LS_Dracon Posted November 19, 2006 Share Posted November 19, 2006 (edited) Hi First all sorry my bad english My name is Ivan and I try to learn some months ago about 2600 programming and assembly. For test my knowledgement, I made a pong game. I think pong is simplest game to do. What's up : Move up or down, and hit the ball, the goal is 11 points. Press game reset switch to reset game anytime or press controller button to restart after "game over". There 2 games in zip, the 2 players version and VsCPU. The VsCPU are bad, I can't made a good AI. This game have a very bad optimised code But works at "high resolution". Works in Z26 and Stella emulators. EDIT : this is the first version, there a new version below AnotherPong.zip Edited November 30, 2006 by LS_Dracon Quote Link to comment Share on other sites More sharing options...
jbanes Posted November 21, 2006 Share Posted November 21, 2006 May I just take a moment to say, those are some Top Notch Graphics! You should be very proud of yourself! Gameplay-wise, it still needs a lot of tweaking before it's playable. It's a great start, but it's difficult to get that "fun" feeling. The general advice for Pong is: - Make sure the paddles are fast enough. The original game used Paddle Controllers, so you need to move the onscreen paddles quickly if you want to replicate that feel. - Hitting different spots on the paddle should spin the ball at different angles. The center should be a horizontal shot, and the outer edges should be a nearly vertical shot. - When you add different angles, remember that the ball should maintain approximately the same speed. Which means that it should go slower along the X axis while it's moving faster along the Y axis, and slower along the Y axis as it's moving faster across the X axis. - After a point is scored, there should be a pause until someone serves the ball. - Don't make the paddles too large or it will become easy to hit the ball. Keep up the good work! Quote Link to comment Share on other sites More sharing options...
LS_Dracon Posted November 22, 2006 Author Share Posted November 22, 2006 (edited) Tnx for feedback jbanes. - Make sure the paddles are fast enough. The original game used Paddle Controllers, so you need to move the onscreen paddles quickly if you want to replicate that feel. Sub Pixel movement is very complex for me at now, but I'll try increase speed if controller button is pressed. - Hitting different spots on the paddle should spin the ball at different angles. The center should be a horizontal shot, and the outer edges should be a nearly vertical shot. I understand, I will try make diferent angles - When you add different angles, remember that the ball should maintain approximately the same speed. Which means that it should go slower along the X axis while it's moving faster along the Y axis, and slower along the Y axis as it's moving faster across the X axis. I think its not possible for now... Sub pixel movement is the key - After a point is scored, there should be a pause until someone serves the ball. Yes, I forget pause... this will be done in next version. - Don't make the paddles too large or it will become easy to hit the ball. Ok, I will reduce in 4 pixels or more the sprites Also, I will try make a pattern colors for sprites, and change colors for score. I need improve the sound, the true I need make a sound, not that annoyng noise Edited November 22, 2006 by LS_Dracon Quote Link to comment Share on other sites More sharing options...
LS_Dracon Posted November 30, 2006 Author Share Posted November 30, 2006 (edited) Hi people Sorry the flood, but here's a new version. What's new ? - Diferent angles (changed by player movement, move up and ball get high angle, move down to get lower) - Double speed (hold controller button) - Pause when the point is scored - Color gradient for score numbers What's lack ? (becouse I can't ) - Angle changed by hitting player edge or other position - Sound Fx (not this noise) - Color gradient for players (I don't have space on kernal for it) - The middle vertical line (same problem as above) But this is finished, now I will make some demos, try new things before start to program my first original game. AnotherPong2.zip Edited November 30, 2006 by LS_Dracon Quote Link to comment Share on other sites More sharing options...
