ndary Posted March 14, 2009 Share Posted March 14, 2009 i have few disks images in .ST format (that are 82 tracks / 10 sectors) that i would like to copy to real 3.5" disks.. 1. What tool can i use to do this on Windows XP? 2. Do i need to buy real 720k disks or can i use 1.44m disks? 3. Can i use my PC 1.44m disk standard disk drive? or do i need to set my PC bios to work at 720k mode or get a real 720k drive? any help one did this in the past? Thanks Nd Quote Link to comment Share on other sites More sharing options...
tjlazer Posted March 14, 2009 Share Posted March 14, 2009 i have few disks images in .ST format (that are 82 tracks / 10 sectors) that i would like to copy to real 3.5" disks.. 1. What tool can i use to do this on Windows XP? 2. Do i need to buy real 720k disks or can i use 1.44m disks? 3. Can i use my PC 1.44m disk standard disk drive? or do i need to set my PC bios to work at 720k mode or get a real 720k drive? any help one did this in the past? Thanks Nd Hi Nir! In the ST scene now? Cool Use this: http://members.tripod.com/~piters/atari/floimgd.html Quote Link to comment Share on other sites More sharing options...
flashjazzcat Posted March 14, 2009 Share Posted March 14, 2009 Use this: http://members.tripod.com/~piters/atari/floimgd.html I spent some time experimenting with this program this morning and I keep getting errors when writing the disk images on a 1.44MB PC drive. It doesn't matter whether I use 720K or 1.44MB disks. If I choose to format the disk during the write process, the ST thinks it's unformatted. The disks which experienced write errors without formatting will read on the ST but with numerous errors resulting in corrupted files. I assume it's all down to having just the write floppy drive in the PC. I'm glad I ordered a Satandisk. Quote Link to comment Share on other sites More sharing options...
tjlazer Posted March 14, 2009 Share Posted March 14, 2009 Don't use 1.44 disks at all. You might want to format he disks 720k first then try again. Works pretty good here for me on XP. Quote Link to comment Share on other sites More sharing options...
flashjazzcat Posted March 14, 2009 Share Posted March 14, 2009 Don't use 1.44 disks at all. You might want to format he disks 720k first then try again. Works pretty good here for me on XP. I had another go, using the format option on a 360K disk and I managed to get a bootable TOS 2.06. Quote Link to comment Share on other sites More sharing options...
Thorsten Günther Posted March 14, 2009 Share Posted March 14, 2009 Use this: http://members.tripod.com/~piters/atari/floimgd.html I spent some time experimenting with this program this morning and I keep getting errors when writing the disk images on a 1.44MB PC drive. It doesn't matter whether I use 720K or 1.44MB disks. If I choose to format the disk during the write process, the ST thinks it's unformatted. The disks which experienced write errors without formatting will read on the ST but with numerous errors resulting in corrupted files. I assume it's all down to having just the write floppy drive in the PC. I'm glad I ordered a Satandisk. This sounds very much what I experienced when I first used this program. The reason is that the sequence in which you click on the icons is very important for creating working ST disks: - first click on the disk drive icon - then choose an ST or MSA file - then check the format checkbox - then write the image to disk. Thorsten Quote Link to comment Share on other sites More sharing options...
ndary Posted March 15, 2009 Author Share Posted March 15, 2009 What i start the program i always get a message "Boot Sector read error"... does anyone knows why this happens? nd Quote Link to comment Share on other sites More sharing options...
ndary Posted March 16, 2009 Author Share Posted March 16, 2009 Here what i found so far when using the "Floppy Image program" 1. if you start the program when there is no Floppy in the drive you get an error message 'boot sector read error' 2. when using 1.44 floppies you need to cover the 2nd hole, and the writing process is faster Quote Link to comment Share on other sites More sharing options...
ggn Posted March 18, 2009 Share Posted March 18, 2009 Hi, I wrote a small guide for data transfer between ST and PC here. Hope it helps! Quote Link to comment Share on other sites More sharing options...
SofiST Posted March 20, 2009 Share Posted March 20, 2009 What i start the program i always get a message "Boot Sector read error"... does anyone knows why this happens? It happens usually with floppies formatted on ST with Fastcopy Pro. Not possible to read on PC - not even in DOS with MAKEDISK. Solution: copy such floppy on some Atari to other one, but don't use Fastcopy Pro. Then will be able to access it on PC. Quote Link to comment Share on other sites More sharing options...
Fuji-Man Posted March 20, 2009 Share Posted March 20, 2009 Nir, Have a look at this page. There is floppy patch that may help. I've had good success with the software. http://ppera.07x.net/atari/floimgd.php Fuji-Man i have few disks images in .ST format (that are 82 tracks / 10 sectors) that i would like to copy to real 3.5" disks.. 1. What tool can i use to do this on Windows XP? 2. Do i need to buy real 720k disks or can i use 1.44m disks? 3. Can i use my PC 1.44m disk standard disk drive? or do i need to set my PC bios to work at 720k mode or get a real 720k drive? any help one did this in the past? Thanks Nd Quote Link to comment Share on other sites More sharing options...
SofiST Posted March 30, 2009 Share Posted March 30, 2009 Floppy Imager for Windows XP is updated to V 1.0 : Separated info boxes for floppy and image file, easier usage, better overview. Option to save compressed MSA images. View option in ST file transfer. http://ppera.07x.net/atari/floimgd.php Quote Link to comment Share on other sites More sharing options...
Foster Posted April 7, 2009 Share Posted April 7, 2009 This is a great program! I'm happy to see its ongoing development. Thanks SofiST!! Quote Link to comment Share on other sites More sharing options...
Evidious Posted April 8, 2009 Share Posted April 8, 2009 (edited) I totally agree.This is a really great program.Thanks SofiST! Edited April 8, 2009 by Evidious Quote Link to comment Share on other sites More sharing options...
