bacteria Posted December 24, 2009 Share Posted December 24, 2009 I read somewhere that the ColecoVision will run on either PAL or NTSC games; is this correct? Reason i'm asking is that I can't work out how to make my PAL ColecoVision console output composite or S-video and I have a stack of PAL games. If I were to buy an NTSC console, would it play my PAL games fine - if it does, any restriction or issues, like speed issues, or borders, etc? Quote Link to comment Share on other sites More sharing options...
Pixelboy Posted December 24, 2009 Share Posted December 24, 2009 I read somewhere that the ColecoVision will run on either PAL or NTSC games; is this correct? Reason i'm asking is that I can't work out how to make my PAL ColecoVision console output composite or S-video and I have a stack of PAL games. If I were to buy an NTSC console, would it play my PAL games fine - if it does, any restriction or issues, like speed issues, or borders, etc? AFAIK, all CV carts (american and european) are compatible with both NTSC and PAL systems, and are fully interchangeable as such. Beyond that, I don't know the specifics of visible differences between the two standards, where CV games are concerned. Don't CV games run a tiny bit faster on 50Hz TV screens..? Quote Link to comment Share on other sites More sharing options...
ten-four Posted December 24, 2009 Share Posted December 24, 2009 Don't CV games run a tiny bit faster on 50Hz TV screens..? Unfortunately it is a bit slower. Quote Link to comment Share on other sites More sharing options...
Bruce Tomlin Posted December 25, 2009 Share Posted December 25, 2009 There's one byte in low ROM that is decimal 60 on USA systems. I'm presuming that was meant to indicate 60 hertz. Apparently there is no way to tell whether your VDP is 50hz or 60hz other than with a timing loop that watches the retrace interrupt flag. Quote Link to comment Share on other sites More sharing options...
ten-four Posted December 25, 2009 Share Posted December 25, 2009 I do not think that it is from the electronics itself from CV, but from the power supplied from the power station from the outside that makes the difference between 50Hz and 60Hz. ColecoVision is structured so that it works as both NTSC and PAL, therefore the small difference in Hz. TMS9918/28/29 show video signal no matter what, it is only through RF/HF adapted to your TV. (am i wrong on that ?). I have a French version of ColecoVision with RGB, is there anyone who has experience with Euro Scart Output in U.S. ? Ole Nielsen. Quote Link to comment Share on other sites More sharing options...
bacteria Posted December 25, 2009 Author Share Posted December 25, 2009 The RF is certainly different between NTSC and PAL, and the PAL board also looks different to the French (SECAM) board. I presume a French Coleco will work fine on RGB via UK PAL? Can't find a French Coloco, will keep my eyes out for one. Quote Link to comment Share on other sites More sharing options...
ten-four Posted December 25, 2009 Share Posted December 25, 2009 I presume a French Coleco will work fine on RGB via UK PAL? Can't find a French Coloco, will keep my eyes out for one. Even i live in PAL land, and can confirm that the French version works perfectly here in Denmark. I bought mine here via AtariAge by Mimo with a tip from Pixelboy Quote Link to comment Share on other sites More sharing options...
PkK Posted December 25, 2009 Share Posted December 25, 2009 (edited) There's one byte in low ROM that is decimal 60 on USA systems. I'm presuming that was meant to indicate 60 hertz. Apparently there is no way to tell whether your VDP is 50hz or 60hz other than with a timing loop that watches the retrace interrupt flag. Byte 0x69 in the BIOS gives the retrace interrupt frequency. In my libraries this is alternatively exposed through cv_get_vint_frequency(). IT will return 60 on NTSC CVs, 50 on PAL CVs. I use it mostly for timing when playing music. Philipp Edited December 25, 2009 by PkK Quote Link to comment Share on other sites More sharing options...
youki Posted December 26, 2009 Share Posted December 26, 2009 French SECAM Coleco works in Europe because most of the TV now support PAL/SECAM standards . in the 80's it was not the case. You had SECAM only TV and PAL only TV. A SECAM console does not work on a PAL Only TV. (i think it works but you have B&W Image ,but not sure..). (And of course PAL console does not work on SECAM only TV) Concerning compatibility with NTSC , until now i didn't have any problem to run NTSC commercial game on my SECAM Coleco. But Some problem can occur, i have experienced that on the current game i'm developping. It worked on PAL but not at all on NTSC. The cause was Timing. I was doing lot of code during the vertical blank interupt , and on PAL/SECAM i have simply more time between 2 interrupts so i could do more things.. I had to optimize and strip down my game to make it work on both. I hate NTSC... Quote Link to comment Share on other sites More sharing options...
