New cart developers code available
karri
As there has been a few queries for how to create a real cart using the
new compiler from the cc65.org site I have uploaded all stuff needed
for this together with two example projects on
http://sipo.fi/lynxdev.html.
To make life easier these are Windows-ports of the compiler. The projects were created on Debian but should compile on Windows systems also.
Have fun,
Karri[/url]
Hello Karri,
thanks for providing that collection of links.
But unfortunately the DOIT-batchfiles don't work in a standard Windows-environment, i was able to adapt the doit.bat for the SKETCH-example, but failed to get the bigger one for the CART_TEMPLATE working (i think the DOS-commandline-character-buffer-limit is the reason for this).
Perhaps a MAKEFILE would be the better solution?
Bye!
Matthias
Actually the Debian version is easiest to install from my CVS.
CVSROOT=:pserver:anonymous@sipo.fi:/home/lynx/cvs
cvs login
(password is th6dxx)
cvs co cc65-lynx
cd cc65-lynx
sudo make -f make/gcc.mak install
(If you don't have sudo installed just do the last command as root.
If you have a vanilla Debian you may have to run
apt-get install zlib1g-dev zlib1g
before compiling the cc65-tools.
The commands above will make all tools usable to the Debian system.
cvs co cart_template
cd cart_template
make
This will produce a cart with a intro and an application called Lynx-Sketch on a cart.
Regards,
Karri
make[3]: Entering directory `cc65-lynx/libsrc/common'
vsscanf.c(25): Error: Struct/union has no field named `buf'
vsscanf.c(25): Error: Struct/union has no field named `ridx'
vsscanf.c(25): Error: Subscripted value is neither array nor pointer
vsscanf.c(27): Error: Struct/union has no field named `ridx'
vsscanf.c(37): Error: Variable `id' has unknown size
vsscanf.c(42): Error: Struct/union has no field named `fin'
vsscanf.c(42): Error: Undefined symbol: `infunc'
Even the docs compile if you get the debiandoc-sgml package.
But unfortunately my linker configuration is a bit broken with the latest version of the compiler. Before I used "wprot" as a type for read-only segments and now I need to use "ro" instead. This is in the *.cfg files.
There also seems to be a new segment called "INIT" that you need to put somewhere. It contains stuff run at "STARTUP" that may be needed later. So far I have not added this to my config file. But I try to do it for my both projects and also update the Windows binary snapshots to the same level.
Karri
hm hm. without a debian system. and anyway a have a sgml system installed... which does not like your sgml files.
... which means the exaple is not compiling anymore.
Now I have a working set of examples there again.
I had to upload Windows versions of make, cp and rm in order to get my Makefiles to work on Linux and Windows platforms.
I also had to add C:lynxbin to the Windows path and create two environment variables CC65_INC to C:lynxinclude and CC65_LIB to C:lynxlib.
When the next release for cc65.org comes out there will be a standard Windows installer and Lynx support included.
Enjoy,
Karri
As a matter of fact it seems to be there already. Once you unzip the two packets anywhere you just click on the install-program and it will install the compiler into C:Program Filescc65
But I have not checked if it also creates the two environment variables.
They should point to
CC65_INC = "C:Program Filescc65include"
CC65_LIB = "C:Program Filescc65lib"
Actually I think it is a bad idea to have spaces in your directory names.
For the people not interested in compiling stuff here is the compiled cart_template application ready to run on a real Lynx or on Handy.
Cheers,
Karri
cart.zip
First, many thanks for your work on this :)
You need sgml2html in order to compile de docs. It is included in the linuxdoc-tools package for debian, I don't know for other distributions, but it should be available in rpm somehere.
I still cannot compile it...
make[2]: Leaving directory `/home/damien/handy/karri/cart_template/sketch'
ld65: Error: lynxcart.cfg(15): Type expected
make[1]: *** [cart.lnx] Error 1
make[1]: Leaving directory `/home/damien/handy/karri/cart_template/cart'
make: *** [all] Error 2
You have to reload everything. The cart_template also.
The reason is that in cart_template/cart/lynxcart.cfg file there is type fields with the value "wprot" that were changed to "ro" in the newest release of the cc65 tools. The real official release of cc65 that includes the Lynx is not out yet, so the details keep changing on a weekly basis.
But once Uz releases the next version the things will calm down.
Anyway... This is a good taster of the new compiler.
Please also note how small carts it can produce. Just a few kbytes for the entire Lynx-Sketch cart.
Regards,
Karri
Thanks Karri for your quick answer, I updated but had to modify myself the type in the lynxcart.cfg file.
I now have the INIT problem you spoke about with sage :
ld65: Error: Missing memory area assignment for segment `INIT'
I had a look at the archive you put online and you're right, it produces a very small cart! Can't wait for the final version :)
Strange. Perhaps I did not update the server after all...
Anyway. Just copy the line in the lynxcart.cfg file for STARTUP and put
if after the startup line and rename it to INIT.
Then you add to cart/directory.s an import line
.import __INIT_SIZE__
and add __INIT_SIZE__+ to the size calculation of the first directory entry. It already includes __STARTUP_SIZE__.
Karri
Thanks Karri, it worked great :)
Another question as you are using Debian ;) : what emulator do you use? I tried sdlhandy but it doesn't work that well... So I have to try my programs under windows :(
835155[/snapback]
Actually I use the Windows version of Handy under wine. It works without
a Windows install out of the box.
There are some minor issues wit Handybug. I have to delete the user.reg files
at every startup.
Karri
PS. I just committed the cart_template in the main www.cc65.org contrib directory
using a new name lynx-cart-demo-1.0. There is also a text file describing the
functionality and how to modify/expand the software on the template.
at every startup.
Hmm... mine does NOT work... and I used the newest wine version. I know it runs under "crossover office", maybe also wineX, but normal wine is new for me.
Tschau,
Bjoern
at every startup.
Tschau,
Bjoern
836183[/snapback]
I updated my wine yesterday (Debian testing). And Handy runs ok with standard wine.
But there is a new bad thing in the new wine. My Mttty.exe cannot handle threads for my serial ports anymore.
Karri
at every startup.
Tschau,
Bjoern
836183[/snapback]
Debian testing here too and no problem under normal wine, last handy version works great.
wine --version gives me Wine 20050310.
Sage, what wine version and linux distribution do you use?
837098[/snapback]
Gentoo, Wine 20050111
Latest handy version AND a self compiled version... same error message (tries to access adress 0x0)
