16 pixel, double-height playfield for std_kernel
batari
I've spent a little time seeing if I can modify the standard kernel to allow a 16-pixel playfield, and I think I've done it. You can either use a 32-wide reflected playfield that fills the screen, or a 16-wide playfield that only uses the middle 16 pixels. I've also created some supporting routines. With standard RAM, you can support up to 24 rows.
There are two new constants - pfhalfwidth, and pfcenter. const pfhalfwidth=1 will enable the 16-wide playfield, and const pfcenter=1 will use the middle 16 pixels (asymmetrical) instead of 32-wide symmetrical playfield.
This isn't complete (the bB source needs changing for playfield: command, pfcolors aren't working, and a few other things.) I'll investigate updating the bB source and new executables, but for now I'll release this in case anyone finds it useful. A demo, test.bas, is included.
For now, at least until the bugs are fixed, you should place the files in the same directory as any bB programs you wish to compile, and bB will use these instead of the normal files of the same name.
pfhalfwidth.zip
Can you make a bin of your example and post it? I can't get it to work, so some of the files probably need to be plopped into the includes folder, but I don't want to screw anything up.
I don't understand the purpose of this, so it would be nice to see a working example.
Thanks.
The only real purpose would be kernel diversity, giving programmers as many options as possible VS a one-for-all solution. More focused kernels usually require less resources, freeing them for other uses. If you develop a game that only needs 16 horizintal playfield pixels, then you could use this kernel to either free up many bytes of RAM for general use, or to double vertical resolution.
I greatly appreciate that Batari is releasing a variety of kernels, but I think maybe he's opening a can of worms.
Edited by MausGames
Of course, using Superchip RAM will give you more power than this kernel. However, some may still wish to target standard bankswitching and get a little more out bB. I should say that it's not so much for double-height, but could also be used to free up some variables. For example, if you were only needed 16 pixels wide and 12 high was fine for you, 24 variables would be freed for general use.
There is a sample included with the zip file. You need to use the 10-25-08 build of bB for this sample, and presumably for this new kernel as well (though I haven't tested this.)
I should also mention that I would like others to test these files with games that don't use the specific features in the kernel and other files, and let me know if those games are adversely affected (they shouldn't be, but I haven't tested this either.)
Thanks.
Yep, you have to put those files into the includes folder. I just compiled the example with the 10-25-08 build of bB and i think i get the idea of this new kernel...
Nice stuff batari, good to see you're still improving bB! :thumbsup:
test.bas.bin
  • 2 months later...
