0
quickest check for a missle
6 replies to this topic
#1 grafixbmp OFFLINE
grafixbmp
    Dragonstomper
  • 659 posts
Posted Tue Oct 13, 2009 12:02 AM
I have aprox 7 cycles to check the Y index (used as a line counter) for a single missle and draw it. Can the pros do it in this length of time? I probably squeeze an extra cycle making it 8.
I am finding myself doing part of a display routine like checking for an object or positioning it one scanline and then doing the actual loading and displaying of the object the next avaliable one. Or preloading data for display but storing it as a temp in RAM for a call back when the time is right on a scanline.are these ever common practices?
Edited by grafixbmp, Tue Oct 13, 2009 12:13 AM.
#2 Omegamatrix OFFLINE
Omegamatrix
  • 4,795 posts
Posted Tue Oct 13, 2009 1:26 AM
Oh boy.
Okay, I seem to remember a trick for this that was first done in Combat. I think it went like this, IIRC.
1. Have the scanline you want the missile to appear on stored in ram.
2. Compare the scanline you are on the the scanline the missile is on.
3. Push the processor status onto the enable register. The **trick** (why this works) is the Zero Flag is set when the compare is equal to the scanline. Since the Missile Enable and Zero Flag occupy the same bit xxxx xxXx the processor status can be used to enable/disable the missle.
7-8 cycles though?
;stack pointer has to be adjusted before hand, it needs to point to the enable register (ie ENAM1, ENAM2, etc..) so you need to find more cycles before it happens.
CPY scanline ;3
PHP ;4 (already at 7 cycles)
however, you need to readjust the stack register back each time you do this! So you again you need to find more cycles. :(
The simple way to adjust the stack pointer is to waste 4 more cycles (when you can) with a PLA. This will trash the accumulator, so do it when you are not needing, or about to reload the accumulator.
i.e.
PLA ;4 (reset stack to the missile, but trashes the accumulator)
LDA #whatever (ahhhh, now it doesn't matter.)
The minimum needed for this method is 11 cycles (split into 7 cycles, and 4 cycles), plus the stack pointer adjusted before hand (more cycles), plus a ram register (to compare the scanline to), plus the stack pointer free (i.e. you are not jumping to a subroutine during the kernel, or using the stack pointer for other things.)
Edited by Omegamatrix, Tue Oct 13, 2009 1:37 AM.
#3 grafixbmp OFFLINE
grafixbmp
    Dragonstomper
  • 659 posts
Posted Tue Oct 13, 2009 1:39 AM
Very nice. I think I can fit this in. Thanks. I just had another thought, but think it would be best as a new topic.
Edited by grafixbmp, Tue Oct 13, 2009 1:40 AM.
#4 bogax OFFLINE
bogax
    Star Raider
  • 61 posts
Posted Tue Oct 13, 2009 5:45 AM
View PostOmegamatrix, on Tue Oct 13, 2009 1:26 AM, said:
Oh boy.
7-8 cycles though?
CPY scanline ;3
i.e.
PHP is three cycles
Assuming you were willing to use self modifying code and reserve the X register
to the pupose you could
TSX
CPY #
PHP
#5 cd-w OFFLINE
cd-w
  • 1,195 posts
  • Juno First!
Posted Tue Oct 13, 2009 6:23 AM
You can use the stack trick as described above, or if you have plenty of ROM to burn, you could just use:
lda (MPTR),y   + 5
sta ENAM0      + 3
You would need a large table consisting of zeros for every scanline other than the one on which you want to display the missile (which would contain the value 0x10). You can then move the missile vertically by changing the value of MPTR.
Not very efficient, but if you are really stuck for cycles ...
Chris
#6 bogax OFFLINE
bogax
    Star Raider
  • 61 posts
Posted Fri Oct 16, 2009 3:13 AM
TSX
CPY #
PHP
oops, that should be
TXS
CPY #
PHP
#7 Ben_Larson OFFLINE
Ben_Larson
    Moonsweeper
  • 336 posts
Posted Fri Oct 16, 2009 6:11 PM
You don't have to reserve the X register. Before the kernel starts, you can do a:
LDX #$1F
TXS
Then inside the kernel, on each line you want to display the missile, you do:
CPY MissileYPos
PHP
PLA
Although that does take longer. After the kernel, you'll probably want to restore the pointer stack.
Edited by Ben_Larson, Fri Oct 16, 2009 6:13 PM.
