imac4567 Posted July 29, 2009 Share Posted July 29, 2009 (edited) I started my portable Atari 2600 project and am wondering what I am doing wrong with my portable Atari. I have chopped it to a 4 x 4 square and wired every thing correctly I think but I can't seem to get it up and running. If anyone could take a look at the pic to see if I got anything wrong(for the people who have done it before) that would be great! BTW: Have put topic on ben heck forum but no response. -Dylan Putting Pic up in a sec Edited July 29, 2009 by imac4567 Quote Link to comment Share on other sites More sharing options...
Wickeycolumbus Posted July 29, 2009 Share Posted July 29, 2009 If you are using the vader you mention in this thread, this should be of no surprise. You should have gotten it working, then cut it into a 4x4 square Quote Link to comment Share on other sites More sharing options...
imac4567 Posted July 29, 2009 Author Share Posted July 29, 2009 (edited) If you are using the vader you mention in this thread, this should be of no surprise. You should have gotten it working, then cut it into a 4x4 square so mostly I am screwed with this board? or since it was just outside of the square(it was only 2 resistors broke) maybe I can revive this board. Edited July 29, 2009 by imac4567 Quote Link to comment Share on other sites More sharing options...
GroovyBee Posted July 29, 2009 Share Posted July 29, 2009 If you are using the vader you mention in this thread, this should be of no surprise. You should have gotten it working, then cut it into a 4x4 square so mostly I am screwed with this board? Yep! Thats the first rule of modding. Before you cut the PCB, make sure its working. Then at each stage of the mod you can test it and hopefully get it going again (if its stopped working). Quote Link to comment Share on other sites More sharing options...
imac4567 Posted July 29, 2009 Author Share Posted July 29, 2009 (edited) If you are using the vader you mention in this thread, this should be of no surprise. You should have gotten it working, then cut it into a 4x4 square so mostly I am screwed with this board? Yep! Thats the first rule of modding. Before you cut the PCB, make sure its working. Then at each stage of the mod you can test it and hopefully get it going again (if its stopped working). well I had another one that I tried with (that worked) but a capacitor broke after it was 4x4ifyed so that didn't work and I tried this one and no go I guess . Anyway I am still going through with this project but in need of a 4 switcher, so I will keep this updated after I grab hold of one. Edited July 29, 2009 by imac4567 Quote Link to comment Share on other sites More sharing options...
GroovyBee Posted July 29, 2009 Share Posted July 29, 2009 Can you not take parts off the latest 4x4 to fix the last known working one? Quote Link to comment Share on other sites More sharing options...
imac4567 Posted July 29, 2009 Author Share Posted July 29, 2009 Can you not take parts off the latest 4x4 to fix the last known working one? well I could but one is a vader(broken one) and one is a reg 4-switch so IDK if that would work or not Quote Link to comment Share on other sites More sharing options...
Wickeycolumbus Posted July 29, 2009 Share Posted July 29, 2009 Can you not take parts off the latest 4x4 to fix the last known working one? well I could but one is a vader(broken one) and one is a reg 4-switch so IDK if that would work or not I believe they are the same PCB (or at least very close). Quote Link to comment Share on other sites More sharing options...
GroovyBee Posted July 29, 2009 Share Posted July 29, 2009 You could just replace the capacitor with a new one on the 4-switcher's cut down PCB. I doubt if that was its only problem tho. Quote Link to comment Share on other sites More sharing options...
imac4567 Posted July 29, 2009 Author Share Posted July 29, 2009 Can you not take parts off the latest 4x4 to fix the last known working one? well I could but one is a vader(broken one) and one is a reg 4-switch so IDK if that would work or not I believe they are the same PCB (or at least very close). ok well I will rewire everything onto the other one including the cap. and update in a few to see if it works Quote Link to comment Share on other sites More sharing options...
roland p Posted July 29, 2009 Share Posted July 29, 2009 Where are the FPGA based portable atari 2600s? Quote Link to comment Share on other sites More sharing options...
EricDeLee Posted July 30, 2009 Share Posted July 30, 2009 check out my blog. Not really sure if I detailed much, but I was working on one. Quote Link to comment Share on other sites More sharing options...
imac4567 Posted July 30, 2009 Author Share Posted July 30, 2009 check out my blog. Not really sure if I detailed much, but I was working on one. ok I will check it out, Thanks Quote Link to comment Share on other sites More sharing options...
imac4567 Posted July 30, 2009 Author Share Posted July 30, 2009 (edited) YAY!! , I finally got video but it comes up like this: any ideas why? EDIT: NVM: it finally came up with video and works great. now I am going to start looking for a compatible tv to hook it to and case it in to. BTW: I will update every so often to tell everyone how its going. -Dylan Pics Edited July 30, 2009 by imac4567 Quote Link to comment Share on other sites More sharing options...
EricDeLee Posted July 30, 2009 Share Posted July 30, 2009 Awesome. Great job. I suppose you'll need more than that 9 volt for the tv and the atari... lol the battery thing is something that still stumps me. I can follow a guid and a how to with pictures. But I can't figure out some electronic stuff. Such a shame. Quote Link to comment Share on other sites More sharing options...
imac4567 Posted July 30, 2009 Author Share Posted July 30, 2009 Awesome. Great job. I suppose you'll need more than that 9 volt for the tv and the atari... lol the battery thing is something that still stumps me. I can follow a guid and a how to with pictures. But I can't figure out some electronic stuff. Such a shame. yea same here I have to always need pictures to really be able to get it . Anyway now im looking around for a casio ev-680 and there is only one on ebay and I hope I can get it. Will update this thread on progress! Thanks Everyone for help ! -Dylan Quote Link to comment Share on other sites More sharing options...
imac4567 Posted August 3, 2009 Author Share Posted August 3, 2009 Awesome. Great job. I suppose you'll need more than that 9 volt for the tv and the atari... lol the battery thing is something that still stumps me. I can follow a guid and a how to with pictures. But I can't figure out some electronic stuff. Such a shame. yea same here I have to always need pictures to really be able to get it . Anyway now im looking around for a casio ev-680 and there is only one on ebay and I hope I can get it. Will update this thread on progress! Thanks Everyone for help ! -Dylan Found Screen and 1W Amp for Sound buying tomorrow and when they arrive I will update. -Dylan Quote Link to comment Share on other sites More sharing options...
ATARIPITBULL Posted August 4, 2009 Share Posted August 4, 2009 I can't wait to see how it turns out and if it looks good, then i think I would like to give it a go and make one my self. Quote Link to comment Share on other sites More sharing options...
maximebeauvais Posted August 4, 2009 Share Posted August 4, 2009 wow, that's very nice. maybe one day, I will try to make one...... (I need more time on my hand !!!!!) Quote Link to comment Share on other sites More sharing options...
keilbaca Posted August 4, 2009 Share Posted August 4, 2009 Congrats on getting it up and running! I need to redo my atari in the pc, I think the 12v its always running on is making it go haywire, as the 12v is going to the pot for color, not 9v. Now the video is kinda fuzzy, unlike what it was when I was playing it about a year or so ago. It could also just be my capture card on my computer. I should test that tonight. ^_^ Quote Link to comment Share on other sites More sharing options...
imac4567 Posted August 4, 2009 Author Share Posted August 4, 2009 (edited) Congrats on getting it up and running! I need to redo my atari in the pc, I think the 12v its always running on is making it go haywire, as the 12v is going to the pot for color, not 9v. Now the video is kinda fuzzy, unlike what it was when I was playing it about a year or so ago. It could also just be my capture card on my computer. I should test that tonight. ^_^ Well at first I was at the min. of 7.5V for the regulator but that was not making anything pop up for some reason so I switched to a 9V so instead of 5 or 6 AA I could have one battery for the thing, Anyway I am working on building the case right now as I do have all the dimensions I need from the TV, Sound Amp, and Atari board. My ViaCAD is not working right now so I using illustrator and photoshop to draw it up. I will put up some pics when I get a prototype case drawn. BTW:Hope you get the pc back up and running like It should. -Dylan wow, that's very nice. maybe one day, I will try to make one...... (I need more time on my hand !!!!!) Well i am only 13 and on summer break so I still have about a month of free time left oh and it does not take too long to get it up and running(maybe about a week or two then everything else is straight forward). -Dylan Edited August 4, 2009 by imac4567 Quote Link to comment Share on other sites More sharing options...
imac4567 Posted August 5, 2009 Author Share Posted August 5, 2009 Here is a rough sketch of the case, Features will include: 2nd controller port, power adapter input, av-out, paddle button on side to give it that paddle feel, and others that are standard in atari 2600 systems. Please tell me what you think -Dylan Quote Link to comment Share on other sites More sharing options...
Vic George 2K3 Posted August 5, 2009 Share Posted August 5, 2009 Looks like the original Nintendo Gameboy in 2600 woodgrain style. Quote Link to comment Share on other sites More sharing options...
imac4567 Posted August 5, 2009 Author Share Posted August 5, 2009 Looks like the original Nintendo Gameboy in 2600 woodgrain style. Yea that was kinda what I was going for , I Plan to use the original Atari 2600 plastic to give an original atri feel but also a since of portability. It will probably look better than the one in the pic as my drawing skills on the computer are weak. I will also add a psp joystick so the control board won't be so cluttered. Quote Link to comment Share on other sites More sharing options...
mcjakeqcool Posted August 5, 2009 Share Posted August 5, 2009 No offence, but aint the portable 2600 already been invented? http://images.google.co.uk/imgres?imgurl=h...sa%3DN%26um%3D1 http://images.google.co.uk/imgres?imgurl=h...sa%3DN%26um%3D1 http://images.google.co.uk/imgres?imgurl=h...sa%3DN%26um%3D1 http://images.google.co.uk/imgres?imgurl=h...sa%3DN%26um%3D1 Seems you've been pitched to the post. Oh well, good luck! Quote Link to comment Share on other sites More sharing options...
