UNIXcoffee928 Posted November 5, 2008 Share Posted November 5, 2008 (edited) This thread is for describing methods of accurately reverse-engineering the SALLY 6502, so that it may first be described & documented on a breadboard, and then, may be used to facilitate a model that can be used in a FPGA description language. There already are 6502 FPGA implementations, please do your research first, and be careful of Intellectual Property (IP) violations. Also remember that SALLY is slightly different than a standard 6502. This idea came to life in the "Atari on a Breadboard" thread, but will be treated as a separate concept, to keep the threads from becoming distracting & cluttered. Here are the links to all related threads in this "Brute Force Initiative": - Atari on a Breadboard - POKEY on a Breadboard - ANTIC on a Breadboard - SALLY on a Breadboard - GTIA on a Breadboard - PIA on a Breadboard ========================================================= SALLY/6502 ========================================================= _________ | | | | | - | 01. Vss -| 01 40 |- 40. RST 02. RDY -| 02 39 |- 39. Ø2 03. Ø1 -| 03 38 |- 38. SO 04. IRQ -| 04 37 |- 37. Ø0 05. -| 05 36 |- 36. R/W 06. NMI -| 06 35 |- 35. HALT 07. SYNC -| 07 34 |- 34. 08. Vcc -| 08 33 |- 33. D0 09. A0 -| 09 32 |- 32. D1 10. A1 -| 10 31 |- 31. D2 11. A2 -| 11 30 |- 30. D3 12. A3 -| 12 29 |- 29. D4 13. A4 -| 13 28 |- 28. D5 14. A5 -| 14 27 |- 27. D6 15. A6 -| 15 26 |- 26. D7 16. A7 -| 16 25 |- 25. A15 17. A8 -| 17 24 |- 24. A14 18. A9 -| 18 23 |- 23. A13 19. A10 -| 19 22 |- 22. A12 20. A11 -| 20 21 |- 21. Vss |_________| | SALLY | |_________| ========================================================= SALLY (6502) (Pins run 0-20 on left & 40-21 on the right) ========================================================= 01. Vss: Ground 02. RDY: Memory ready signal 03. Ø1: Clock out (inverted Ø2) 04. IRQ: Interrupt request signal 05. 06. NMI: Non-maskable interrupt signal 07. SYNC: (unknown) 08. Vcc: +5V power 09. A0: Memory addr bus 0 10. A1: Memory addr bus 1 11. A2: Memory addr bus 2 12. A3: Memory addr bus 3 13. A4: Memory addr bus 4 14. A5: Memory addr bus 5 15. A6: Memory addr bus 6 16. A7: Memory addr bus 7 17. A8: Memory addr bus 8 18. A9: Memory addr bus 9 19. A10: Memory addr bus 10 20. A11: Memory addr bus 11 21. Vss: Ground 22. A12: Memory addr bus 12 23. A13: Memory addr bus 13 24. A14: Memory addr bus 14 25. A15: Memory addr bus 15 26. D7: Memory data bus 7 27. D6: Memory data bus 6 28. D5: Memory data bus 5 29. D4: Memory data bus 4 30. D3: Memory data bus 3 31. D2: Memory data bus 2 32. D1: Memory data bus 1 33. D0: Memory data bus 0 34. 35. HALT: Halts the CPU 36. R/W: Read/write direction 37. Ø0: Clock in 38. SO: Set Overflow flag 39. Ø2: Sync / Clock out 40. RST: Resets the CPU Welcome Aboard Edited November 5, 2008 by UNIXcoffee928 Quote Link to comment Share on other sites More sharing options...
perry_m Posted November 7, 2008 Share Posted November 7, 2008 (edited) Some C64 people discussed here: http://noname.c64.org/csdb/forums/?roomid=...;showallposts=1 a blog post here: http://www.pagetable.com/?p=39 which explains some 6502 internals not explained elsewhere. There was a link from that site to here: (in Hungarian) http://impulzus.sch.bme.hu/6502/letolt.php3 And a partial English translation: http://www.downloads.reactivemicro.com/Pub...%20Engineering/ The Hungarian site has PostScript files of a full, transistor-level reverse engineering of the 6502 chip. (edit: I found a better pdf of it here, with all pages combined:) http://www.downloads.reactivemicro.com/Pub...lectronics/CPU/ The 6502 was decapsulated and its surface photographed at high resolution. The partial English translation explains how to read the schematics back from such a photograph. There are also scans of a 286, 8255 and Pic16f84 on that site. Since this method is now publically documented, if someone could get photographs of ANTIC, POKEY and GTIA, we could probably use this method to reverse engineer them. The MAME people have been using decap photographs to extract mask ROMs http://www.mameworld.net/gurudumps/decap/index.html It says the cost for each chip is about $330. Edited November 7, 2008 by perry_m Quote Link to comment Share on other sites More sharing options...
ClausB Posted November 7, 2008 Share Posted November 7, 2008 The Hungarian site has PostScript files of a full, transistor-level reverse engineering of the 6502 chip. The 6502 was decapsulated and its surface photographed at high resolution. Cool stuff! Quote Link to comment Share on other sites More sharing options...
+Stephen Posted November 8, 2008 Share Posted November 8, 2008 wnloads.reactivemicro.com/Public/Electronics/CPU/"]http://www.downloads.reactivemicro.com/Pub...lectronics/CPU/[/url] The 6502 was decapsulated and its surface photographed at high resolution. The partial English translation explains how to read the schematics back from such a photograph. There are also scans of a 286, 8255 and Pic16f84 on that site. Since this method is now publically documented, if someone could get photographs of ANTIC, POKEY and GTIA, we could probably use this method to reverse engineer them. The MAME people have been using decap photographs to extract mask ROMs http://www.mameworld.net/gurudumps/decap/index.html It says the cost for each chip is about $330. Fascinating stuff! I have looked at the 6502 stuff. I pledge $330 to decipher any one of the LSI chips in the 8-bit line. No BS. Three more volunteers, and we are set. Stephen Anderson Quote Link to comment Share on other sites More sharing options...
jacobus Posted November 8, 2008 Share Posted November 8, 2008 Please tell me people aren't reading these by hand - surely there is an OCR derivative that would work... The 6502 was decapsulated and its surface photographed at high resolution.The partial English translation explains how to read the schematics back from such a photograph. There are also scans of a 286, 8255 and Pic16f84 on that site. Since this method is now publically documented, if someone could get photographs of ANTIC, POKEY and GTIA, we could probably use this method to reverse engineer them. The MAME people have been using decap photographs to extract mask ROMs http://www.mameworld.net/gurudumps/decap/index.html It says the cost for each chip is about $330. Quote Link to comment Share on other sites More sharing options...
UNIXcoffee928 Posted November 8, 2008 Author Share Posted November 8, 2008 Some C64 people discussed here:http://noname.c64.org/csdb/forums/?roomid=...;showallposts=1 a blog post here: http://www.pagetable.com/?p=39 which explains some 6502 internals not explained elsewhere. There was a link from that site to here: (in Hungarian) http://impulzus.sch.bme.hu/6502/letolt.php3 And a partial English translation: http://www.downloads.reactivemicro.com/Pub...%20Engineering/ The Hungarian site has PostScript files of a full, transistor-level reverse engineering of the 6502 chip. (edit: I found a better pdf of it here, with all pages combined:) http://www.downloads.reactivemicro.com/Pub...lectronics/CPU/ The 6502 was decapsulated and its surface photographed at high resolution. The partial English translation explains how to read the schematics back from such a photograph. There are also scans of a 286, 8255 and Pic16f84 on that site. Since this method is now publically documented, if someone could get photographs of ANTIC, POKEY and GTIA, we could probably use this method to reverse engineer them. The MAME people have been using decap photographs to extract mask ROMs http://www.mameworld.net/gurudumps/decap/index.html It says the cost for each chip is about $330. Wow! That's some extremely impressive stuff! It would be nice to have the ROM Dump Guru here, I love his PR & support style! If only more people were that "No-Nonsense" and displayed such a "Zero Tolerance for Jerks"... (could I be referring to a scenario involving "Cheese on a Breadboard"?... ha). Anyway, thanks for those links! Quote Link to comment Share on other sites More sharing options...
+remowilliams Posted November 8, 2008 Share Posted November 8, 2008 The MAME people have been using decap photographs to extract mask ROMs That decap process is wild! Quote Link to comment Share on other sites More sharing options...
sup8pdct Posted November 9, 2008 Share Posted November 9, 2008 Wasn't there once a project to do the entire custom chip lineup in a FPGA or something like that? Anyone know if that project has stalled? That decaping looks good. If it would help the above project, or a new one along similar lines, I would vote for it 10 times. James Quote Link to comment Share on other sites More sharing options...
re-atari Posted November 9, 2008 Share Posted November 9, 2008 This thread is for describing methods of accurately reverse-engineering the SALLY 6502, so that it may first be described & documented on a breadboard, and then, may be used to facilitate a model that can be used in a FPGA description language. A few years ago I came across http://freenet-homepage.de/dieter.02/m02.htm , where Dieter Mueller describes how he reverse engineered a 6502 using standard 74LS, eproms and an Sram. It might just be a good starting point for your efforts to recreate the 6502C. Also remember that SALLY is slightly different than a standard 6502. You can probably assess the differences between the 6502 and the 6502C by comparing the 800's (uses a standard 6502) schematics with the ones for the XL. This idea came to life in the "Atari on a Breadboard" thread, but will be treated as a separate concept, to keep the threads from becoming distracting & cluttered. To me, veroboarding an A8 only makes sense if you're planning to greatly enhance/expand the hardware (while maintaining backward compatibility), similar to Georg Braun's design of the Amiga 1000 based GB 1000. Take a look at http://www.gb97816.homepage.t-online.de/a1kboard.htm re-atari Quote Link to comment Share on other sites More sharing options...
sl0re Posted January 4, 2009 Share Posted January 4, 2009 (edited) To me, veroboarding an A8 only makes sense if you're planning to greatly enhance/expand the hardware (while maintaining backward compatibility), similar to Georg Braun's design of the Amiga 1000 based GB 1000. Take a look at http://www.gb97816.homepage.t-online.de/a1kboard.htm re-atari I agree, FPGA versions of the custom chips would not have to be run at the stock mhz. We could finally have our full 14 mhz 816 atari (or maybe even higher)... doubling up with dual pokeys, dual antics, et cetera... wouldn't be much more work. Edited January 4, 2009 by sl0re Quote Link to comment Share on other sites More sharing options...
sl0re Posted January 4, 2009 Share Posted January 4, 2009 wnloads.reactivemicro.com/Public/Electronics/CPU/"]http://www.downloads.reactivemicro.com/Pub...lectronics/CPU/[/url] The 6502 was decapsulated and its surface photographed at high resolution. The partial English translation explains how to read the schematics back from such a photograph. There are also scans of a 286, 8255 and Pic16f84 on that site. Since this method is now publically documented, if someone could get photographs of ANTIC, POKEY and GTIA, we could probably use this method to reverse engineer them. The MAME people have been using decap photographs to extract mask ROMs http://www.mameworld.net/gurudumps/decap/index.html It says the cost for each chip is about $330. Fascinating stuff! I have looked at the 6502 stuff. I pledge $330 to decipher any one of the LSI chips in the 8-bit line. No BS. Three more volunteers, and we are set. Stephen Anderson I'll pledge for Antic. Quote Link to comment Share on other sites More sharing options...
