Yobo FC and did a comparison to a real NES on my youtube channel. The real NES has a cleaner video signal and more accurate sound and the YOBO like most clones doesn't work with every game. Quote Link to comment Share on other sites More sharing options...
Atariboy Posted September 27, 2008 Share Posted September 27, 2008 Retro Duals only output mono for NES titles, no need to combine the audio signals into 1 since they're both outputting identical sounds. Quote Link to comment Share on other sites More sharing options...
+remowilliams Posted September 27, 2008 Share Posted September 27, 2008 Retro Duals only output mono for NES titles Not on mine. Quote Link to comment Share on other sites More sharing options...
Atariboy Posted September 27, 2008 Share Posted September 27, 2008 (edited) Whats it doing? As far as I know, no NES titles even were programmed for stereo sound so I'm unsure how the hardware can do what your saying. I'm sure I'm wrong though, I just don't understand it. My Retro Duo doesn't do it. Edit - I see NES hardware has a total of five sound channels, so yours is actually splitting that up between the two rather than sending all 5 channels through each audio output? Edited September 27, 2008 by Atariboy Quote Link to comment Share on other sites More sharing options...
Ace_1 Posted September 27, 2008 Share Posted September 27, 2008 What it seems most RetroDuos do(and original hardware can do with a hardware mod) is split the channels like this: Square(2 channels) on one speaker, Triangle/Noise/DPCM on the other(the other 3 channels) This sometimes results is really odd sound. I had tried Donkey Kong and Top Gun on a Black/Red RetroDuo, and while Top Gun was garbled/completely distorted, Donkey Kong was perfect, with the exact same sounds coming out of both speakers. I'm assuming the later RetroDuos(this is an earlier model from approximately April) had a change in hardware in which NES audio is split between the 2 speakers on a TV. Quote Link to comment Share on other sites More sharing options...
+remowilliams Posted September 27, 2008 Share Posted September 27, 2008 What it seems most RetroDuos do(and original hardware can do with a hardware mod) is split the channels like this: Square(2 channels) on one speaker, Triangle/Noise/DPCM on the other(the other 3 channels) This sometimes results is really odd sound. Yes, that is what mine does and it is easily observable. And some stuff sounds really wrong with the audio split. Quote Link to comment Share on other sites More sharing options...
Ace_1 Posted September 28, 2008 Share Posted September 28, 2008 (edited) Since I don't own a RetroDuo, nor do I plan on owning one or modifying an NES for Stereo, I will actually record some games' music on an NES emulator to simulate the "Stereo" effect you get. I actually like it. Only tried one game so far. Now, to see if the Gradius games sound good in Stereo. Edited September 28, 2008 by Ace_1 Quote Link to comment Share on other sites More sharing options...
SRGilbert Posted September 28, 2008 Share Posted September 28, 2008 Reaperman, you had stated that they don't work at all. Unless you were trying to say the same thing as me? The way you worded it, it sounds like you're saying that neither the 32X or Master System games work at all on the GN Twin and Gen-X.If you consider non-functioning controllers in SMS mode and no sound in 32x mode as "working" then I suppose you are correct. I just don't really "get" the point of all these clones when the original hardware is just so cheap and easy to find, especially Sega Genesis! Quote Link to comment Share on other sites More sharing options...
