The bank has loaned you $5,00 to start your own Ghostbusters franchise. Earn enough money busting ghosts before their dangerous energy emissions (PK energy) reach critical mass at 9999. Otherwise, your business will be foreclosed.
Post your scores right here in this thread, and I will add them to the list. Remember to play the game with the recommended game mode and difficulty settings as shown above so that your scores will be consistent with everyone elses. The deadline for posting scores is Wednesday July 8th at 1:00 AM (CST). |
Current High Scores
Best Tips
Challenges
TwinGalaxies Top 3
| Current Standings |
| The Manual |
| As always, you really should read the manual. In case you don't have the manual, AtariAge has a typed copy and a scanned copy available online. The manual doesn't provide any real hints, but this game is pretty advanced for an Atari game, so I highly suggest you read the manual so you know what you're doing. |
| vjames |
| It is also possible to catch the ghosts by using two parallel streams so that it's sandwiched between them (but still seems random). Forget the image enhancer and vacuum. Not enough ghosts get by to be able to give you enough time to catch more slimers. (you need both on the C64 version). I THINK you only get two baits (hit F7/F8 on stella (right difficulty switch)) to release bait. If you are driving the Marshmallow Man cannot come, so move your cursor all around the screen from about 6-7k on the pk meeter and then drive around (anywhere) the rest of the game. |
| aftermac |
| Tip: Make sure you have your first Ghostbuster on the building screen facing to the right otherwise he will fire off to the left and you can't trap the slimers. Tip: As soon as the game gets "out of control" start flipping your right difficulty switch BEFORE the Marshmallow Man appears to bait him. Tip: On the driving screen when you are going after a floater, immediately move your car to the center lane to get in a better position to catch him. If you're on the right and it appears on the left you won't have enough time to catch it. Tip: Always take the shortest route to the closest building... this will make for a shorter car trip and save a bit on the PK meter. (And you will get more money, the faster you get there and the faster you catch the ghost you will get more money. I think the max is 700-800 dollars. --vjames) |
| sloth713 |
| the best tip i can give is to not hold the ghost too tight between you beams, let the ghost bounce around a little between the beams and you will be more likely to catch it in your trap. |
--Zero
