TROGDOR Posted December 18, 2005 Share Posted December 18, 2005 (edited) I've always wondered why there was never a good port of Star Castle to the 2600. The closest thing that I'm aware of is Yar's Revenge. However, I didn't like how the fortress scrolled in Yar's Revenge, and I'd like to see something that more closely matches the look and feel of the original. So, I present version 0.01 of Stellar Fortress. New Features in this version: - First demo release. - Displays 3 ring fortress in the center of the screen, using mirrored dynamic PF graphics. - Shield is stored in 28 bytes of RAM, so holes can be poked in the shield. - The outer ring of the shield rotates. - The ring color plusates. Next to do: - Get the interrior 2 rings rotating. - Add a player ship and the fortress cannon. - Write a kernal that can handle a dynamic PF. Commercially, I can understand why Yar's Revenge used such a simple scrolling system for the blocks of their fortress. They just used a series of RORs, which requires a trivial amount of code. Below you'll see the code required just to rotate the outer ring in Stellar Fortress. It will get harrier when I add the two center rings. Below the code, you'll find the 4k binary attachment. FYI, I'm still working on Battle of Midway. This is just another game that I've always wanted to do. TROGDOR RotateShield LDA Frame AND #%00000111; Rotate the shield only on this multiple. BNE ScanWait LDX #13 CopyShield0 ; This can be removed when all the rotate code is done correctly. LDA LShield,X STA LShTemp,X LDA RShield,X STA RShTemp,X DEX BPL CopyShield0 LDA LShield+13 ASL STA LShTemp+13 LDA LShield+12 BEQ NoBit2 INC LShTemp+13 INC LShTemp+13 NoBit2 LDA RShield+13 ROR AND #%11111110; Always clear the far right bit. STA RShTemp+13 LDX #11 ShiftLeftUp LDA LShield,X AND #%00000010 BEQ NoBit0 LDA LShield+1,X ORA #%00000010 BNE WriteOut0; Careful. The ORA always has a non-zero result. This is a BRA. NoBit0 LDA LShield+1,X AND #%11111101 WriteOut0 STA LShTemp+1,X DEX BPL ShiftLeftUp LDX #13 ShiftRightDown LDA RShield,X AND #%00000010 BEQ NoBit3 LDA RShield-1,X ORA #%00000010 BNE WriteOut1; Careful. The ORA always has a non-zero result. This is a BRA. NoBit3 LDA RShield-1,X AND #%11111101 WriteOut1 STA RShTemp-1,X DEX BNE ShiftRightDown LDA RShield ASL STA RShTemp LDA LShield ROR AND #%11111110; Always clear the far left bit. STA LShTemp LDA RShield+1 AND #%00000010 BEQ NoBit1 INC RShTemp INC RShTemp NoBit1 LDX #13 CopyShield1 LDA LShTemp,X STA LShield,X LDA RShTemp,X STA RShield,X DEX BPL CopyShield1 SF01.BIN Edited December 18, 2005 by TROGDOR Quote Link to comment Share on other sites More sharing options...
gambler172 Posted December 18, 2005 Share Posted December 18, 2005 Hi looks nice.Want to see more. greetings Gambler172 Quote Link to comment Share on other sites More sharing options...
Thomas Jentzsch Posted December 18, 2005 Share Posted December 18, 2005 386 scanlines Quote Link to comment Share on other sites More sharing options...
TROGDOR Posted December 20, 2005 Author Share Posted December 20, 2005 386 scanlines 984897[/snapback] Oops. Surely you're not suggesting I should check my scanline count before posting a demo??? V0.02 New in this release: - Cleaned up the Vblank, display, and overscan timers so exactly 262 scanlines are used. - Added a low pulsing sound in unison with the shield visual pulse. This will either add an ominious feeling to the game, or be really annoying. To do: - The original game required 2 shots per shield section to destroy it. Since this is impractical given the color constraints of the 2600, I'll probably just add more single shot shield rings. I'm thinking 6 rings should work. SF02.BIN Quote Link to comment Share on other sites More sharing options...
ZylonBane Posted December 22, 2005 Share Posted December 22, 2005 I've always wondered why there was never a good port of Star Castle to the 2600. Because the 2600 only has the graphical capability to do a BAD port of Star Castle. Which is exactly why we got Yars' Revenge instead. Quote Link to comment Share on other sites More sharing options...
Vic George 2K3 Posted December 22, 2005 Share Posted December 22, 2005 I've always wondered why there was never a good port of Star Castle to the 2600. Because the 2600 only has the graphical capability to do a BAD port of Star Castle. Which is exactly why we got Yars' Revenge instead. 987065[/snapback] O ye of little faith! Quote Link to comment Share on other sites More sharing options...
NovaXpress Posted December 27, 2005 Share Posted December 27, 2005 If it only takes one shot to break a shield, that would be too easy. With 5 or 6 rings there wouldn't be much room left for the rest of the playfield. Did anyone else get bored with the original Star Castle after you discovered the warping trick? The only way to get the high scores is to cozy up to the side of the screen and tap thrust, turn around, fire, repeat as needed. Not much variety. Quote Link to comment Share on other sites More sharing options...
TROGDOR Posted December 29, 2005 Author Share Posted December 29, 2005 (edited) If it only takes one shot to break a shield, that would be too easy. With 5 or 6 rings there wouldn't be much room left for the rest of the playfield. Did anyone else get bored with the original Star Castle after you discovered the warping trick? The only way to get the high scores is to cozy up to the side of the screen and tap thrust, turn around, fire, repeat as needed. Not much variety. 989909[/snapback] Not necessarily so. The latest version has 5 rings, and there's still plenty of playfield left. I will probably add a 6th ring, for the higher levels. It will make the game harder, but that's the idea. As for the side screen technique, I'm aware of it. At higher levels, the AI just might become aware of it, too. Seriously, my plan is to increase the difficultly each level, so you're always challenged. This won't be like pacman, where you can get one million plus points and play indefinitely. Eventually, the game will beat you. It's just a question of how far you can get. For example, if you make it to level 10, touching the shield will be fatal. You won't find that in the original. Because the 2600 only has the graphical capability to do a BAD port of Star Castle. Heh. I'll bet my big beefy arm you're wrong on that one. The main objective of 2600 ports is to create a fun game. My game won't look exactly like the original, but it will have the same feel, and I will make sure it's fun to play. FYI, all future posts on this game will be in my blog, here. Edited December 29, 2005 by TROGDOR Quote Link to comment Share on other sites More sharing options...
vdub_bobby Posted December 30, 2005 Share Posted December 30, 2005 Heh. I'll bet my big beefy arm you're wrong on that one. Quote Link to comment Share on other sites More sharing options...
