Jaguar file extensions
18 replies to this topic
#1
  • 27,072 posts
Posted Sat Jan 2, 2010 4:05 PM
I am setting up a new Downloads module for the forum, and I need to know what valid file extensions I should allow for Atari Jaguar files. This will mainly be intended for demos and games that authors want to share freely (for projects in development and released).
Thanks!
..Al
#2
  • 5,694 posts
  • 7800 Guy
Posted Sat Jan 2, 2010 4:16 PM
.BIN, .ROM, .JAG and .ABS should cover most of them. :)
Mitch
#3
  • 27,072 posts
Posted Sat Jan 2, 2010 4:26 PM
Mitch
Thanks. :)
..Al
#4
  • 1,252 posts
Posted Sat Jan 2, 2010 4:33 PM
And thanks for the new feature, Albert :thumbsup:
#5
  • 2,008 posts
Posted Sat Jan 2, 2010 4:42 PM
Please add in .COF & .PRG they are frequently used also for the Jaguar. ;) :) -Even more so now with the many Skunkboards around.
Albert, if you would like valid working examples of these two I mentioned, I can make a zip file with some working Jaguar files of these, that I have handy on my HDD for Skunkboard use.
Edited by ovalbugmann, Sat Jan 2, 2010 4:45 PM.
#6
    Dragonstomper
  • 715 posts
Posted Sat Jan 2, 2010 4:44 PM
There's been at least one during the past year shared as an NRG file (Nero CD image)
#7
  • 27,072 posts
Posted Sat Jan 2, 2010 4:53 PM
View Postovalbugmann, on Sat Jan 2, 2010 4:42 PM, said:
Please add in .COF & .PRG they are frequently used also for the Jaguar. ;) :) -Even more so now with the many Skunkboards around.p
Thanks, I've added these. :)
Quote
No reason to, but thanks for the offer.
..Al
#8
  • 27,072 posts
Could that file have been saved in some non-proprietary CD format?
..Al
#9
    Dragonstomper
  • 715 posts
Posted Sat Jan 2, 2010 5:02 PM
..Al
Honestly I'm not technical enough to know.... I imagine ISO or CDI or some other CD image format would work, but I don't know the Jaguar's CD requirements and it seems, at least to me, that within the Jag community there seems to be a preference for NRG images when it is CD.
Someone please jump in and correct me who has been around longer.
#10
  • 2,008 posts
Posted Sat Jan 2, 2010 5:03 PM
Quote
Yes, they are non-propietary Jaguar disc image extensions.
.NRG(Nero) & .CDI(Discjuggler) are not Jaguar specific file extensions and can be used for any disc image for any platform. Although they are popular and are frequently used for CD-R disc images for burning Jaguar games/videos/apps that will be run from the Jaguar CD Player.
Might as well include them though. :) - the more the merrier. :P
Keep in mind though Al, those are the ones that could be large in size -up to around 700 MB. :o
To best answer your question Al; The CD format Atari used and developers use and I use(when making video cds for the Jag) is just a folder with a set of "CDRECORD" files. They are a group of files that work together and include a Warning.WAV file(just an audio file), a burnenc.BAT file, several Track02.RAW type files, a cdrecord.exe file and cygwin.dll file.
If you want to allow for this type of file set on your system just a .ZIP or .RAR which I am sure you already allow would be fine for people who want this form(cdrecord files) of a Jaguar CD image. -As all these file types work together and will be compressed into a zip or rar most frequently. After the disc is burned and checked in this format - only then is it converted into a .NRG or .CDI disc images then compressed to .RAR or .ZIP for distribution as most people don't like to mess with old cdrecord type files.
So just .RAR or .ZIP will do! for the Jaguar CD.
Edited by ovalbugmann, Sat Jan 2, 2010 5:21 PM.
#11
  • 1,252 posts
Posted Sat Jan 2, 2010 5:08 PM
Jaguar game CDs need at last two sessions to be playable on a standard console, and the ISO file format only supports a single session.
Unfortunately, it seems there is no real standard file format for multisession CDs ; NRG (Nero Image) files are the most popular.
Regarding the size, almost all homebrew CD games are much smaller than 700 MB. Most of the size is used by the mandatory CD audio track before the actual data ; it could be replaced by silence, which would compress well in a ZIP file.
Edited by Zerosquare, Sat Jan 2, 2010 5:11 PM.
#12
  • 27,072 posts
Posted Sat Jan 2, 2010 5:09 PM
Okay, thanks for the explanation of NRG as it relates to Jaguar CD images. :)
..Al
#13
  • 4,633 posts
Posted Sat Jan 2, 2010 5:26 PM
If it has not already been mentioned Cd images are more like an audio disc( in fact it is a audio disc).
Ofcourse you can always zip up the file.
#14
  • 2,008 posts
Posted Sat Jan 2, 2010 5:40 PM
So Albert, just .RAR or .ZIP will do! for the Jaguar CD.
As .NRG(nero) or .CDI(dj) Jaguar CD Image should be compressed into a .RAR or .ZIP file for bandwidth conservation for you(the host) and the downloader. ;) This will go quicker especially for those with slow internet.
Quote
Very True! Definitely!, Yes, only way a Jaguar CD disc will approach 700MB in size, nowadays with just homebrew dev going on is if the disc is a Cinepak JaguarCD - and people don't care for those too much, since there not games to actually play!
Edited by ovalbugmann, Sat Jan 2, 2010 5:43 PM.
#15
    Dragonstomper
  • 527 posts
Posted Sat Jan 2, 2010 11:39 PM
Al,
Jaguar file extensions to add. These are ones typically associated with source code files:
.3DS - Autodesk 3D-Studio object file
.BPG - Jaguar BPEG graphic file
.C - C source code
.CRG - Jaguar Cinepak Chunky-format 16-bit RGB film file
.SRG - Jaguar Cinepak Smooth-format 16-bit RGB film file
.CRY - CRY-format graphic image
.DAS - DSP assembly source file
.DB - Debugger script file
.GAS - GPU assembly source file
.S - 68K assembly source file
.H - C include file
.INC - Jaguar include file
.O - Jaguar object module (pre-linked compiled code)
.MID - MIDI score file
.SYM - Symbol Table File
.TXT - Jaguar binary image of program text segment
.DTA - Jaguar binary image of program data segment
I've attached the reference pages from the Jaguar developers manual. But I pulled some of the most likely ones that can be found with source code files.
Glenn
#16
  • 12,240 posts
Posted Sun Jan 3, 2010 4:31 AM
Also missed off .j64
Edited by carmel_andrews, Sun Jan 3, 2010 4:32 AM.
#17
  • 2,008 posts
Posted Sun Jan 3, 2010 9:01 AM
That's right .J64 is an after Atari folded, BJL file extension(i think) -add it in Al! :)
#18
  • 12,240 posts
Posted Sun Jan 3, 2010 12:57 PM
Some PD roms don't work though (either bin or rom format)
So perhaps we should also have a list of what works and what does not work
#19
  • 27,072 posts
Posted Sun Jan 3, 2010 1:16 PM
That's outside the scope of this discussion--feel free to start another thread to discuss that if you'd like.
..Al
1 user(s) are reading this topic
0 members, 1 guests, 0 anonymous users
