0
that byte at $fff9
3 replies to this topic
#1 doppel OFFLINE
doppel
    Star Raider
  • 65 posts
Posted Fri Nov 27, 2009 6:48 PM
According to all the literature I keep reading, if the low nybble of $fff9 in the cartridge ROM is set to any other value besides $x3 and $x7, the BIOS will reject it as an invalid cart. That's true enough.
What doesn't seem true is how $x3 and $x7 act. According to some sources (including the badly-aged BIOS code source from GCC) if the value at $fff9 in the cart ROM is set to $x7, it will display the Atari logo and fuji symbol, but if it's set to $x3 it will skip that. However, I've been studying the NTSC BIOS ROM closely, and I've noticed that before the routine at $fb84 which actually checks $fff9 is called, the BIOS ROM is switched back in. And I haven't found any occurrence of the routine at $fb84 being called elsewhere in the BIOS. (Edit: Also, there's the fact that the BIOS ROM would have to be switched in for the routine at $fb84 to be called, since it isn't copied to RAM.)
So it checks $fff9 in the BIOS ROM, NOT the cart's ROM!
I tested this by changing the byte at $fff9 from $c7 to $c3 in the Asteroids ROM and re-signing it, then running it in an emulator. Sure enough my suspicions were confirmed - the Atari logo and fuji symbol were still displayed.
So either I'm wrong or everybody else is.
Edited by doppel, Fri Nov 27, 2009 9:59 PM.
#2 gdement OFFLINE
gdement
  • 1,752 posts
Posted Sun Nov 29, 2009 8:22 AM
Interesting observation. From what you describe, it sounds like a BIOS bug. They surely didn't mean for it to work that way.
I'm surprised if nobody has ever tried disabling the Atari logo before now. I never have.
#3 Bruce Tomlin OFFLINE
Bruce Tomlin
  • 3,531 posts
  • CD C9 01
Posted Wed Dec 2, 2009 11:29 PM
The main reason not to disable the atari logo is that the signature check still runs, so you would have a blank screen for that time. It's not like the Colecovision's startup screen that is just running a LONG delay loop. It's not so bad when only 4K of the game is signed, but a whole 16K would keep the screen blank for like a whole second. And it's a kind of cool startup logo anyhow.
#4 doppel OFFLINE
doppel
    Star Raider
  • 65 posts
Posted Tue Feb 21, 2012 10:56 PM
The thing is, when you change that byte's lower nybble to a 3, it gets stuck in an infinite loop.
Edited by doppel, Tue Feb 21, 2012 10:56 PM.
