PhantomDJ Posted July 2, 2009 Share Posted July 2, 2009 http://www.donhodges.com/donkey_kong_easter_egg.htm Donkey Kong Lays an Easter Egg By Don Hodges Posted July 1, 2009 Updated 07/01/2009 In 1983, the arcade smash hit Donkey Kong was ported to the Atari 400/800 home computer systems by Landon Dyer. It was at the time the best home computer/console port for this game. Mr. Dyer, in between pulling his hair out while working on this game, included what is known as an "Easter Egg" in the game's code. If a certain sequence of moves or scores were done correctly, the designer's initials would appear somewhere on the screen. He writes on his blog, "There’s an easter egg, but it’s totally not worth it, and I don’t remember how to bring it up anyway (something like: Die on the ’sandpile’ level with 3 lives and the score over 7,000)." The Digital Press web site has a whole section dedicated to Easter eggs, and they are even offering cash rewards to those who can find out how to trigger them. Even the Landon Dyer himself did not remember how to trigger this Easter egg in Donkey Kong for the Atari home computers. It is suggested on the Digital Press site that the initials would appear in the bonus score box. 26 years later, I am pleased to announce that I have discovered the way to trigger this long lost Easter egg. Here is how to do it: 1. Play a game and get a score of 33,000 through 33,900. This score must become the new high score. [some other scores will work as well, see below.] 2. Kill off all of your remaining lives. However, your last life must be killed off by falling too far - by walking or jumping off a girder that is too high to land safely. If the last life is killed any other way, the egg will not appear. 3. Set the game difficulty to 4 by pressing the Option button 3 times. The icon for this difficulty is a firefox. 4. Wait a few minutes, and the demo screen where Kong jumps across the screen will appear. 5. The title screen will then appear, and Landon Dyer's initials [LMD] will be at the bottom center of the screen: Other base scores that will work are 37,000 ; 73,000 ; and 77,000. The hundreds digit can be anything, as can the hundred thousands digit. It doesn't matter what difficulty the game is played on to set the high score. But to see the egg, the current difficulty must be set to 4 (firefox). Technical Details How on earth did I figure this out? I started by getting a very good emulator for the Atari system - MESS [Multiple Emulator Super System]. Once in to the game, I activated the game's debugger and did a complete disassembly of the entire 64K RAM bank. This file is over 25,000 lines long. I faced a few false starts - I first believed the initials were to appear in the bonus score box. So I looked there but found nothing. I also closely observed the input routines, so see if a special sequence of joystick moves were required. This search came up empty as well. I kept digging around and eventually discovered the subroutine for drawing text to the screen. Right after the data for the "GAME OVER" text data , I found the following: 8D3E: FE ; location code to follow 8D4F: 50 BC ; screen location #50, #BC 8D41: 16 17 0E ; "L M D" [designer's initials!] 8D44: FF ; end code It was quickly after this that I traced back to the command which would display this line. It was preceded by a test based on several factors, which were all then discovered. Each of the factors are logically ANDed to each other, and the end result has to be equal to 3 to trigger the egg. 861C: A5 D2 lda $D2 ; load number of lives 861E: 2D 01 0E and $0E01 ; mix with high score, ten thousands 8621: 2D 02 0E and $0E02 ; mix with high score, thousands 8624: 25 CB and $CB ; mix with difficulty 8626: 2D 31 0E and $0E31 ; mix with Mario's last state 8629: C9 03 cmp #$03 ; result == 3 ? 862B: D0 07 bne $8634 ; no, skip Easter egg ; Easter egg 862D: A0 3E ldy #$3E 862F: A9 8D lda #$8D ; Easter egg text location at #8D3E 8631: 20 B8 AB jsr $ABB8 ; print Easter egg to screen ; resume program 8634: ... It turns out that the number of lives is set to #FF (255 decimal, or 11111111 binary) after a game is over. This provides a starting point with all of the bits turned on. Most of the bits turn to zero with the first AND at line #861E. For the high score, since the numbers 3 and 7 both have the same lower 2 bits turned on, they both work as far as this routine is concerned. [3 = 0011 binary and 7 = 0111 binary]. The game's difficulty is counted starting at zero, so level 4 has an internal value of 3 which is needed for the correct answer. Finally, line #8626 mixes in Mario's last state. The memory location referenced (#0E31) changes based on how Mario is moving. It is set to 3 when Mario falls and dies. Comments & Conclusions Of all the game hacking that I have done, this has to be one of the most rewarding and enjoyable. I played quite a bit of this game back in the day at a friend's house. It really was the best port of Donkey Kong that could be played at home. Another puzzle solved. What will I do next with all of my spare time? Quote Link to comment Share on other sites More sharing options...
Rybags Posted July 2, 2009 Share Posted July 2, 2009 Nice find. No wonder the egg in this game remained just a rumour for so long... kinda rare circumstances to get it to trigger. Quote Link to comment Share on other sites More sharing options...
devwebcl Posted July 2, 2009 Share Posted July 2, 2009 excellent! great discovery Quote Link to comment Share on other sites More sharing options...
Tempest Posted July 2, 2009 Share Posted July 2, 2009 Wow! That has to be one of the trickiest easter eggs I've seen. Has anyone told Landon yet? Tempest Quote Link to comment Share on other sites More sharing options...
R4ngerM4n Posted July 2, 2009 Share Posted July 2, 2009 Woohoo, nice find! Quote Link to comment Share on other sites More sharing options...
+Allan Posted July 2, 2009 Share Posted July 2, 2009 Wow! That has to be one of the trickiest easter eggs I've seen. Has anyone told Landon yet? Tempest I just posted it in his blog. Allan Quote Link to comment Share on other sites More sharing options...
+Allan Posted July 2, 2009 Share Posted July 2, 2009 Does somebody want to do a Youtube video of it? Allan Quote Link to comment Share on other sites More sharing options...
Fres Posted July 2, 2009 Share Posted July 2, 2009 Nice find. It was fun trying to re-create it on my 8-bit. Interestingly, it took me about 3 or 4 times to get the score to fall within 33000-33900. Best DK port I've ever seen. Quote Link to comment Share on other sites More sharing options...
devwebcl Posted July 3, 2009 Share Posted July 3, 2009 Does somebody want to do a Youtube video of it? Allan Here it is: Quote Link to comment Share on other sites More sharing options...
tjb Posted July 3, 2009 Share Posted July 3, 2009 Very cool! Thanks for sharing this and please post any other eggs you find! tjb Quote Link to comment Share on other sites More sharing options...
Bryan Posted July 3, 2009 Share Posted July 3, 2009 I'd like to see someone figure out how to show William Robinson's name in AtariWriter. Quote Link to comment Share on other sites More sharing options...
Shannon Posted July 3, 2009 Share Posted July 3, 2009 Nice... That one memory address may make for a good rumble code in atarixlbox.. Quote Link to comment Share on other sites More sharing options...
+Allan Posted July 3, 2009 Share Posted July 3, 2009 I'd like to see someone figure out how to show William Robinson's name in AtariWriter. Maybe you should ask the guy who found it if he wants to give it a try. I'd love to see it as well. Allan Quote Link to comment Share on other sites More sharing options...
+Allan Posted July 3, 2009 Share Posted July 3, 2009 Does somebody want to do a Youtube video of it? Allan Here it is: Thanks devwebcl. You rock. Allan Quote Link to comment Share on other sites More sharing options...
landondyer Posted July 4, 2009 Share Posted July 4, 2009 (edited) Initially I was going to replace the "DONKEY KONG" title with "LANDON DYER" (same number of letters, heh) but I chickened out, and I'm not sure there was enough space in the ROM anyway. In retrospect the triggering of this was way too obscure, and the reward was paltry, but I was worried that an easy to find easter egg would cause management to get upset. So, like I said: Really hard to get, and totally not worth it. Kudos to Don for figuring this out. I hope he had fun doing it. Edited July 4, 2009 by landondyer Quote Link to comment Share on other sites More sharing options...
