Lynx 1 Repair Problem - Help Needed!
9 replies to this topic
#1 Elerach OFFLINE
Elerach
    Moonsweeper
  • 264 posts
Posted Sat Dec 6, 2008 11:34 PM
Hey everybody, I recently got a lynx, but im having some problems with it.
I have an AC adaptor, and i tried 6 batteries, but no matter what i do, i cant get it to turn on. i tired cleaning the slots, trying different games, e.t.c
But no luck...... the cart door wont close all the way but i put the carts in and they *click* like they should.
Does anybody have any suggestions on how to remedy this problem?
#2 Rybags ONLINE
Rybags
  • 10,312 posts
Posted Sat Dec 6, 2008 11:40 PM
Pull it apart. Check the solder joins for the various wires that supply power etc. Use a multimeter to check that power is getting through or not.
Try a game in it with the thing still apart.
#3 Battlezone OFFLINE
Battlezone
    Moonsweeper
  • 380 posts
Posted Sun Dec 7, 2008 12:28 AM
http://cgi.ebay.it/A...1713.m153.l1262
#4 Insert Coin OFFLINE
Insert Coin
    Space Invader
  • 12 posts
Posted Sun Dec 7, 2008 9:08 AM
Did you, by accident, plug your AC adapter into the headphones connector? Is so, you might have fried the chips and your Lynx is lost forever.
#5 Elerach OFFLINE
Elerach
    Moonsweeper
  • 264 posts
Posted Sun Dec 7, 2008 2:28 PM
I definitely did not plug the AC adaptor into the headphone jack, i know that.
i also have no idea what im looking for inside the lynx that might indicate anything is broken. i dont have a multimeter, although i can guess what it does (measures power)
I'll take some photos and post them of the insides, and maybe somebody can tell me what is wrong.
#6 Elerach OFFLINE
Elerach
    Moonsweeper
  • 264 posts
Posted Sun Dec 7, 2008 4:20 PM
Ok, here are the pics. Does anybody see anything wrong? anything unusual?
#7 MrAtari2600 OFFLINE
MrAtari2600
    Dragonstomper
  • 643 posts
Posted Sun Dec 7, 2008 4:43 PM
my lynx 1 does same thing though i know it needs that ebay item up there
From what I know it is a common issue for things like this to happen,
mine is soldered right from what I was told but the thing is it still doesn't work right
Im in your boat as well,
I hope you find out whats going on with yours,
#8 karri OFFLINE
karri
  • 1,049 posts
Posted Sun Dec 7, 2008 11:14 PM
Sounds like the old MOS-FET problem. Q12 or was it Q11 in the Lynx I. You can easily try if this is the case by connecting a wire from headphone shield (the ground in for the headphones) to battery minus. It is the job of the MOS-FET component to do this connection to turn on the Lynx. If the Lynx turns on when you put the wire there then you know where your problem is.
Karri
#9 a8maestro OFFLINE
a8maestro
    Chopper Commander
  • 161 posts
Posted Wed Jan 7, 2009 12:27 AM
Karri
My #1 repair on dead Lynxes is to resolder the three pins on the power adapter jack.
Rick D.
#10 bradjewell OFFLINE
bradjewell
    Dragonstomper
  • 916 posts
Posted Fri Jan 21, 2011 11:20 AM
Sorry for bumping a semi-ancient thread..
however, I was wondering if anyone had some of these mosfet laying around and if I could get 1 or 2 so I could fix a lynx I have that has this issue, any help would be greatly appreciated.
Regards,
Brad
Karri
