Trying to repair a dead colecovision,
So far I have removed and cleaned the power switch, replace PSU for a know good one, replaced DRAM at U15.
Still get a black screen on startup, sometimes with an audio screech.
Any ideas what I should do next?
Help with dead Colecovision
Started by mimo, Nov 17 2009 5:25 AM
5 replies to this topic
#1 ONLINE
Posted Tue Nov 17, 2009 5:25 AM
#2 ONLINE
Posted Tue Nov 17, 2009 5:53 AM
edit, on some occasions with a cart inserted I get a blue border with blue vertical lines down the screen (Gorf cart) and with Donkey kong inserted I get a blue screen flash on every 3 seconds or so:x
once I got a garbled title screen on Gorf but I can't get that to happen again
#3 ONLINE
Posted Tue Nov 17, 2009 6:40 AM
another update, I get the same effect with nothing inserted at U15
#4
Posted Tue Nov 17, 2009 9:21 AM
One thing that often goes wrong is the RF unit (this sends the sound and video to your TV) inside the console. I had many video problems that were not caused by say the power switch. Eventually, I did an AV mod so I could catch the sound and video before it gets to the RF unit. There are many ways to do it. I used Ben Heck's AV mode because it is relatively simple, cheap, and my flat screen likes it. Everything has been working fine since. I can even move my console without it going haywire!
#5 ONLINE
Posted Tue Nov 17, 2009 9:44 AM
I should have mentioned that it is a PAL system, unfortunately the AV mods do not work on these. I don't believe the problem to be RF related as when I do get any output on the screen the signal is good and strong.
#6
Posted Sat Nov 28, 2009 12:17 AM
Sounds like bad DRAM. Do the modification on the board and replace those pesky 4116 DRAMs with some 4516 or 4164 types that are 5v only.
http://newlifegames....g11121#msg11121
1 user(s) are reading this topic
0 members, 1 guests, 0 anonymous users
