RMT: tripple hit and archive
samurai
Hi guys.
Voting in 6502 compo is over i think, so i am publishing my entries to it.
They are covers from amiga mods:
- thermostat7
- gary&denise
- deluxe dream
you can find them in tripple_hit.zip
Also you can find all of my RMT productions in tatqoo_all.zip (ASMA warriors go get it ;) ).
Gretz
tripple_hit.zip
tatqoo_all.zip
detecting stereo??...simple:
I assume the 2nd pokey is mapped at $D280-$D2FF:
Just disable the random generator on one of the pokeys and enable it on the other (some bit in IRQEN I think).
Then peek at RANDOM ($D20a) in both pokeys for several times. The register that's constant isn't generating random numbers and if $D28a is not constant, then you obviously have two pokeys.
ehm...i am not good in hardware low-level stuff... can someone post just the routine so i can paste it in xasm?
What a lame excuse :P
Come on, you're a coder, it's not that hard. ;)
It's something like this:
mva #DISABLE irqen
mva #ENABLE irqen+128
ldx #16
_loop
lda random
eor random
bne _exit
dex
bne _loop
lda #2 (means 2 pokeys)
bne _end
_exit
lda #1 (means 1 pokey)
_end
rts
where #ENABLE is the bit-combination to turn on the random generator, and #DISABLE is for turning it off.
However I'm not sure if it's irqen you need to write to.
Explanation:
if you have 1 pokey then:
random is turned off first, and then random is re-enabled (by mva #ENABLE irqen+128), but that's mirrored to the same register of the only one pokey. That means: random number register will change every cycle.
Then: with lda #random --> eor #random we look whether the random register is still the same after a few cyles. If it is (for 16 times) then it's a very unlikely coincidence (16 times the same value is polled) or you have a second pokey. But the loop will detect changing values so it will directly go to _exit to return a value of 1 in acc.
if you have 2 pokeys then:
random in first pokey is disabled, and in second pokey is enabled, so we expect a constant value in random (and a not constant value in random+128).
Then the checking loop will (hopefully) detect always the same value in random so there are two pokeys: the loop will continue returning 2 in acc.
April the 1st :)
You cannot freeze random generator.
But I suppose it is possible to check the stereo by using the irq:
sei
mvx #1 $d20e
dex
stx $d21e
stx $d208
loop lda $d21e
lsr @
bcc mono
inx
bne loop
stereo equ *
mono equ *
Untested (it's 3:51AM).
