4Ks, on Mon Dec 14, 2009 9:23 AM, said:
therealbountybob, on Mon Dec 14, 2009 4:19 AM, said:
4Ks, on Sun Dec 13, 2009 3:43 PM, said:
Unfortunately, I don't have this game, and I can't seem to get
any emulator except Stella (2600 emu.) to work on my turdy Windows XP PC. It's so annoying
. So, until we play either Pac-Man, Donkey Kong, or Blue Max, I won't be participating in this HSC.
Atari800Win Plus 4.0 works fine on XP - have you tried this emulator? You will need to use the ROM files from the Xformer emulator also on this link. Link to
Super Zaxxon ATR and XEX formats.
If you get stuck there are some (bad instructions on my site below and probably) much better info on the main 8-bit forum or just post here and well get you up and runnin
So now that I have all the required files, how do I configure Atari800win plus to work with them?
Something like this...
Select the Atari menu, then ROM images.
Click on XL/XE and find the ROM file (from the XFormer you also downloaded) ATARIXL.ROM
Also select BASIC and browse to ATARIBAS.ROM.
You can leave OS-A, OS-B, 5200 and Cartridge blank for now.
From the Atari menu, select Settings and make sure only the 'Enable SIO patch' for fast disk access is ticked.
Now go to the Input menu, select Joysticks, make sure Autofire Mode is off, choose Arrows + RCtrl as fire on Joystick 1 (or map keyset 1 as you wish)
Go to the the View menu, then Graphics Options, select 1024x768 or 800x600 etc. I use Alt and Enter to toggle between window and full screen.
Then from the file menu Load Executable (XEX & COM files) or Autoboot Image (ATR) files and get Zapping
Good Luck may the 4Ks be with you
Edited by therealbountybob, Mon Dec 14, 2009 1:04 PM.
