0
Playfield height?
15 replies to this topic
#1 yuppicide OFFLINE
yuppicide
    I am the Black Knight. Give me your money!
  • 6,933 posts
Posted Mon Jul 28, 2008 8:30 AM
I want to make a playfield that is taller than 32x11. How do I accomplish this? Is 32x24 too much?
I've been trouble getting anything larger than 32x9 to display. It only displays the first nine lines of the playfield.
If I run the AnimatedPlayfield code snippet it displays fine. If I go do my own program it only displays the first 9 lines.
Edited by yuppicide, Mon Jul 28, 2008 8:32 AM.
#2 jwierer OFFLINE
jwierer
    Dragonstomper
  • 746 posts
Posted Mon Jul 28, 2008 8:56 AM
Try setting
const pfres=32
-Jeff
#3 yuppicide OFFLINE
yuppicide
  • 6,933 posts
Posted Mon Jul 28, 2008 9:33 AM
The Animated Playfield doesn't use that and it displays larger than 11 lines.
I tried const pfres=32, but it makes the screen all garbled and have a funky score on the bottom. I also tried enabling Superchip and it looks better, but my screen is still screwed up. I don't want to use Superchip anyway.
My code is attached to this.
Try setting
const pfres=32
-Jeff
#4 yuppicide OFFLINE
yuppicide
  • 6,933 posts
Posted Mon Jul 28, 2008 10:10 AM
What I am doing is making a box that will move in and out. I want to have it if you touch the box you die. I'm going to make it later on like the code sample so I can make it go slower and faster, but for now just wanted it to work.
#5 jwierer OFFLINE
jwierer
    Dragonstomper
  • 746 posts
Posted Mon Jul 28, 2008 12:40 PM
Looking at your code, your playfield is actually 20 pixels tall, instead try:
const pfres=21
-Jeff
Edited by jwierer, Mon Jul 28, 2008 12:43 PM.
#6 jwierer OFFLINE
jwierer
    Dragonstomper
  • 746 posts
Posted Mon Jul 28, 2008 12:42 PM
Also the effect looks a bit better if you use this setting
set kernel_options no_blank_lines
-Jeff
#7 yuppicide OFFLINE
yuppicide
  • 6,933 posts
Posted Mon Jul 28, 2008 1:52 PM
Yeah, maybe the one I uploaded is 20 high.. I've been fooling with different settings trying to get it to work. I do a pfres of 21 and it looks the best it's ever looked, but it's still all garbled for some reason.
Wow! No blank lines.. great. I never noticed that option and always wondered how people get no lines between rows.
Attached are two screenshots of the garbled output I get in Stella. It keeps r
-Jeff
#8 Impaler_26 OFFLINE
Impaler_26
    Cookie Meister
  • 2,148 posts
  • Braindead
Posted Mon Jul 28, 2008 4:27 PM
There's nothing wrong with your code.I set pfres to 21 and compiled your test-code, works fine for me.
Do you have the latest updates and bugfixes for bB? The links are here (post #134).
#9 yuppicide OFFLINE
yuppicide
  • 6,933 posts
Posted Mon Jul 28, 2008 7:57 PM
You know I did read about the latest updates/bugfixes, but totally forgot to install any. Thanks. I'll do that when I get to work tomorrow. Actually, I might just install everything at home also and fool around tonight as well.
#10 yuppicide OFFLINE
yuppicide
  • 6,933 posts
Posted Mon Jul 28, 2008 8:52 PM
I downloaded your file and it works fine. I compiled mine again (with bugfixes and pfres=21) and get garbled output again with funky score.
If I remove any pfres it'll look fine, but only display the first 9 rows of playfield.
Edited by yuppicide, Mon Jul 28, 2008 8:53 PM.
#11 jwierer OFFLINE
jwierer
    Dragonstomper
  • 746 posts
Posted Mon Jul 28, 2008 9:43 PM
You code also compiles fine for me. Definitely something with your environment. What emulator are you using?
-Jeff
#12 yuppicide OFFLINE
yuppicide
  • 6,933 posts
Posted Mon Jul 28, 2008 9:46 PM
I have the latest Stella. I followed instructions on Batari Basic website to install everything. I had Crimson Editor installed, but made the switch to Visual Batari Basic.
Maybe I should get rid of the DASM that came with bB and download full?
#13 Random Terrain ONLINE
Random Terrain
    Visual batari Basic User
  • 20,911 posts
  • Controlled Randomness
    Replay Value
    Nonlinear
Posted Mon Jul 28, 2008 10:18 PM
I didn't think we could have more rows unless we used the Multisprite Kernel:
http://www.randomter...tml#multikernel
Quote
Although the playfield is limited in many ways, the fact that it is stored in ROM is advantageous in one way. Unlike the standard kernel, you are not limited to just 11 rows — you can use up to 44 rows, and you can set the vertical resolution to suit your needs.
#14 Random Terrain ONLINE
Random Terrain
  • 20,911 posts
    Replay Value
    Nonlinear
Posted Mon Jul 28, 2008 11:43 PM
Are you sure you didn't remove this:
set romsize 8kSC
Without it, I get the same mangled mess you did, but it looks fine with it because it enables Superchip RAM. I skipped over that line when I looked at the code and didn't see that you were using Superchip RAM. No wonder you can have more rows. :dunce:
#15 yuppicide OFFLINE
yuppicide
  • 6,933 posts
Posted Tue Jul 29, 2008 6:43 AM
Yeah, what had happened at one point I had superchip but wrong pfres. Another point I had correct pfres but no superchip. It's all sorted out now.
#16 yuppicide OFFLINE
yuppicide
  • 6,933 posts
Posted Tue Jul 29, 2008 6:48 AM
Actually, know what I think my problem was originally?
Maybe this can be fixed in a future version.
having the following will compile, but give you garbled output:
 set romsize 8ksc
having the SC in capital letters compiles and works.
I was just fooling around here at work and noticed it.
Edited by yuppicide, Tue Jul 29, 2008 6:49 AM.
