Is it possible to insert different chunks of sprite data into one sprite?
3 replies to this topic
#1 Random Terrain ONLINE
Random Terrain
    Visual batari Basic User
  • 20,911 posts
  • Controlled Randomness
    Replay Value
    Nonlinear
Posted Thu May 22, 2008 7:36 PM
Thanks to SeaGtGruff, I know how to make sprites share sprite data. For example, you can have long sprite data made up of number shapes and have various sprites display any of those numbers (like you see in Tone Toy 2008). But what if you want to change certain parts of a sprite instead of the whole thing? Say you want to have Space Invader-like aliens and you create 20 top halves and 20 bottom halves that all match perfectly. Is there a way to randomly insert the top sprite data into the top of the sprite and randomly insert the bottom sprite data into the bottom part of the sprite so you never know exactly what the alien will look like? Is it possible to do it without getting flicker? Anything I try makes the two parts flicker.
Thanks.
Edited by Random Terrain, Thu May 22, 2008 7:36 PM.
#2 SeaGtGruff OFFLINE
SeaGtGruff
  • 4,543 posts
Posted Thu May 22, 2008 8:33 PM
Thanks.
Yes, there is a way-- but to do it with the default (non-customized) bB kernels, you must use RAM. If you're using the Superchip option-- no problem, you may have RAM to spare! But if you are *not* using the Superchip option-- ouch, you don't have much precious RAM to spare as it is! :)
What you need to do is (1) reserve some bytes of RAM for this purpose, such as deciding that variables a through h will be used to store an 8-line shape for player0; (2) instead of using the "player0:" statement to define player0's shape, just set the hi and lo pointers for player0 to the beginning of the RAM area; and (3) set the RAM locations to the necessary values to define the player's shape. You could also (4) use the "player0:" statement to define a long sprite that has all the different parts you want to use for the player, and then (5) change the pointers for the player so they point to the RAM location, and (6) copy the desired portions of the shape into the appropriate bytes of RAM.
My brain is kind of fried right now, so I can't post an example right away, but I actually posted an example of doing a RAM player a couple of years ago. If you search the batari Basic forum, you should be able to find it. I'll look for it and post a link, although it's just an example of how it could be done, and it doesn't utilize all of the suggestions I mentioned above.
Michael
#3 SeaGtGruff OFFLINE
SeaGtGruff
  • 4,543 posts
Posted Thu May 22, 2008 8:43 PM
Hmm, I guess it was a demo for the early Superchip stuff that I did, before Superchip support was officially added to bB, so I should probably put together a new demo. As I said, my brain is fried right now, so it won't be until this weekend that I can focus enough to do one. :ponder:
Michael
#4 Random Terrain ONLINE
Random Terrain
  • 20,911 posts
    Replay Value
    Nonlinear
Posted Thu May 22, 2008 8:54 PM
I was just looking at that too. Whenever you get a chance, that would be great. I hope to do it without Superchip and without bankswitching if I can. I might find out that it wastes too many variables, but it's worth a try. Even if I never use it in a finished game, somebody else might.
Thanks.
