Heaven/TQA Posted May 14, 2006 Share Posted May 14, 2006 hi guys, attachted a wip build of vulcano 1k (whirlwind 2006). i just played around with sound. can you please give me your feedback if the sound is too disturbing or is it fitting to the game? it should put the player into stress... the score routines is in place (see the changes in the score) but not the mechanics as the scoring is not ironed out yet. further you can move the shitty car from left to right but this gfx is just a simple place holder and will be multicolour same as the small man which will be animated somehow as well... havent tried the game on real machine yet just atari800win... the interesting thing is that in PAL more stones are falling down than in NTSC mode... vulcano.zip Quote Link to comment Share on other sites More sharing options...
Rybags Posted May 14, 2006 Share Posted May 14, 2006 The sound is too annoying. Why are the rainbow colours moving? That effect is a bit annoying too. The ambulance doesn't move with diagonals. A cheap way to cope with that is to just use the PTRIG (0,1) shadows for l/r movement - the OS routine saves you needing tables, masks or bitshifts which might save you some valuable bytes. Quote Link to comment Share on other sites More sharing options...
Heaven/TQA Posted May 14, 2006 Author Share Posted May 14, 2006 thanks for feedback. the rainbow colours are interlacing and producing 16 colours for the background. it will not be noticable on real machine but even in atari800win fullscreen mode you should get the interlace fx. OS is completly switched off to have full processor power + zero page. joystick routines. diagonals will be implemented in the next release as i am using the routine from Boinxx & Venus. so... what to do with the sounds? i was thinking as well about a "asteroid" or "centipede"-like background msx which gets faster while you are playing... would this be better? Quote Link to comment Share on other sites More sharing options...
Heaven/TQA Posted May 21, 2006 Author Share Posted May 21, 2006 small update. - joystick routine changed. should be easier now to navigate - 1st collision implemented. drive to the man, pick him up and move back. - timebar included. it does nothing at the moment but moves slowly - sound disabled Quote Link to comment Share on other sites More sharing options...
Heaven/TQA Posted May 21, 2006 Author Share Posted May 21, 2006 small update. - joystick routine changed. should be easier now to navigate - 1st collision implemented. drive to the man, pick him up and move back. - timebar included. it does nothing at the moment but moves slowly - sound disabled the sprites are still mono-colours but will be coloured via rasterinterrupts. dont worry about the 1k size... i waste a lot of space. i will squeeze gfx and data/code when the game is finished... vulcano.zip Quote Link to comment Share on other sites More sharing options...
Heaven/TQA Posted May 21, 2006 Author Share Posted May 21, 2006 on PAL TV set the flicker of the background is not noticeable. so try to run atari800win in fullscreen to minimize the flickering. Quote Link to comment Share on other sites More sharing options...
Rybags Posted May 21, 2006 Share Posted May 21, 2006 Still not a fan of that moving rainbow effect. I assume the rocks will destroy man / ambulance? Possible ideas: Maybe have a time penalty + damage when a rock hits ambulance? Have score for rescuing man increase for consecutive rescues, but reset when 1 is missed. Have the man appear in random positions. Have the drop-off point appear randomly at left or right of screen. Quote Link to comment Share on other sites More sharing options...
Heaven/TQA Posted May 21, 2006 Author Share Posted May 21, 2006 rybags... the collision detection car/rock will be next. time penalty/bonus score will be implemented that's for what the time bar is used for. i thought when the rock hits the ambulance the game is over... or how do you think the player could miss the man? i like the idea of "combo points" but don't get it how can i miss... maybe you ment that i have picked up the man but could not rescue him? Quote Link to comment Share on other sites More sharing options...
Heaven/TQA Posted May 21, 2006 Author Share Posted May 21, 2006 new build. - level tables included (how many men do you have to rescue for next level, drop rate of asteroids, score). the tables are not optimised yet - collision of car/asteroid enabled so now you can play it. press start to start a game each time you hit an asteroid. vulcano.zip Quote Link to comment Share on other sites More sharing options...
Rybags Posted May 21, 2006 Share Posted May 21, 2006 Miss a man = a rock hits him first. Quote Link to comment Share on other sites More sharing options...
+Stephen Posted May 22, 2006 Share Posted May 22, 2006 Looks cool so far - it works fine on my NTSC machine, and there is no flicker. The rainbow background is stable. Stephen Anderson Quote Link to comment Share on other sites More sharing options...
vdub_bobby Posted May 22, 2006 Share Posted May 22, 2006 Like it, very colorful and pretty for a 1K game, but needs to either start harder or get harder quicker. Too easy! Quote Link to comment Share on other sites More sharing options...
Heaven/TQA Posted May 22, 2006 Author Share Posted May 22, 2006 here is the level table... you can find it at $4800ff (after the display list9... so you can enter monitor by hitting F8 and play around with the values. restart with "cont". ;***** level data (1-10) mantab dta 2,4,6,10,14,18,26,34,42,50 scoretab dta 2,2,2,4,4,4,8,8,8,10 ;*100 ;NTSC tab * 60, PAL * 50 timetabl dta <360,<480,<540,<600,<850,<1080,<1320,<1560,<1680,<1800 timetabh dta >360,>480,>540,>600,>850,>1080,>1320,>1560,>1680,>1800 nexttab dta 120,60,40,30,25,20,15,10,9,8 Quote Link to comment Share on other sites More sharing options...
Heaven/TQA Posted May 22, 2006 Author Share Posted May 22, 2006 the drop rate of the asteroids is "nexttab". how many VBLs to wait for releasing a new one. scoretab is the bonus you get for rescuing man, mantab how many men you have to rescue for next level... timetabl,h is not working yet... it should become the values for the time out bar... so how much time you have for rescue one man... Quote Link to comment Share on other sites More sharing options...
Heaven/TQA Posted May 22, 2006 Author Share Posted May 22, 2006 check out this version... i changed some parameters... should be harder now... btw... packed i am 158 bytes over... hmmm.... it seems i should now keep an eye on file size... vulcano.zip Quote Link to comment Share on other sites More sharing options...
Heaven/TQA Posted May 23, 2006 Author Share Posted May 23, 2006 hmm.... i went through the source code and at the moment i can not see any big improvements to save memory.... the preshifted asteroids in the source code should be packed well by Flashpack2.1 but i am not sure... i'll test it with own preshift routines... then i see improvments when using a "general init routine" which initialises the zeropage/antic/gtia via tables and not with lda,sta... any more ideas? ;***** Vulcano 1K ;***** for Minigame Compo 2006 ;***** written by Heaven/TQA ;***** start: 06/05/07 ;**** to do's ;**** 1. title screen ;**** 2. car sprite ;**** 3. man sprite - done ;**** 4. game logic ;**** 5. music/jingles ;**** 6. pal/ntsc vram equ $6000 sprites equ $5000 p0 equ $5400 p1 equ $5500 p2 equ $5600 p3 equ $5700 font equ $8000 wsync equ $d40a vcount equ $d40b dliv equ $200 dlistv equ $d402 soundf0 equ $d200 soundc0 equ $d201 soundctl equ $d208 hitclr equ $d01e colp0pl equ $d00c colp0pf equ $d004 ;***** zeropage vbl_flag equ 0 ;will be decremented each VBL var1 equ 1 interlace equ 3 ;flag to delay DLI every 2nd VBL var2 equ 4 flash_counter equ 6 ;counter for switching on the lights scr_pointer equ 7 save_a equ 9 save_x equ 10 save_y equ 11 next_stone equ 12 ;counter when next appears start_kernel equ 13 level equ 14 ;level score equ 15 ;15-17 in BCD stick0 equ 18 car_pos_x equ 19 ;car screen position car_dir equ 20 ;***** sirene vars siren_delay equ 21 siren_mode equ 22 siren_freq equ 23 ;timer timer_pos equ 24 ;16 bit timer_add equ 26 ;16 bit pickup_flag equ 28 next_level equ 29 ;how many men to pick up skyv equ 30 end_flag equ 32 org $4000 start jsr set_skyscraper font_copy ldx #0 font_copy_loop lda $e080,x sta font+48*8,x inx cpx #80 bne font_copy_loop jsr switch_off_os_rom jsr wait_vbl jsr pm_init mva #$80 $d409 mva #62 $d400 mwa #dlist dlistv mva #4 $d016 mva #8 $d017 mva #2 $d019 start_game lda 53279 cmp #6 bne start_game mva #0 interlace sta score sta score+1 sta score+2 sta level sta end_flag sta car_dir jsr write_score mva #8 var1 sta hitclr mva #$30 car_pos_x main ldx level lda timetabl,x sta timer_add lda timetabh,x sta timer_add+1 lda mantab,x sta next_level ;loop99 jmp loop99 mva #0 start_kernel loop lda start_kernel beq loop mva #0 start_kernel jsr kernel lda next_stone bne loop loop3 lda 53770 and #31 tax lda vram+4,x bne loop3 lda #3 sta vram+4,x lda #12 sta vram+44,x ldx level lda nexttab,x sta next_stone lda end_flag bne endgame lda next_level bne loop inc level jsr set_skyscraper jmp main endgame jmp start_game dli pha lda var1 sta wsync sta $d01a lda #15 sta $d016 lda #<dli1 sta dliv lda #>dli1 sta dliv+1 pla rti ;**** rasterinterrupt for the main game screen dli1 pha txa pha tya pha ldy #8 lda interlace ;check for interlace and delay one scanline bne dli_loop :6 sta wsync dli_loop lda var1 tax add #$f0 sta var1 :12 sta wsync sta $d01a stx wsync stx $d01a sta wsync sta $d01a dey bne dli_loop mva #$a8 wsync sta $d01a sta start_kernel pla tay pla tax pla rti wait_vbl lda #1 sta vbl_flag wait_vbl_loop lda vbl_flag bne wait_vbl_loop rts ;***** main-kernel ;***** runs through vram and moves meteors down ;***** and turn on/off the lights in the skyscrapers kernel ldx #24 mwa #vram scr_pointer kernel_loop ldy #39 kernel_loop1 lda (scr_pointer),y beq kernel_loop2 ;skip if its the sky bmi kernel_loop2 ;skip if its a skyscraper (char>128) add #1 cmp #11 ;maximum reached? then move sprite down bne kernel_loop4 lda #0 sta (scr_pointer),y ;whipe top of sprite sty save_y tya add #80 tay lda (scr_pointer),y bpl kernel_loop5 ;hit skyscraper? trigger sound lda #0 sta (scr_pointer),y tya sub #40 tay lda #0 sta (scr_pointer),y kernel_loop99 beq kernel_loop4 kernel_loop5 tya sub #40 tay lda #3 kernel_loop6 sta (scr_pointer),y tya add #40 tay lda #12 sta (scr_pointer),y ldy save_y bne kernel_loop2 kernel_loop4 sta (scr_pointer),y kernel_loop2 dey bne kernel_loop1 lda scr_pointer add #40 sta scr_pointer bcc kernel_loop3 inc scr_pointer+1 kernel_loop3 dex bne kernel_loop rts ;***** init pm-grafics pm_init ldx #0 txa pm_init_loop0 sta p0,x sta p0+256,x sta p0+512,x sta p0+768,x inx bne pm_init_loop0 stx 53257 stx 53258 stx 53259 lda #$c0 pm_init_loop2 sta p0+256+$20,x inx cpx #176 bcc pm_init_loop2 lda #192 sta 53251 lda #15 sta $d015 sta $d012 lda #$34 sta $d013 lda #48 sta 53248 sta car_pos_x sta 53249 lda #3 sta 53277 lda #1 sta 53256 lda #>sprites sta 54279 set_car ldy #0 ldx car_dir ;which car sprite? 0,11 ofset pm_init_loop1 lda car_r,x sta p0+217,y iny inx cpy #10 bcc pm_init_loop1 rts set_man ldy #0 ldx #0 set_man_loop lda sprite,x sta p3+216,y inx iny cpy #11 bcc set_man_loop rts ;***** sets the 2 skyscrapers set_skyscraper mwa #vram+80 skyv ldx #9 ;set 10 lines mva #32 var2 set_skyscraper_loop ldy #39 set_skyscraper_loop0 lda skyscraper_data,y beq set_skyscraper_loop3 ;space? lda 53770 and #1 add #160 set_skyscraper_loop3 sta (skyv),y- bpl set_skyscraper_loop0 lda skyv ;move screen pointer one line down add #40 sta skyv bcc set_skyscraper_loop1 inc skyv+1 set_skyscraper_loop1 dex bne set_skyscraper_loop rts ;***** Add A to a BCD number add_score sed clc _bcdc adc score,x sta score,x add_score2 lda #$00 inx bcs _bcdc cld rts ;----- Write two digits BCD a to sprite at y write_bcd pha ;1st digit lsr @ lsr @ lsr @ lsr @ sty save_y ;save y-reg jsr WriteNumber pla ;2nd digit and #$0f ldy save_y iny ;next position WriteNumber clc adc #48 ;offset for font _wrlp sta status_line,y iny rts ;***** puts whole score on screen write_score ldy #3 lda score+2 jsr write_bcd ;1000-9999 lda score+1 jsr write_bcd ;100-999 lda score jsr write_bcd ;00-99 rts ;***** move car move_car jsr set_car lda end_flag bne move_car_end lda car_pos_x sta 53248 lda stick0 and #$f8 ;right? bne move_car2 lda #0 sta car_dir lda car_pos_x cmp #$c0 bcs move_car_end inc car_pos_x;move car one pixel to the right rts move_car2 lda stick0 and #244;left? bne move_car_end lda #11 sta car_dir lda car_pos_x cmp #$30 bcc move_car_end dec car_pos_x move_car_end rts ;***** time-out bar ;***** a=0 - set & init bar ;***** a<>0 - count down depending on level set_timeout_bar ldx timer_pos+1 lda #0 sta p0+256+$20,x lda timer_pos add timer_add sta timer_pos lda timer_pos+1 adc timer_add+1 sta timer_pos+1 rts ;***** checks if player hits an asteroid or ;***** if he picked up the man check_collision lda colp0pl ;checks colission with man beq check0 sta 53251 sta pickup_flag check0 lda car_pos_x;left screen reached with man? cmp #$30 bcs check1 lda pickup_flag beq check1 ldx level lda scoretab,x ldx #1 jsr add_score jsr write_score lda #0 sta pickup_flag lda #192 sta 53251 dec next_level;decress how many men to pick up for next level check1 lda colp0pf ;checks collision with asteroid beq check2 sta end_flag check2 sta hitclr ;clears collision registers rts ;----- Atari specific code switch_off_os_rom sei ;stop interrups mva #0 ^4e ;stop all interrupts mva #$fe ^31;switch off ROM to get 16k more ram mwa #nmi $fffa;new NMI handler mwa #nmi $fffe mwa #dli dliv mva #$c0 ^4e;switch on NMI+VBL again rts ; NMI routine ; ^4f==#$5f if VBLKI ; ^4f==#$9f if DLI nmi bit ^4f bpl sys_vbl ; DLI routine, e.g. ; pha jmp (dliv) ; pla ; rti ; VBL routine, e.g. sys_vbl pha txa:pha tya:pha lda $d300 ;prepare joystick and #$0f sta stick0 lda #8+$80 sta var1 lda interlace eor #1 sta interlace dec vbl_flag lda #<dli sta dliv lda #>dli sta dliv+1 jsr vbl pla:tay pla:tax pla rti vbl mva #$88 $d01a jsr check_collision jsr move_car jsr set_man jsr set_timeout_bar ; jsr sound_engine lda next_stone beq vbl0 dec next_stone vbl0 dec flash_counter bne vbl_end lda 53770 and #15 sta $d017 lda 53770 and #15 sta $d016 vbl_end rts sound_engine jsr do_siren rts do_siren dec siren_delay beq do_siren0 rts do_siren0 lda #32 sta siren_delay lda siren_mode eor #1 sta siren_mode beq do_siren1 lda #100 sta soundf0+2 lda #$af sta soundc0+2 rts do_siren1 lda #160 sta soundf0+2 lda #$af sta soundc0+2 rts org start+$800 skyscraper_data dta d" !!!!!!!! !!!!!!!! " status_line dta d"CDEPPPPPP FCDEPPPPPP" dlist dta $f0,$c6,a(status_line),$70 dta $45,a(vram) dta 5,5,5,5,5,5,5,5,5,5,5,5 dta $41,a(dlist) ;***** level data (1-10) mantab dta 2,4,6,10,14,18,26,34,42,50 scoretab dta 2,2,2,4,4,4,8,8,8,10;*100 ;NTSC tab * 60, PAL * 50 timetabl dta <360,<480,<540,<600,<850,<1080,<1320,<1560,<1680,<1800 timetabh dta >360,>480,>540,>600,>850,>1080,>1320,>1560,>1680,>1800 nexttab dta 120,40,30,20,15,12,10,9,8,7 ;**** custom font org font+$18 dta %00111100;3 dta %11111111 dta %11111111 dta %00111100 dta %00000000 dta %00000000 dta %00000000 dta %00000000 dta %00000000;4 dta %00111100 dta %11111111 dta %11111111 dta %00111100 dta %00000000 dta %00000000 dta %00000000 dta %00000000;5 dta %00000000 dta %00111100 dta %11111111 dta %11111111 dta %00111100 dta %00000000 dta %00000000 dta %00000000;6 dta %00000000 dta %00000000 dta %00111100 dta %11111111 dta %11111111 dta %00111100 dta %00000000 dta %00000000;7 dta %00000000 dta %00000000 dta %00000000 dta %00111100 dta %11111111 dta %11111111 dta %00111100 dta %00000000;8 dta %00000000 dta %00000000 dta %00000000 dta %00000000 dta %00111100 dta %11111111 dta %11111111 dta %00000000;9 dta %00000000 dta %00000000 dta %00000000 dta %00000000 dta %00000000 dta %00111100 dta %11111111 dta %00000000;10 dta %00000000 dta %00000000 dta %00000000 dta %00000000 dta %00000000 dta %00000000 dta %00111100 dta %00000000;11 (buffer) dta %00000000 dta %00000000 dta %00000000 dta %00000000 dta %00000000 dta %00000000 dta %00000000 ;2nd half dta %00000000;12 dta %00000000 dta %00000000 dta %00000000 dta %00000000 dta %00000000 dta %00000000 dta %00000000 dta %00000000;13 dta %00000000 dta %00000000 dta %00000000 dta %00000000 dta %00000000 dta %00000000 dta %00000000 dta %00000000;14 dta %00000000 dta %00000000 dta %00000000 dta %00000000 dta %00000000 dta %00000000 dta %00000000 dta %00000000;15 dta %00000000 dta %00000000 dta %00000000 dta %00000000 dta %00000000 dta %00000000 dta %00000000 dta %00111100;16 dta %00000000 dta %00000000 dta %00000000 dta %00000000 dta %00000000 dta %00000000 dta %00000000 dta %11111111;17 dta %00111100 dta %00000000 dta %00000000 dta %00000000 dta %00000000 dta %00000000 dta %00000000 dta %11111111;18 dta %11111111 dta %00111100 dta %00000000 dta %00000000 dta %00000000 dta %00000000 dta %00000000 dta %00111100;19 dta %11111111 dta %11111111 dta %00111100 dta %00000000 dta %00000000 dta %00000000 dta %00000000 org $8000+32*8 dta %11111111 ;@ dta %11010111 dta %11010111 dta %11111111 dta %11111111 dta %11101011 dta %11101011 dta %11111111 dta %11111111 ;A dta %11101011 dta %11101011 dta %11111111 dta %11111111 dta %11010111 dta %11010111 dta %11111111 dta %11111111 ;B dta %11111111 dta %11111111 dta %11111111 dta %11111111 dta %11111111 dta %11111111 dta %11111111 dta %00000000 ;C dta %11101110 dta %10001000 dta %11101000 dta %00101000 dta %00101000 dta %11101110 dta %00000000 dta %00000000 ;D dta %11101110 dta %10101010 dta %10101100 dta %10101100 dta %10101010 dta %11101010 dta %00000000 dta %00000000 ;E dta %11100000 dta %10000000 dta %11000100 dta %10000000 dta %10000100 dta %11100000 dta %00000000 dta %00000000 ;F dta %10100100 dta %10100100 dta %11100100 dta %10100100 dta %10100100 dta %10100100 dta %00000000 ;***** man sprite sprite dta %10001000 dta %11011100 dta %10011100 dta %11001000 dta %01111110 dta %00011101 dta %00011101 dta %00011100 dta %00011100 dta %00010100 dta %00110110 car_r dta %00100000 dta %11110000 dta %11110000 dta %11110000 dta %11101000 dta %11111000 dta %11111111 dta %11111111 dta %11111111 dta %01000010 dta 0 car_l dta %00000100 dta %00001111 dta %00001111 dta %00001111 dta %00010111 dta %00011111 dta %11111111 dta %11111111 dta %11111111 dta %01000010 run start Quote Link to comment Share on other sites More sharing options...
Rybags Posted May 23, 2006 Share Posted May 23, 2006 (edited) start_game lda 53279 cmp #6; change to lsr a bne start_game; change to bcs ... Saved one byte!!! I've noticed a few add/subtract ops. In cases where you know that the carry will be clear or set, you can save another byte by ADC # <number-1>,SBC # <number-1> etc. A reasonable amount of inline code there that just inits HW regs, RAM variables etc. Maybe make a subroutine that does a table lookup and does the stores. The table layout would be: .word ADDRESS .byte VALUE ADDRESS=0 means end of table. $D40E (NMIEN) always reads as $FF, so an ASL $D40E instruction would save 2 bytes each time instead of LDA #$C0 , STA $D40E. Edited May 23, 2006 by Rybags Quote Link to comment Share on other sites More sharing options...
Heaven/TQA Posted May 23, 2006 Author Share Posted May 23, 2006 huj... the lsr,bcs is cool if it works... and the asl $d40e, too... again...if it works.... Quote Link to comment Share on other sites More sharing options...
Rybags Posted May 23, 2006 Share Posted May 23, 2006 (edited) You could just LSR $D01F but it's not recommended if the OS VB routine is running since it stores 8 every VBI. By doing a LSR, you would generate a 50 Hz pulse wave through the keyboard speaker. What about the bulk-store routine? bulk_store ; on entry, X= index into address, data table ; each entry = .WORD ADDRESS ; and .BYTE DATA ldy #0 loop lda store_table,X sta $FE lda store_table+1,X sta $FF ora $FE beq finished lda store_table+1,X sta ($FE),y inx inx inx jmp loop finished rts ; ; example table ; store_table .WORD $D01A .BYTE $74 .WORD $D40E .BYTE $C0 .WORD $230 .BYTE <dlist .word $231 .byte >dlist .byte 0; end of table Using such a technique, you'd probably need about 25 or more table entries, or multiple calls to the same entries before you started saving memory. Edited May 23, 2006 by Rybags Quote Link to comment Share on other sites More sharing options...
vdub_bobby Posted May 23, 2006 Share Posted May 23, 2006 I'll take a stab at some 6502 optimization, . org $4000 start jsr set_skyscraper font_copy ldx #0 font_copy_loop lda $e080,x sta font+48*8,x inx cpx #80 bne font_copy_loop If this loop can count down you'd save two bytes here: font_copy ldx #79 font_copy_loop lda $e080,X sta font+48*8,X dex bpl font_copy_loop Next... jsr switch_off_os_rom jsr wait_vbl jsr pm_init mva #$80 $d409 mva #62 $d400 mwa #dlist dlistv mva #4 $d016 mva #8 $d017 mva #2 $d019 I think you mentioned this already, but combining all your memory/variable initialization into a loop with a table would probably save few bytes. Might be tricky since, unlike the 2600, all your RAM isn't in the zero page! start_game lda 53279 cmp #6 bne start_game mva #0 interlace sta score Could replace this with: start_game lda 53279 eor #6 bne start_game sta interlace ;assuming that the 'MVA' pseudo-op is what I think it is (lda, sta) sta score ;--etc. Saves two bytes. Learned that trick from TJ. sta score+1 sta score+2 sta level sta end_flag sta car_dir jsr write_score mva #8 var1 sta hitclr mva #$30 car_pos_x main ldx level lda timetabl,x sta timer_add lda timetabh,x sta timer_add+1 lda mantab,x sta next_level ;loop99 jmp loop99 mva #0 start_kernel loop lda start_kernel beq loop mva #0 start_kernel Am I missing something here? What is the purpose of this code (starting one line above the "loop" label)? jsr kernel Looks like this subroutine is called only once. Eliminate the 'JSR' and move the whole "kernel" subroutine inline right here; saves 4 bytes from losing the JSR call and the RTS. lda next_stone bne loop loop3 lda 53770 and #31 tax lda vram+4,x bne loop3 lda #3 sta vram+4,x lda #12 sta vram+44,x ldx level lda nexttab,x sta next_stone lda end_flag bne endgame lda next_level bne loop inc level jsr set_skyscraper jmp main endgame jmp start_game dli pha lda var1 sta wsync sta $d01a lda #15 sta $d016 lda #<dli1 sta dliv lda #>dli1 sta dliv+1 pla rti I'm not real familiar with how DLIs work, but if you put all your DLI routines in the same page* then can't you just set the high byte of dliv once and then leave it alone thereafter? Save you 5 bytes, at least, from not having to lda #imm sta dliv+1 here. *Or at least the first instruction of every DLI routine. ;**** rasterinterrupt for the main game screen dli1 pha txa pha tya pha ldy #8 lda interlace;check for interlace and delay one scanline bne dli_loop :6 sta wsync dli_loop lda var1 tax add #$f0 I assume the 'ADD' pseudo-op code translates to: clc adc #imm. If the carry is known then you can lose the CLC opcode and save a byte. Might not work here, though. Okay, that's all for now. Hope that helps. Quote Link to comment Share on other sites More sharing options...
vdub_bobby Posted May 23, 2006 Share Posted May 23, 2006 Could optimize that a little... bulk_store ; on entry, X= index into address, data table ; each entry = .WORD ADDRESS ; and .BYTE DATA ldy #0 ldx #NUMVALUES*3 ;assuming you don't have more than 85 values to initialize! loop lda store_table-3,X sta $FE lda store_table-2,X sta $FF lda store_table-1,X sta ($FE),y dex dex dex bne loop finished rts ; ; example table ; store_table .WORD $D01A .BYTE $74 .WORD $D40E .BYTE $C0 .WORD $230 .BYTE <dlist .word $231 .byte >dlist Quote Link to comment Share on other sites More sharing options...
Rybags Posted May 23, 2006 Share Posted May 23, 2006 You don't need the CMP #$80 after an INX, just a BPL will do the trick. How much filespace does the depacking routine take? For a 1K program, I would have thought you wouldn't get too much savings. Quote Link to comment Share on other sites More sharing options...
Heaven/TQA Posted May 23, 2006 Author Share Posted May 23, 2006 thanks guys... some of vdub's optimisations are knew by me (of course... ) but implemented or converted when the game is done or when it is really needed (f.e. loops counting downwards etc) but i assume that i am heading for thr 1k entry so i should try to do that... but there are some really nice tricks which i havent come over after more than 20 yeards of 6502 coding... you never finish to learn... but nobody went over THE standard 2600 optimisation... draw your players in reverse order... which again i havent yet done. so i'll go through the code now and implement some of it... in the end i am gonna put subroutines right after each others to save the JSR...and the DLI trick is correct as well... you don't need to store the highbyte if on same page... thank 800xl for his plenty of ram.... Quote Link to comment Share on other sites More sharing options...
Heaven/TQA Posted May 23, 2006 Author Share Posted May 23, 2006 rybags... the depacker needs less than 128bytes as far as i remember... so if i put in my preshifter than i probably will not need the depacker... but we will see which gives better results in the end... Quote Link to comment Share on other sites More sharing options...
Heaven/TQA Posted May 25, 2006 Author Share Posted May 25, 2006 what do you think of that lda #8 sta $d017 lsr @ sta $d016 lsr @ sta $d019 Quote Link to comment Share on other sites More sharing options...
