ICD Multi I/O
drac030
Could you please make a few good photos of that device and send to me?
I need them to a web-based article about Multi I/O, and it seems that the board is so rare, that even photos are almost nowhere to be found - and a photo I found has very low quality. Until I found that one I even had no idea how does the MIO look like.
Wish I still had one to take pictures of. I used a 1MB MIO board a long time ago as part of a large collection of hardware I ran an Atari 8-bit BBS on. Sadly, I sold most of that hardware when going off to college in 1988. I'm hoping I can one day get my hands on a 1MB version, but I may have to settle for the 256K version. Look forward to seeing your article when it's done.
..Al
933795[/snapback]
Here are some pics. They are large files (1.2 - 1.8 MB each). I can compress them more if you want, but you said you wanted good Hi-Res.. Let me know if you need anything else.
post-6925-1127145468_thumb.jpgpost-6925-1127145548_thumb.jpgpost-6925-1127145604_thumb.jpgpost-6925-1127146118_thumb.jpg
No, these pics are just great. Thank you. As about "anything else", can you please, if possible, tell me how does this device perform as a harddisk interface? I mainly mean the I/O speed. Specifically, if you could run this program:
http://drac030.krap.pl/rwtest.arc
and tell me, what did it report, it would be great. Also, I'd like to hear more about that video port.
934499[/snapback]
Here's the results on a hard drive:
DOS writing: 14144.406 B/sek
DOS reading:14403.5164 B/sek
DOS average:14273.9884 B/sek
Do you have numbers from other devices for comparison?
Just for fun I ran it on the MIO Ramdisk and got these results:
DOS writing: 37809.2307 B/sek
DOS reading: 45197.2413 B/sek
DOS average: 41503.236 B/sek
As for the Video port, what I have heard is that an 80 column video add on board was planned, but never released.
Here's what the manual had to say:
80 Column Video Interface
The MIO has a video port on its front left side. This is for use with an optional 80 column adapter which plugs on top of the MIO circuit board. pin assignments are listed in the 80 Column Adapter Users Manual.
Edited by JR>
Yes. If you are interested, here are the numbers for an IDE disk attached to the KMK/JŻ IDE:
DOS writing: 8713.666 B/sek.
DOS reading: 36714.887 B/sek.
DOS average: 22714.276 B/sek.
Could you please yet tell me, what are the dimensions of the Multi I/O?
Edited by drac030
934922[/snapback]
That's pretty good. Why the large discrepancy between read and write speeds? Is it doing a write with verify? Are those interfaces still available for purchase?
The MyIDE (original external cart version with 3.1 drivers) is a dog by comparison:
DOS writing: 2806.680942 B/sek.
DOS reading: 2849.391304 B/sek.
DOS average: 2828.036123 B/sek.
Anybody run this on a Black Box?
The dimensions of the MIO are 9.5" X 6.25" X 1.3" (1.5" with the feet). I'll let you do the Metric conversion, my tape measure doesn't have cm.
No, this is the side effect of the 256-byte sector emulation. IDE drives have sector size fixed at 512 bytes. The firmware stores two 256-byte sectors inside one physical sector, and so while writing 256 bytes to the media it has to do a 1024-byte I/O (read 512 - replace half - write 512).
Of course, the emulation mode can be switched off. This speeds I/O up a lot. However, there is no DOS that can work with such a sector size.
Yes, there is a guy who occasionally sells them on eBay or Allegro.
Hmm, this is hardly believable. If the speed is measured correctly, the program must run for about 46 seconds (it first writes a 64k data file in four portions 16 each, and then reads it back). Maybe there's a bug in the program, but at the other hand all other figures look reasonably.
From the bad photo I had previously, I estimated the size as 25x15x2 cm, and later from your photos I corrected this estimation to 25x15x3 cm. The real dimensions you gave are 24.13x15.875x3.302 cm. So, not bad ;) Thank you again.
Edited by drac030
934990[/snapback]
Yeah, that's right. It takes almost 50 seconds to complete the test.
934990[/snapback]
934996[/snapback]
Interesting.....those numbers were using an old 2.5" laptop IDE drive. I just tried again using a Compact Flash card instead of the drive and got much more respectable numbers:
DOS writing: 15855.4838 B/sek.
DOS reading: 12288 B/sek.
DOS average: 14071.7419 B/sek.
Yes, that's very interesting indeed. What is the type of that "slow" IDE drive?
935047[/snapback]
That particular drive wa a Toshiba HDD2339 - 262 MB 2.5" drive. I have since tried a couple of other IDE drives and all have given results from around 2800 up to about 7500. So far only the CF card yeilds decent results on this test, although in actual use I don't really notice a large difference in performance between the CF and IDE drive.
Perhaps this is a question of LBA mode availability. CF cards AFAIK all have LBA, some hard drives don't. If the drive does not support LBA and CHS routines in MyIDE are extremely slow, then it may result in significant performance loss, I guess.
Edited by drac030
  • 1 month later...
Here are the results for the Black Box (3-1/2" Conner SCSI drive)
Dos Writing 7110.5967
Dos Reading 20373.8859
Dos Average 13742.2413
I can add a little about the video port, based on a call to ICD around 1987 or so. The 80-column TTL RGB video was completely designed, and the firmware revisons written, but ICD believed there was not a significant market for the 80-column feature. I can't remember if this was before or after Atari finally released the XEP80. But ICD saw added cost, with little or no added revenue, so it was economically not feasible. Neither of my MIO's have the video port, although IIRC, at least one has an area stenciled on the board for the video components.
-Larry
Well,
does anyone have some software for the MIO ?!? I mean original software (drivers and such) by ICD and/or PD software ... ?!? If so, please send me a copy...  greetings and thanks - Andreas Magenheimer.
961168[/snapback]
Did you just buy this off ebay?
If not, maybe you could contact this buyer. It looks like he will have the original disk to copy from. I was going to bid on it until it hit the stratosphere. :sad:
