Lunchbox11000 Posted August 17, 2005 Share Posted August 17, 2005 Does anyone know if there is a good working emulator for the 2600 for the PSP? Or a Activision or Atari compilation coming out in the near future for PSP? Quote Link to comment Share on other sites More sharing options...
dalton4life Posted August 17, 2005 Share Posted August 17, 2005 Don't know of any 200 emulators yet but there is a Kaboom game out. Quote Link to comment Share on other sites More sharing options...
Laner Posted August 22, 2005 Share Posted August 22, 2005 I was wondering the same thing... at the moment, it doesn't look like one is available. Quote Link to comment Share on other sites More sharing options...
+stephena Posted August 22, 2005 Share Posted August 22, 2005 Does anyone know if there is a good working emulator for the 2600 for the PSP? Or a Activision or Atari compilation coming out in the near future for PSP? 912989[/snapback] I can't say much about it right now, but there might be a surprise for you in a month or so Quote Link to comment Share on other sites More sharing options...
+stephena Posted August 23, 2005 Share Posted August 23, 2005 Does anyone know if there is a good working emulator for the 2600 for the PSP? Or a Activision or Atari compilation coming out in the near future for PSP? 912989[/snapback] I can't say much about it right now, but there might be a surprise for you in a month or so 916407[/snapback] OK, looks like I can say a bit more. I just received a port of Stella for the PSP, and while I can't test it, the author says it works fine. So unless anything major pops up, it looks like Stella 2.0 will have a PSP port Quote Link to comment Share on other sites More sharing options...
GodMedia Posted August 25, 2005 Share Posted August 25, 2005 Does anyone know if there is a good working emulator for the 2600 for the PSP? Or a Activision or Atari compilation coming out in the near future for PSP? 912989[/snapback] I can't say much about it right now, but there might be a surprise for you in a month or so 916407[/snapback] OK, looks like I can say a bit more. I just received a port of Stella for the PSP, and while I can't test it, the author says it works fine. So unless anything major pops up, it looks like Stella 2.0 will have a PSP port 917037[/snapback] ACK! I started a new topic just about this. Sorry. However, I have tested this and it works great. Still needs work on the d-pad controls, but analog works great. V-Sync needs fixing and speed throttling needs work, too. Overall, 80% of games are very very playable. Quote Link to comment Share on other sites More sharing options...
+stephena Posted August 25, 2005 Share Posted August 25, 2005 Does anyone know if there is a good working emulator for the 2600 for the PSP? Or a Activision or Atari compilation coming out in the near future for PSP? 912989[/snapback] I can't say much about it right now, but there might be a surprise for you in a month or so 916407[/snapback] OK, looks like I can say a bit more. I just received a port of Stella for the PSP, and while I can't test it, the author says it works fine. So unless anything major pops up, it looks like Stella 2.0 will have a PSP port 917037[/snapback] ACK! I started a new topic just about this. Sorry. However, I have tested this and it works great. Still needs work on the d-pad controls, but analog works great. V-Sync needs fixing and speed throttling needs work, too. Overall, 80% of games are very very playable. 918303[/snapback] The version you tested is not the version I'll be including in 2.0. It may in fact be illegal (in the sense of the GPL), since there's no source available. Quote Link to comment Share on other sites More sharing options...
Flojomojo Posted August 25, 2005 Share Posted August 25, 2005 OK, looks like I can say a bit more. I just received a port of Stella for the PSP, and while I can't test it, the author says it works fine. So unless anything major pops up, it looks like Stella 2.0 will have a PSP port 917037[/snapback] Commercial or homebrew? Watching the scene with mild interest in case they hack the later firmware versions ... Quote Link to comment Share on other sites More sharing options...
+stephena Posted August 25, 2005 Share Posted August 25, 2005 OK, looks like I can say a bit more. I just received a port of Stella for the PSP, and while I can't test it, the author says it works fine. So unless anything major pops up, it looks like Stella 2.0 will have a PSP port 917037[/snapback] Commercial or homebrew? Watching the scene with mild interest in case they hack the later firmware versions ... 918369[/snapback] The code will be fully GPL, as is all code in Stella. I'm currently in the process of committing the patch to CVS, and there should be a 2.0 release at the same as for the major platforms. I just didn't want to say anything until I knew the author was on board for sure. Quote Link to comment Share on other sites More sharing options...
dalton4life Posted August 26, 2005 Share Posted August 26, 2005 Kaboom didn't work (it froze) all but since there is a port already I guess it doesn't matter. This emulalor needs some work but it's still cool. Quote Link to comment Share on other sites More sharing options...
bigdcaldavis2k Posted August 26, 2005 Share Posted August 26, 2005 StellaPSP just came out. I have included a .zip. The contents of the zip file must be put in the GAMES directory of your PSP memory card. For game roms, you must go into the memory stick's root directory and make a directory named Stella. Then go in that directory and make a directory named Roms...this is where the roms will go. And most importantly...all Atari 2600 game roms you wish to use with StellaPSP must have the file extension as .a26 (roms with .bin will NOT be recognized). The easiest way to rename files from .bin to .a26 is to go into your command prompt (aka the DOS emulator) and type in "rename *.bin *.a26". StellaPSP_01.zip Quote Link to comment Share on other sites More sharing options...
+stephena Posted August 26, 2005 Share Posted August 26, 2005 StellaPSP just came out. I have included a .zip. This is what I was talking about earlier in the thread. This port is based on 1.4.2 and is not the same as the one currently in CVS. As such, many of the problems you just mentioned don't apply to the current code. I just wish the original author had contacted me before releasing this, as all it's doing is creating confusion Quote Link to comment Share on other sites More sharing options...
r3n4ud Posted August 26, 2005 Share Posted August 26, 2005 StellaPSP just came out. I have included a .zip. This is what I was talking about earlier in the thread. This port is based on 1.4.2 and is not the same as the one currently in CVS. As such, many of the problems you just mentioned don't apply to the current code. I just wish the original author had contacted me before releasing this, as all it's doing is creating confusion 919054[/snapback] Hm. Please help me understand this. There's going to be a second stella emulator for psp? Sorry, I'm slow Quote Link to comment Share on other sites More sharing options...
+stephena Posted August 26, 2005 Share Posted August 26, 2005 StellaPSP just came out. I have included a .zip. This is what I was talking about earlier in the thread. This port is based on 1.4.2 and is not the same as the one currently in CVS. As such, many of the problems you just mentioned don't apply to the current code. I just wish the original author had contacted me before releasing this, as all it's doing is creating confusion 919054[/snapback] Hm. Please help me understand this. There's going to be a second stella emulator for psp? Sorry, I'm slow 919192[/snapback] No, you're not slow; it's just that this is really confusing The author of StellaPSP 0.1 based the port on the 1.4.2 codebase. That code had several slowdowns, no rom launcher, and a very minimal internal GUI. So they worked very hard hard to add those features, and released the port. Meanwhile, another person sent me a patch for PSP support for the current CVS code (what will become Stella 2.0 in about a month or so). The current CVS version already had the slowdowns fixed, gained a ROM launcher, and has a very extensive internal GUI. So my main problem is that the first author reimplemented features we already have, and people are reporting bugs in it that don't exist in the current codebase anymore! If the first author had contacted me (or anyone on the Stella team) directly, we would have asked them to work with the second author, and greatly reduce the work they've done reimplementing stuff. As well, the first author wants to add features to the 1.4.2 branch that are already slated to be included in the 2.0 branch anyway. So long story short, there will definitely be one official PSP port of Stella, and one unofficial one. The one currently in circulation is the unofficial one. Also, I have no problem with people hacking at Stella, as long as they release the source (which the first author has done). It just seems to be a great waste of time to me ?? Quote Link to comment Share on other sites More sharing options...
bigdcaldavis2k Posted August 26, 2005 Share Posted August 26, 2005 StellaPSP just came out. I have included a .zip. This is what I was talking about earlier in the thread. This port is based on 1.4.2 and is not the same as the one currently in CVS. As such, many of the problems you just mentioned don't apply to the current code. I just wish the original author had contacted me before releasing this, as all it's doing is creating confusion 919054[/snapback] Hm. Please help me understand this. There's going to be a second stella emulator for psp? Sorry, I'm slow 919192[/snapback] No, you're not slow; it's just that this is really confusing The author of StellaPSP 0.1 based the port on the 1.4.2 codebase. That code had several slowdowns, no rom launcher, and a very minimal internal GUI. So they worked very hard hard to add those features, and released the port. Meanwhile, another person sent me a patch for PSP support for the current CVS code (what will become Stella 2.0 in about a month or so). The current CVS version already had the slowdowns fixed, gained a ROM launcher, and has a very extensive internal GUI. So my main problem is that the first author reimplemented features we already have, and people are reporting bugs in it that don't exist in the current codebase anymore! If the first author had contacted me (or anyone on the Stella team) directly, we would have asked them to work with the second author, and greatly reduce the work they've done reimplementing stuff. As well, the first author wants to add features to the 1.4.2 branch that are already slated to be included in the 2.0 branch anyway. So long story short, there will definitely be one official PSP port of Stella, and one unofficial one. The one currently in circulation is the unofficial one. Also, I have no problem with people hacking at Stella, as long as they release the source (which the first author has done). It just seems to be a great waste of time to me ?? 919207[/snapback] I noticed some not-so-good things about the first StellaPSP (the one I attached to my previous message) : poor video quality when you play PAL roms didn't find any paddle support Hopefully the next StellaPSP based on Stella 2.0 will have paddle support. Quote Link to comment Share on other sites More sharing options...
+stephena Posted August 26, 2005 Share Posted August 26, 2005 I noticed some not-so-good things about the first StellaPSP (the one I attached to my previous message) : poor video quality when you play PAL roms didn't find any paddle support Hopefully the next StellaPSP based on Stella 2.0 will have paddle support. Paddle support will require mouse emulation by the joystick/gamepad. It's not in Stella yet, but should be before the final release. As for the PAL rom issue, I'll have to pass that one to the PSP maintainer. It's kind of difficult to test when you don't have the machine. Maybe someone can donate one to me Just kidding of course. Quote Link to comment Share on other sites More sharing options...
r3n4ud Posted August 26, 2005 Share Posted August 26, 2005 stephena: thanks for making it more clear for me! guess the unofficial one will do for now Quote Link to comment Share on other sites More sharing options...
Shannon Posted August 27, 2005 Share Posted August 27, 2005 Also, I have no problem with people hacking at Stella, as long as they release the source (which the first author has done). It just seems to be a great waste of time to me ?? 919207[/snapback] Maybe a waste of time for the people involved, but in the meantime I'm in emu heaven. Cant wait till the official release so I dont have to worry about all the quirks though. It's really nice to have full speed 2600 emulation on a handheld. Quote Link to comment Share on other sites More sharing options...
Laner Posted August 29, 2005 Share Posted August 29, 2005 Seems to work with about 75% of the ROMs I throw at it... pretty cool Quote Link to comment Share on other sites More sharing options...
Shannon Posted August 30, 2005 Share Posted August 30, 2005 Silly question for stephana... But how hard would it be to modify stella so it can display documentation that is in cuttle cart form? The reason being that cuttle cart doc form is simple and with the doc conversion project it seems it'd make a great fit for psp on the go to be able to view them. Quote Link to comment Share on other sites More sharing options...
+stephena Posted August 30, 2005 Share Posted August 30, 2005 Silly question for stephana... But how hard would it be to modify stella so it can display documentation that is in cuttle cart form? The reason being that cuttle cart doc form is simple and with the doc conversion project it seems it'd make a great fit for psp on the go to be able to view them. 921291[/snapback] Never heard of this 'cuttle cart' format, but assuming it's just straight ASCII text it wouldn't be too hard to add an in-game menu/listbox containing this info. Problem is, we're scrambling to get the next release done, so it would have wait until after the 2.0 release. Quote Link to comment Share on other sites More sharing options...
Shannon Posted August 31, 2005 Share Posted August 31, 2005 Silly question for stephana... But how hard would it be to modify stella so it can display documentation that is in cuttle cart form? The reason being that cuttle cart doc form is simple and with the doc conversion project it seems it'd make a great fit for psp on the go to be able to view them. 921291[/snapback] Never heard of this 'cuttle cart' format, but assuming it's just straight ASCII text it wouldn't be too hard to add an in-game menu/listbox containing this info. Problem is, we're scrambling to get the next release done, so it would have wait until after the 2.0 release. 921421[/snapback] As far as I know it is pretty much straight ASCII but it was intended for display from an Atari 7800 (thru the cuttle cart). So it is obviously designed with small size in minde. Quote Link to comment Share on other sites More sharing options...
+stephena Posted October 4, 2005 Share Posted October 4, 2005 It seems that development on the 2.0 port of Stella for PSP has stalled somewhat. We're due for a general 2.0 release next week, but the PSP port won't be ready. I've started another thread in 2600->Emulation asking for Paypal contributions, so I can get a PSP and help the other guys finish the PSP port. I don't normally ask for contributions, and in fact have never done so since I started working on Stella in 2001. But unless I can get my hands on a PSP, I fear the PSP port may never be finished. And that would be a shame, since 2.0 brings a lot of goodies with it. Quote Link to comment Share on other sites More sharing options...
Guitardude Posted October 13, 2005 Share Posted October 13, 2005 I hope other emulator ports come out for it...I'd love a Colecovision emulator for PSP...Portable Space Fury, Time Pilot & Looping? Hell yes! Quote Link to comment Share on other sites More sharing options...
Shannon Posted October 14, 2005 Share Posted October 14, 2005 They guy who made the sms/game gear emulator was supposed to be working on colecovision emulation, but that was months ago and he has not updated it. Quote Link to comment Share on other sites More sharing options...
