Gury Posted December 24, 2009 Share Posted December 24, 2009 (edited) Hello all in Christmas time, Here is another bulk of listings from Moj Mikro magazine. Presented here are short listings, which may be useful and fun for some of you... or not. The programs are collected in ATR disk image file, with Atari DOS installed. All programs are in tokenized form, except of file HEADER.LST on disk, which is of no concern here. For a change source code listings of programs are included for everyone to examine with no need to run original hardware or Atari emulator. File for download is in attachment section. All the material here is the property of Moj Mikro magazine, but the listings can be used freely in your own programs. Trapping BASIC errors Moj Mikro 1986/10/33 Author: Igor O. File on disk: MM861033.BAS One of the rarely used commands in Atari BASIC is TRAP. It can help you find errors in your own programs. Example of using TRAP command is: After program is run, it will jump to line 1000 and print coded error message. Also, it will print the line where error was detected. Additional lines Moj Mikro 1987/5/74 Author: Antun Kis File on disk: MM870574.BAS This short program adds additional lines above existing ones. New lines do not scroll, but the content can be easily changed. You can also try to change to other two text modes, 1 and 2 respectively. This example uses absolute addresses of display list locations, which is not recommended. It is better to read addresses for display list, screen memory and such, with corresponding address pointers, which calculate it for you automatically. Special characters for formatting the text on the screen Moj Mikro 1988/03/55 Author: Bosko Lucev File on disk: MM880355.BAS Some of the special characters, integrated in your little machine, can be used for formatting text on the screen. Simultaneous press of two or three keys print such characters on the screen. I will not describe the functions of these special characters, because there are many books for your Atari, which cover this subject. Here is an example program, which generates a menu on the screen by using special control characters. Timer Moj Mikro 1989/3/54 Author: Zlatko Bleha File on disk: M8903541.BAS If you want to make use of internal timers of 8-bit Atari, this program is for you. Time is measured in seconds and miliseconds. It won't be hard to modify this program to show minutes and hours. Such program is useful for setting time limit, for example measuring the time in games. Reset Moj Mikro: 1989/3/54 Author: Edin Husakovic File on disk: M8903542.BAS Moj Mikro 1989/4/58 Author: Zlatko Bleha File on disk: M8904581.BAS File on disk: M8904582.BAS This program shows how to use your own machine language routine in place of default reset behaviour - when you press Reset button. If we put value 3 on address 9, we call the routine, which low and high byte of address are on locations 2 and 3. When you run this program and press Reset key, text shows on the screen. Zlatko Bleha recommended safer approach by filling location 9 with value 1 or 2. Previous solution can lock the system. a) Putting address of the program at locations 12 and 13 (DOSINI) 10 POKE 9,1: POKE 12,0: POKE 13,6 b) Putting address of the program at locations 2 and 3 (CASINI) 10 POKE 9,2: POKE 2,0: POKE 3,6 Help button Moj Mikro: MM89/3/54 Author: Edin Husakovic File on disk: M8903543.BAS This short program shows how to use Help button in your own program. Location 732 holds value 17, if we press just Help button. In combination with Shift key it gives value 81 and in combination with Control key value 145. When we release Help button, the value on address 732 does not change, so we need to reset its value by typing POKE 732,0 in BASIC. tips_and_tricks_no1.zip Edited December 24, 2009 by Gury Quote Link to comment Share on other sites More sharing options...
