Wrathchild Posted August 15, 2005 Share Posted August 15, 2005 I tried to take to original 40K BB cart image and make this work using the standard 64K XEGS model. This almost works but I believe the additional overhead in swapping in the correct bank pair means that some interrupts overrun and so the stack/bank selection gets out of control. The original cart uses a clever stack popping method of jumping to routines so that the (RTS) return restores the state of the selected banks at the time of the call. However, interspersed in the cartridge are other bank swap commands. The cart model is neat - $A000->$BFFF is fixed 8K, but $8000-$8FFF and $9000->$9FFF are independantly selectable, each having selecting one of 4 banks via access to the addresses $8FF6->$8FF9 and $9FF6->$9FF9 respectively. Anyway, the sources of where I'd got to are included if anyone wants to try and finish this. The problems to fix are: 1) When starting the game, the screen scrolls into position. At a random point the drawing stops and so only part of the level is displayed and you cannot play. Sometimes the screen will draw OK and you can play the level. 2) When music is played the sound is messed up. I'm not sure if this is a problem of the correct bank not being selected when note data is accessed, or if there is some protection in the code which corrupts the data, e.g. press 'select' to see the high-scores. Good luck, Mark BbsbXegs.zip Quote Link to comment Share on other sites More sharing options...
carmel_andrews Posted August 25, 2005 Share Posted August 25, 2005 'wrathchild' you seem to have forgotten something, if memory serves me correctly looking at the loader of the cassette version, BBSB uses the normal xl/xe bank switching to load of the first part of the code in at page cxxx (it is 'hardloaded'), the main block of code loads in a lo end of mem and is scrambled up...i.e the data loaded into ram doesn't correspond with the data held on the cassete/disk I am assuming/guessing the the BBSB cart version works pretty much the same way Quote Link to comment Share on other sites More sharing options...
Wrathchild Posted August 25, 2005 Author Share Posted August 25, 2005 No, the cart would allow you to play on 48K machine, the tape version is for a 64K machine, so simply porting that to a switchable XEGS or MegaCart, or even a flashcart would be more straightforward but would only be good for XL/XE owners, excluding the 400/800. Quote Link to comment Share on other sites More sharing options...
carmel_andrews Posted September 9, 2005 Share Posted September 9, 2005 No, the cart would allow you to play on 48K machine,the tape version is for a 64K machine, so simply porting that to a switchable XEGS or MegaCart, or even a flashcart would be more straightforward but would only be good for XL/XE owners, excluding the 400/800. 918684[/snapback] Perhaps certain cart. bank switching protection techniques cannot be defeated and you've probably come across one of them... unlucky you, i guess not even scanalyser or impersonator or the pill or the impossible would be able to defeat this technique (as these programs predated the new cart. bank switching protection techniques, the fact that these programmes did a song and dance in getting 16k programmes to work is irrelevent) Quote Link to comment Share on other sites More sharing options...
