0
Mac monitor
2 replies to this topic
#1 Walter_J-64 OFFLINE
Walter_J-64
    Chopper Commander
  • 230 posts
Posted Sat Oct 5, 2002 2:06 PM
I have starting to see a lot of them here I was thinking is there a way use Mac monitors with J-64? the monitor input port looks like PC game port
#2 Gunstar OFFLINE
Gunstar
    Gunstar
  • 6,546 posts
Posted Sat Oct 5, 2002 5:00 PM
The port shape isn't important; a cable can be made to fit. What's important is that the monitor's vertical refresh rate is 15hz or a multisync monitor that can run at either 15hz or 30hz(like newer VGA monitors-30hz). Atari ST and Amiga monitors will work, so if the Mac monitor refreshes at 15hz a cable can be made/possibly bought (try BEST Electronics) to work with the Jaguar. If you have a Catbox, that makes it easier as it has a monitor port on it like the one your describing and it may work directly or by crossing a few pin wires...
I'm about to hack together a cable to use my Jaguar with my Atari ST SC monitor I got recently with my 1040STf. It's only like a eleven or twelve inch screen (pretty small), but the clarity of the RGB is incredible with the ST and should look fantastic with the Jag attached to it!
#3 Walter_J-64 OFFLINE
Walter_J-64
    Chopper Commander
  • 230 posts
Posted Sat Oct 5, 2002 6:30 PM
Let me know if your hack works Ive have SC1224 not in use! ;)
Ill hook you up!
