Last time I was home, I found an ICD "P:R Connection," to wit, one o' these:
http://page6.org/arc..._30/page_74.htm
Is there any way to use this to back up files or disk images onto a PC without having to buy anything other than maybe a cable? (I have m'old RS232 SIO cables, no worries there.) Or is there no driver that will make that possible? I'm dreaming that I can hook a modern external USB drive up to m'old Atari 800 via Atari 800 to RS232 cable to P:R Connection to Parallel cable to parallel-to-USB converter cable to the USB drive... but I'm probably dreaming. (Am I?) OR, use it to hook an old Atari 1050 drive directly to a PC (1050 drive to RS232 cable to P:R Connection to parallel cable to PC, or mebbe using a parallel-to-USB converter for the final hookup).
If that's all a pipe dream, it looks like SIO2PC is the way to go (the USB version with the SIO jack), to wit:
http://www.atarimax....tion/index.html
But their page is really unclear whether I can just buy one of these lovelies and jack my 1050 drive directly into my PC, or whether I also need to purchase the "APE for Windows" for a driver... though I also stumbled across this:
http://sourceforge.n...rojects/aspeqt/
If I purchase an SIO2PC and download the above, will it serve as a driver to hook a 1050 up directly to my PC and image the disk from there? (Or even just transfer the files? I have an old copy of "Make ATR," so I could grab the files individually to my PC and then make the disk image if necessary.)
Thanks for your patience and time. Yay.
This post has been edited by CKlemow: Mon Jan 4, 2010 6:53 PM
Sign In
Register
Help
MultiQuote
