Video Pencil
29 replies to this topic
#1 atari2600land OFFLINE
atari2600land
  • 6,494 posts
  • All hail the zyzzyva!
Posted Fri Mar 5, 2010 2:38 AM
This could be a nifty Easter egg, or good on its own IMO. There's just one problem: The only diagonal line you can make is up and right. I want to know why this is and fix it so you can make all 4 diagonal lines. You might have seen this in my blog under the Videomation name, but I decided to drop the title screen and song and make this a 2k game.
#2 Random Terrain ONLINE
Random Terrain
    Visual batari Basic User
  • 20,914 posts
  • Controlled Randomness
    Replay Value
    Nonlinear
Posted Fri Mar 5, 2010 4:57 AM
I don't see a line. Is there something special you have to do? Is it a drawing program kind of like these 2 versions of Double-click Draw:
http://www.atariage....08#entry1487708
http://www.atariage....07#entry1487807
#3 atari2600land OFFLINE
atari2600land
  • 6,494 posts
Posted Fri Mar 5, 2010 10:07 AM
To draw a line, the left difficulty switch should be in A. To move the pencil, use the joystick, and to draw, press fire.
#4 Random Terrain ONLINE
Random Terrain
  • 20,914 posts
    Replay Value
    Nonlinear
Posted Fri Mar 5, 2010 11:10 AM
Since Stella seems to have B as the default, why not use B instead of A?
Oh, OK. It is kind of like those two versions of Double-click Draw.
Normal version:
Attached File  double_click_draw_2008y_03m_22d_1100.bin   4K   66 downloads
(Draw or erase by holding down the fire button and change the color of the playfield pixels by double clicking.)
Special multicolored version:
Attached File  double_click_draw_special_2008y_03m_22d_1402.bin   4K   90 downloads
(Draw or erase by holding down the fire button and change the color of a row of playfield pixels by double clicking.)
#5 atari2600land OFFLINE
atari2600land
  • 6,494 posts
Posted Fri Mar 5, 2010 3:41 PM
Somehow I must have missed that program. Here, I changed it to B. But the question remains: Why is the only diagonal line I can make is up+right? It just doesn't make any sense to me.
#6 MausGames OFFLINE
MausGames
    Dragonstomper
  • 851 posts
Posted Fri Mar 5, 2010 5:44 PM
I have this problem in my programs too, not sure what it is; either something to do with the keyboard, stella, or the way we are checking the joystick.
For example if I have a game with a free-moving spaceship, I can only move it up and right while firing at the same time, trying to fire and move diagonally in other directions won't work unless I have a joystick hooked up to my laptop.
Edited by MausGames, Fri Mar 5, 2010 5:45 PM.
#7 atari2600land OFFLINE
atari2600land
  • 6,494 posts
Posted Fri Mar 5, 2010 5:56 PM
Just tried this in Z26 and it works fine, so it must be a problem in Stella. Started a topic about this in the Emulation forum.
#8 RevEng ONLINE
RevEng
  • 2,010 posts
  • bit shoveler
Posted Fri Mar 5, 2010 6:05 PM
Your pencil program works fine for me with all diagonals, in Stella under Ubuntu.
I suspect its a keyboard and/or Windows thing.
#9 atari2600land OFFLINE
atari2600land
  • 6,494 posts
Posted Fri Mar 5, 2010 11:33 PM
Here's a new version. You can change the color of the drawing by pressing and holding the select button. Also, you can start over by pressing the reset switch. I also removed the score, which made the number of bytes available from 127 to 328! So, any suggestions on what features I should add next?
#10 stephena ONLINE
stephena
  • 1,967 posts
  • Stella maintainer
Posted Sat Mar 6, 2010 9:26 AM
It's working for me in Stella with Linux, OSX and Windows. Stella processes events differently from z26, and has to do it that way because of its event remapping capabilities. I suspect you're trying to move in an opposite direction while still having the other direction pressed (ie, you're trying to go right and still have left pressed). Also, some keyboards don't respond to multiple keys at the same time in the same way.
There's also the '-joyallow4' commandline argument that allows all 4 directions to be recognized at once, but I still think the main problem is that you have to physically let go of one direction before selecting another. The fact that it works fine with a joystick (which by design cannot select both directions at the same time) seems to confirm this.
Also forgot to add that Keyboards Are Evil.
#11 atari2600land OFFLINE
atari2600land
  • 6,494 posts
Posted Sat Mar 6, 2010 11:04 AM
OK, I read the Keyboards are evil thing, so I changed fire from space to right shift and it works OK.
#12 Philsan OFFLINE
Philsan
  • 2,335 posts
  • New Orleans Saints Super Bowl XLIV Champions
Posted Sat Mar 6, 2010 1:57 PM
Very nice!
#13 atari2600land OFFLINE
atari2600land
  • 6,494 posts
Posted Sat Mar 6, 2010 5:32 PM
I got bored, so I tinkered with this some more. Now, to change to color of the drawing, you press the select switch with right difficulty switch on B. To change the color of the background, press the select switch with right difficulty switch on A. Anything else I should add?
Edited by atari2600land, Sat Mar 6, 2010 5:37 PM.
#14 atari2600land OFFLINE
atari2600land
  • 6,494 posts
Posted Sun Mar 7, 2010 4:38 AM
I've been working on this basically non-stop all night, trying to fit some more features in. Then it occured to me: Why not get rid of the scrolling part in the default.inc file? So I did and now I have 58 bytes left. I've added a bunch of stuff like a title screen with title screen music, and adding in a black and white option with the color/bw switch. The eraser is a square instead of an upside down pencil.
#15 Ethaniel OFFLINE
Ethaniel
    Chopper Commander
  • 189 posts
  • bored...
Posted Sun Mar 7, 2010 4:59 AM
good work :) i really like it :D
so is there a full features list or a to-do list? dunno what to try :P
isn't it possible to display more than one colors at the same time or make the dot smaller?
maybe before you start painting you could choose the background color...
Edited by Ethaniel, Sun Mar 7, 2010 5:00 AM.
#16 Philsan OFFLINE
Philsan
  • 2,335 posts
Posted Sun Mar 7, 2010 8:30 AM
It would be nice to have an intuitive menu to select options but I think it's too complicated.
Perhaps a menu with simple coloured boxes would be better than using switches.
Edited by Philsan, Sun Mar 7, 2010 9:45 AM.
#17 atari2600land OFFLINE
atari2600land
  • 6,494 posts
Posted Mon Aug 30, 2010 11:51 PM
I tinkered with this even more and fit in bass notes and a "cymbal" noise during the title screen music. 6 bytes left!
#18 Lendorien OFFLINE
Lendorien
  • 1,029 posts
Posted Sat Sep 4, 2010 6:02 PM
Heya,
I tried this out. It's a bit simplistic in form, seeing as you can't have multiple colors on the screen at once and have to use switches to change the colors.
That said, I love the tones when drawing and I think the pencil is pretty cool.
Overall a fun program. It's be neat to see if one could make a program like this with a few more features, such as multiple colors and a selectable menu. But for 2K, it's pretty cool.
Hm. Go 4K and make.... Atari Paint. :D
Edited by Lendorien, Sat Sep 4, 2010 6:06 PM.
#19 TooSlowGamer OFFLINE
TooSlowGamer
    Chopper Commander
  • 126 posts
Posted Sat Sep 4, 2010 6:11 PM
Hehe, I drew a penis!
#20 Ethaniel OFFLINE
Ethaniel
    Chopper Commander
  • 189 posts
  • bored...
Posted Sun Sep 5, 2010 8:47 AM
picture or it never happened :D :D :D :D :D
#21 Philsan OFFLINE
Philsan
  • 2,335 posts
Posted Tue Sep 7, 2010 4:56 AM
Hm. Go 4K and make.... Atari Paint. Posted Image
+1
#22 yuppicide OFFLINE
yuppicide
    I am the Black Knight. Give me your money!
  • 6,933 posts
Posted Wed Sep 8, 2010 7:18 PM
Neat program. I like the pencil sprite.
Edited by yuppicide, Wed Sep 8, 2010 7:18 PM.
#23 atari2600land OFFLINE
atari2600land
  • 6,494 posts
Posted Sun Apr 10, 2011 2:01 PM
Hey gang, I decided to go improve this program. I cleaned up the code, and got the pencil to go upside down instead of having a crappy eraser sprite. In case you don't know how to operate it:
color/b&w switch: toggle between color and black & white.
fire at the title screen goes to the drawing screen.
Fire + joystick: draw/erase
left difficulty swtich A - erase
left difficulty switch B - draw
Reset switch - clears everything.
right difficulty switch A + select switch - select through different graphite colors
right difficulty switch B + select switch - select through different paper colors.
it's 2k right now and i have 2 bytes left! If you want to compile this for yourself, you'd need to go into your default.inc file and unselect "pf_scrolling.asm" by putting in a semicolon before it (thus making it into a rem statement and not deleting it completely from the include file.)
#24 Random Terrain ONLINE
Random Terrain
  • 20,914 posts
    Replay Value
    Nonlinear
Posted Sun Apr 10, 2011 2:27 PM
View Postatari2600land, on Sun Apr 10, 2011 2:01 PM, said:
It's 2k right now . . .
Sorry, I only play 1k games.
#25 atari2600land OFFLINE
atari2600land
  • 6,494 posts
Posted Sun Apr 10, 2011 7:17 PM
Vigorously combed through the code, deleting unneccessary stuff left and right. Now I have 107 bytes left! What should I do with them? I'm only attaching the .bas file because the binary file is about the same, except for I narrowed the drawing area just a little bit to make some division math work properly.
1 user(s) are reading this topic
0 members, 1 guests, 0 anonymous users
