amiman99 Posted August 9, 2009 Share Posted August 9, 2009 Hi, I got a 1050 disk drive w/o power supply, can someone tell me which p/s I need. Voltage, Amp, AC or DC? Can I use p/s from 1010 Tape Drive? Thanx Quote Link to comment Share on other sites More sharing options...
amiman99 Posted August 9, 2009 Author Share Posted August 9, 2009 I found this in FAQ: 9 VAC 31 VA 3.4 A Max:50W Power Adaptor Atari#C017945(unit)/CA017964(box) http://www.computerhistory.org/collections...ssion/102688424 400,800,810,822,850,1200XL,1010,1020,1050,XF551 Can any one check on their Power supply? Quote Link to comment Share on other sites More sharing options...
Rybags Posted August 9, 2009 Share Posted August 9, 2009 1010 PSU = no. PSUs for the other machines you've listed = unsure. All are 9V AC but the Amps rating on the PSUs can vary. My 400's supply is only rated at 2 Amps but my 1050 supply says 4.5 Amps. So, unsure on that one. Quote Link to comment Share on other sites More sharing options...
Crimefighter Posted August 10, 2009 Share Posted August 10, 2009 I could have sworn Atari's used the same power supplies for the computer and the peripherals - and yes the power supply for the 1010 works on the 1050. http://www.ecrater.com/product.php?pid=1424533 Quote Link to comment Share on other sites More sharing options...
Atari Smeghead Posted August 10, 2009 Share Posted August 10, 2009 (edited) I found this in FAQ: 9 VAC 31 VA 3.4 A Max:50W Power Adaptor Atari#C017945(unit)/CA017964(box) http://www.computerhistory.org/collections...ssion/102688424 400,800,810,822,850,1200XL,1010,1020,1050,XF551 Can any one check on their Power supply? I can promise you that the power supply for the 1050 is identical to 400/800/810/850/1050/1020. I have used them for all of those devices. I grabbed my C017945 PS and yes, what you wrote above for the power output is correct. I have no history with the others mentioned above, , but according to B&C's website, PS is interchangable with XF551/1200XL too. You can buy a PS from B&C for $9.95, if you need one. http://www.myatari.com/atarixlh.txt - about halfway down the page. It also shows what PSs go with what machine, as well. Cheers, Smeg Edited August 10, 2009 by Atari Smeghead Quote Link to comment Share on other sites More sharing options...
amiman99 Posted August 10, 2009 Author Share Posted August 10, 2009 Thanx, I will try it as soon as I find a disk for it. Quote Link to comment Share on other sites More sharing options...
Bryan Posted August 16, 2009 Share Posted August 16, 2009 My 1010 came with a tiny wall-wart supply that wouldn't power a 1050. In the US, I know Atari shipped a couple different sized AC bricks. The smaller one was okay for the computers, but the larger one was recommended for the drives. Quote Link to comment Share on other sites More sharing options...
amiman99 Posted August 29, 2009 Author Share Posted August 29, 2009 It worked fine, the light came on, but I don't have dos disk to try it. I think I will get SIO2PC to copy some disks now. Quote Link to comment Share on other sites More sharing options...
