Atari800Win
6 replies to this topic
#1
    Moonsweeper
  • 310 posts
Posted Sat Jun 6, 2009 8:28 PM
I've tried both Atari800Win 4.0 and 4.1 and neither display properly in Windows 7 (I thought it was a Vista problem, too). The colors are "inverted" or just wrong no matter the settings.
Is this a known bug or do I have a bad setting somewhere? Works fine in XP...
Edited by R.Cade, Sat Jun 6, 2009 8:28 PM.
#2
    Star Raider
  • 73 posts
Posted Sun Jun 7, 2009 12:08 PM
Dunno about Atari800Win but I'm running Atari800 (http://atari800.sourceforge.net/) just fine in Windows 7 - it's still being updated too (last update was March 2009) which makes it a better fit for me than Atari800Win...
Edited by Aegis, Sun Jun 7, 2009 12:08 PM.
#3
    Moonsweeper
  • 423 posts
Posted Sun Nov 15, 2009 9:10 PM
Mabie you need to both share youre whole atari800 dir and security too all everyone then restart and mabie it will work AS sometimes i get sharing violations ..w xp
#4
    Star Raider
  • 75 posts
Posted Fri Dec 4, 2009 3:27 PM
Weird. No problems with version 4.0 on Windows 7 here.
I have had config problems with Atari800win in the past, on XP or 2000 (can't remember which), and my solution back then was to trash the entire folder and install a fresh copy.
I did notice that under the View menu, there's an option for Palette. You're able to browse to the Atari800Win folder in which there are several palette files. Not sure what if that's your culprit, and I didn't try these in case I messed up my own install, but you've got nothing to lose by trying .;)
#5
    Chopper Commander
  • 209 posts
Posted Fri Jan 7, 2011 1:09 PM
Got a new Win7 pc and was just playing around with the emus a bit. On mine, what happens with Atari800Win is that the colors look okay if you run in windowed mode, but get all messed up if you enter full screen mode. I've also found via trial and error, that if you right-click on the atari800win.exe file, select the compatibility tab, set it to emulate win xp sp2, and then check ALL of the check boxes below (256 colors, 640x480 mode, disable desktop, etc), it will then run in full screen mode with correct colors as long as the emu was in full screen mode the last time you quit out. (if you start out in windowed mode, you may have to enter full screen mode in the emu, then click the mouse pointer near the top edge to make the menus appear, quit out and then relaunch it.....at which point it should launch in full screen mode and work fine.)
#6
    Moonsweeper
  • 423 posts
Posted Tue Mar 1, 2011 11:30 PM
i forgot goto 800x600 16bit color before starting and check use agp mode also get all directx SDK from microsoft to chomp video card drivers..
windows 7 is a nother milleinuim no video card open gl or directx drivers they expect on cdrom w video card manafacture.
try downloading catalyst or detonator nvidia or ati drivers mabie it might work..
#7
    Moonsweeper
  • 423 posts
Posted Tue Mar 1, 2011 11:31 PM
use gdi for windows ? i have a older verison witch might work better
also i found a zipped version i just loaded month ago witch emulates paddles as MOUSE!! .
1 user(s) are reading this topic
0 members, 1 guests, 0 anonymous users
